Is wheel/tire weight the problem? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 01-28-2015, 09:49 AM Thread Starter
When considering the issues with upgrading to a larger tire size, what does the issue stem from? Is it the overall weight of upgrading, or the increased leverage on the components from the size?
mgrych is offline
post #2 of 7 Old 01-28-2015, 09:58 AM
Treader's Avatar
Increased leverage
2010 2 door manual sport
Treader is offline
post #3 of 7 Old 01-28-2015, 10:13 AM
nlgrav182's Avatar
Both. Force-moment, both components increase. You've installed a larger heavier tire that takes more force to start and stop. You've pushed the contact surface further away from the axle, so the distance is larger. Multiply to greater components together, (X*force)*(Y*distance) and you get a gear-shearing, pinion-disintegrating, axle-twisting situation.
OKAY FUCKMOUTH.
nlgrav182 is offline
post #4 of 7 Old 01-28-2015, 05:07 PM Thread Starter
Makes sense,
I want to do everything I can to increase my tire size with destroying the "sufficient" d30 on my sahara..
I'm lifted already so i'll keep it at 35" and buy light weight tires/rims..
I go wheeling now, but it's nothing crazy.. I'll have to beef it up some if I decide to kick it up a notch on the trails
mgrych is offline
post #5 of 7 Old 02-19-2015, 01:52 AM
It's everything because almost evertyhing increases:
- Mass
- Rotational Inertia
- Bending Moment
- Braking Load
The only thing that decreases is fuel economy.
It sounds like your not even pushing the limits of your 35s. You can roll 37s on a D30 but you have be mindful of what you do because the threshold for damage is lower.
spinlock is offline
post #6 of 7 Old 02-19-2015, 02:06 AM
CamoCop's Avatar
also depends on where you wheel and how you wheel. wheeling rocks is a lot tougher on your drivetrain than say trail riding or playing in the mud. each style of wheeling provides it's own problems to your drivetrain but the harder you are on the skinny pedal, the more likely you will break something.
2011 Wrangler Unlimited Rubicon
- 3.5" Rubicon Express lift /w 1.25" BL
- 5.38 Yukon gears
- 40" Pro Comp MT2's
- Lot's of extra's
CamoCop is offline
post #7 of 7 Old 02-25-2015, 07:45 PM
Depends how huge the difference would it be from the stock form. But it can also be solve easily which is also a part of upgrading parts.
lowender is offline
