noob question about 33x12.5x15 load capacity - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 03-03-2015, 05:12 AM Thread Starter
hello,
i'm a newbie to the forum.
im in a 2011 unlimited sport with 17" oe wheels. wanted to go with a wider more aggresive tread.
after reading about 200 posts on the forum, i had decided to go with the 33"x12.5"x15 duratrac tire and wheel package from discount tire (i was thinking 15x8 mbtko 5x5) when i contacted the sales rep through the forum he told me that the stock tire carries a load capacity on 2,458 lbs and the 33" duratrac on 15" falls short at 2,205 lbs. i was told i could either move up to a 35" tire on 15" rim (requiring lift) or i would have to go with a 16" rim.
ive seen dozens of posts from unlimited sport owners runing the 33"x12.5" duratrac package. is there something im missing?
any information would be greatly appreciated.
marleycustom is offline
post #2 of 9 Old 03-03-2015, 06:27 AM
WINNAR!
DOOKEY's Avatar
Look at the door card to check the total weight of your vehicle. You need tires that support that weight. Years ago Jeep put load range E tires on TJ's. Just because Jeep did it doesn't mean it has to be that way.
Unfortunately, all the big tire chains are going to suggest OE applications. Never looked myself but I'd be interested in what your Jeep weighs.
Andy
316.337.5311
DOOKEY is offline
post #3 of 9 Old 03-03-2015, 07:28 AM
Treader's Avatar
Exactly the case. Years ago my dad tried to put some d range on a f350. The place would not do it.
I personally run 33" on 15" wheels Duratracs. I have a 2 door which helps with weight. I have never had a problem with them.
2010 2 door manual sport
Treader is offline
post #4 of 9 Old 03-12-2015, 07:30 PM
I'm running the 33's DT's on a 15x9 KMC Enduros with no problems. Daily driver. 20 PSI for every day driving and 12 PSI when I'm in Moab.
8000ft is offline
post #5 of 9 Old 03-15-2015, 01:08 AM
The thing to consider is the Gross Weight of the JK vs the Load Capacity of the tire. They JK has something like 51/49 weight distribution for 5000 GVWR so you can just divide the gross weight by 4 and add a safety factor. The other important thing to consider is that the load capacity changes with air pressure. Running the tires near the 30 PSI popular air pressure does not provide max load capacity.
It doesn't matter what others do. What matters is what is safe and what you are comfortable with.
spinlock is offline
post #6 of 9 Old 03-15-2015, 06:09 AM
BigTB's Avatar
20PSI seems awfully low for street driving. Are they a bit squirrelly? Seems like they would be pretty soft and wallowy at that pressure on the street.
BigTB is offline
post #7 of 9 Old 03-16-2015, 07:24 PM
I wouldn't want to run a slalom course on them but for what I am running them on they are just fine. A 5000 pound brick on wheels that is designed to go over and through just about anything.
If this was a Ferrari then yes they would definitely be squirlie.
I should add that I got almost 60,000 miles on my last set and they were not quite down to the warning strips yet.
8000ft is offline
post #8 of 9 Old 03-18-2015, 07:34 PM
20 PSI is on the low side even for a C load range tire. It may appear to carry the load but spinning them at 70 MPH can cause them to overheat and damage them.
You are also going to get a lot of sidewall flex and excessive roll when you turn.
spinlock is offline
post #9 of 9 Old 03-18-2015, 08:52 PM
I think some 15" wheels rub on the brake calipers. Better see if there is clearance before you go with 15's instead of 16
longlegs is offline
