is 3.2" too little of backspacing? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 01-28-2015, 04:39 PM Thread Starter
Im shopping for something that will push my tires out a little more and the only hub centric spacers I can find are 1.5" which will put me at 3.2" of backspacing...
For some reason I remember someone saying 3.5" is the lower limit, but I could be wrong.
mgrych is offline
post #2 of 6 Old 01-28-2015, 04:42 PM Thread Starter
Also,
Teraflex makes a 1.25" which would put me at 3.45" but it doesn't say whether its hub centric or not..
http://www.quadratec.com/products/92807_200.htm
Here is the URL, is that ring in the middle of the spacer in the picture the hub centric part?
mgrych is offline
post #3 of 6 Old 01-29-2015, 07:28 AM
The farther out you push the wheels the more stress you are going to put on the hubs, ball joints. That being said I would not be concerned at the numbers you are talking about.
post #4 of 6 Old 01-29-2015, 08:23 AM
KrawlOff-Road.com's Avatar
Feedback: 37 reviews
http://www.krawloff-road.com/product_p/sptx-1.5.htm
2 pair of those and you will be set. They are hub and lug centric.
What size tire and wheel are you running? 90% of setups will be fine with this spacer.
-Jason
Phone: 864-437-8029
KrawlOff-Road.com is offline
post #5 of 6 Old 01-29-2015, 08:44 AM Thread Starter
I will be running these in conjunction with 35x12x18 tires (which really measure 34.4" x 11.7" the wheels have 4.7" of backspacing
mgrych is offline
post #6 of 6 Old 01-29-2015, 10:09 AM
Maertz's Avatar
im running a 3.5 bs and no spacers front, but 2" spacers rear. But these are different axles. In the past i ran 4.5 backspacing on 1.5 spacer and 35s on factory axles also with no problems other than the shitty stock bjs and bending a stock axle shaft...
Maertz is offline
