37x12.5 or 37x13.5 - JKowners.com : Jeep Wrangler JK Forum
post #1 of 14 Old 02-15-2015, 06:49 PM Thread Starter
jtlr's Avatar
37x12.5 or 37x13.5
I'm upgrading my 35's time to move to 37's
Have the RK 1.5"(actual2.5) I'm looking at cooper STT in either 37x12.5 or 37x13.5 Currently have KMC addicts with 4.5" back spacing.
Will the 13.5" wide work?
2013 Sport
Stretched F+R
Coilovers F+R
Built and locked 44s F+R
40x13.5 Maxxis RAZR
Full skids
jtlr is offline
post #2 of 14 Old 02-19-2015, 01:31 AM
I don't think the Coopers are quite as wide as the Toyo's discussed here:
https://www.jkowners.com/forum/archiv...p/t-84116.html
spinlock is offline
post #3 of 14 Old 02-19-2015, 06:42 AM
TCdawg's Avatar
How wide is your wheel? 8" would be too narrow most likley.
also, the 4.5" bs won't cut it for the 13.5. I have a 1.5" spacer on my 4.5" bs wheels to get full clearance out of my 37x12.50's.
TC
TCdawg is offline
post #4 of 14 Old 02-19-2015, 07:17 AM
GRIZZLY47's Avatar
Feedback: 13 reviews
Interested in this as well, I went with 4" of backspacing on my trail ready beadlock. Looking to wrap them in 37x13.50 Toyos but don't have the coin for the tires just yet
2010 4-DOOR MOUNTAIN
GRIZZLY47 is offline
post #5 of 14 Old 02-19-2015, 07:19 AM
They will rub during articulation on the lower control arms and likely the frame. The 12.5" wide would be better for that wheel back spacing.
post #6 of 14 Old 02-19-2015, 07:22 AM
GRIZZLY47's Avatar
Unfortunately Toyo doesn't make a 12.5 in the 37 flavor for a 17in wheel
post #7 of 14 Old 02-19-2015, 09:30 AM
The Wheelin Man's Friend
RiverCityOffroad's Avatar
Feedback: 60 reviews
I can't speak for the Coopers, but the Toyos are very true to size in regard to width and sometimes underestimated. Their 13.50s are more like 14s.
I would stick with a 37/1250 on that 1.5" RK system OP.
Marcus
RiverCityOffroad is offline
post #8 of 14 Old 02-19-2015, 11:24 AM
TCdawg's Avatar
There are other tires that come 37x12.5...the sun doesn't rise and set on Toyo
TC
TCdawg is offline
post #9 of 14 Old 02-19-2015, 12:01 PM
GRIZZLY47's Avatar
I'm aware of that fact, my set of 35 Toyos have beyond impressed me with the situations I have put them in. They're very puncture resistant and the tread life has longevity. Just hate to change a winning formula
post #10 of 14 Old 02-19-2015, 05:28 PM Thread Starter
jtlr's Avatar
My wheels are 17x9
Was hoping the 13.5 would be good for some reason they are cheaper then the 12.5
2013 Sport
Stretched F+R
Coilovers F+R
40x13.5 Maxxis RAZR
Full skids
jtlr is offline
post #11 of 14 Old 02-19-2015, 05:29 PM
TCdawg's Avatar
Originally Posted by jtlr View Post
My wheels are 17x9
Run a 1.5" spacer and you'll be good. The 9" wheel works w the 13.5
TC
TCdawg is offline
post #12 of 14 Old 02-22-2015, 03:51 AM
I agree with the rim with but you might not need the full 1.5" spacer with the STTs. A 1" might do the trick and you can keep your scrub radius in line.
https://www.jkowners.com/forum/showthread.php?t=73472
spinlock is offline
post #13 of 14 Old 02-25-2015, 06:49 PM
I think it makes good sense to pick the tire you want based on traction, toughness, tread wear, or some other measure of performance, rather than whether it is a 12.50 or 13.50 width. Chose the tire you want, and then make it fit. An extra inch of width should be pretty easy to work with .
2017 Jeep Wrangler Rubicon Recon; 35s - no lift, Warn 9.5 XP-S, ARB Twin Air, SPOD
2017 Jeep Grand Cherokee Trailhawk (wife's Jeep)
2016 Ram Laramie 3500 Megacab 4x4; 6.7 CTD, Aisen, AEV Prospector conversion; 37s, 4.10s, Warn 16.5K
MOPWR2U is offline
post #14 of 14 Old 02-26-2015, 08:56 AM Thread Starter
jtlr's Avatar
Thanks for all the responses. Ordering the 13.5
Thanks again
2013 Sport
Stretched F+R
Coilovers F+R
40x13.5 Maxxis RAZR
Full skids
jtlr is offline
