35" on stock jk - JKowners.com : Jeep Wrangler JK Forum
post #1 of 16 Old 02-18-2015, 04:55 PM Thread Starter
35" on stock jk
I i want duratrac 35' on my 2015 jk stock? How much inch lift i need?
Fortin.jk is offline
post #2 of 16 Old 02-18-2015, 06:09 PM
0" for trips to the mall.
2012 JKU 6-speed 1.5" on 37" Mud Grapplers
2003 TJ Rubi 5-speed on 35s
NT2HLBLY is offline
post #3 of 16 Old 02-18-2015, 06:30 PM Thread Starter
I want a set up for trail
post #4 of 16 Old 02-18-2015, 07:23 PM
Hartj17's Avatar
Maybe re-write the thread and explain what you are looking for a little better. You will get better responses.
Hartj17 is offline
post #5 of 16 Old 02-19-2015, 01:40 AM
There's a difference between just avoiding interference (stuffing) the 35" DTs and wanting big articulation or even just doing it for proportional looks. There are a lot of options. For starters, what are you looking to accomplish, what type of trail and how much are you willing to spend?
spinlock is offline
post #6 of 16 Old 02-19-2015, 01:50 AM
CamoCop's Avatar
let me see if I understand this...
no lift with 35" tires is only good for the mall BUT a 1.5" lift with 37" tires is acceptable for off-road?
2011 Wrangler Unlimited Rubicon
- 3.5" Rubicon Express lift /w 1.25" BL
- 5.38 Yukon gears
- 40" Pro Comp MT2's
- Lot's of extra's
CamoCop is offline
post #7 of 16 Old 02-19-2015, 01:59 AM
CamoCop's Avatar
if you are aiming for a low center of gravity build or just tight on money, you don't "need" any lift to run 35's on a stock JK. you will need different rims or run spacers. if I was going to go this route I would trim my fender flares and trim/knock back the rear pinch seam inside the rear fenderwells.
- 5.38 Yukon gears
- Lot's of extra's
CamoCop is offline
post #8 of 16 Old 02-19-2015, 09:01 AM
They rub a little
NT2HLBLY is offline
post #9 of 16 Old 02-19-2015, 09:07 AM
I agree. The wife slapped some new fenders on and cut back the pinch seam. 35s would be great with this setup. Nice and low, plenty of room to flex. Buuuuut 37s were calling our name! Rubbing never hurt anything.
Edit: If you want more flex out of it, toss some longer shocks on it while your at it.
NT2HLBLY is offline
post #10 of 16 Old 02-19-2015, 05:51 PM
CamoCop's Avatar
They rub a little
if your not rubbing, then your not try'n hard enough!
- 5.38 Yukon gears
- Lot's of extra's
CamoCop is offline
post #11 of 16 Old 02-20-2015, 07:23 AM
Currently running 35s on stock suspension.
to keep a stock suspension with 35s you'll need to cut the stock fenders or go with flat fenders (I went with flat fenders), and either spacers behind the wheels or new wheels with a 4.5" backspacing (that's what I did).
you'll also need, I believe, 1.5" bump stops to keep the 35s out of the fenders, and don't even think of disconnecting. I'm still running stock bump stops, and haven't had a chance to offroad due to work schedule, so I'm not worried yet. By the time I have time to offroad, I'll have a lift in it.
If you expect to do some serious offroading, I believe the consensus is a 2.5" lift. I'll be going with a 3.5" soon as I intend on upping to 37s eventually.
and a 4-door on 35s with stock suspension does look awesome. Low and mean!
Grimscale is offline
post #12 of 16 Old 02-24-2015, 01:55 AM
OP, just for the record the 35" tires will fit with at 2.5" lift which also minimizes steering alignment and stress on joints but the 3-3.5" lifts will give it more room to articulate.
spinlock is offline
post #13 of 16 Old 02-24-2015, 11:04 AM
azoth99's Avatar
My last jeep I ran 35's with a 2.5" BB ran stock fenders and disconnected. It did great and didn't have any issues. I couldn't convince the wife to let me cut the fenders back then.
If money is tight read or look up the fender cutting video and trim them and run your 35's till you can get the lift you want.
2014 JKU Rubicon, 2007 Superbee #692/1000, BMC Hooligan (my chopper yea it's a Rigid)
"There is no limit to the amount of good you can do if you don't care who gets the credit."
- Ronald Reagan 40th President of the United States (1981-1989)
azoth99 is offline
post #14 of 16 Old 03-20-2015, 04:45 AM
Huh?
YoKev is offline
post #15 of 16 Old 03-20-2015, 05:09 AM
nlgrav182's Avatar
Could cause some chafing.
OKAY FUCKMOUTH.
nlgrav182 is offline
post #16 of 16 Old 03-20-2015, 06:05 AM
warcop's Avatar
Send a message via Yahoo to warcop
Quality 2.5 lifts are popular. Depending on the lift you can can run up to 37's with fender modifications. I personally run the RK 2.5 flex. This lift gives you options if you want to upgrade and go bigger later.
Warcop
2012 JKU Sport, Rock Krawler 2.5 Flex, Smittybilt SRC Side Armor, Mesh Grille MOD, Sony Double DIN AV Receiver, Back up Camera, Kicker Speaker Upgrade, ARB Twin Compressor, Dominion Off Road High Lift Mount, Homemade Paracord Grab Handles, Nitto Trail Grapplers, Paramount Rear Bumper with Tire Carrier, KC Hilites Daylighters, under seat lock box, Metal Cloak Front Bumper, BARTACT Seat Covers, BARTACT Sun Shade, x20 Comp Winch, sPOD, ARB Air lockers, 4.10 Gears.
warcop is offline
