alignment - degree to inches - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 12-11-2014, 07:11 AM Thread Starter
Send a message via Skype™ to jlagross
Some background -
i get my alignments at a local sears where i know the guys.
I run 315/70/17 MTZ's on 17 inch procomps
Now the point of this forum
They can only set alignment based on degrees, and since i run 315's i want my toe in set to 1/8 of an inch in.
Can anyone tell me what i should tell them so i get the proper alignment im looking for?
thank you
Jason LaGross
jlagross is offline
post #2 of 8 Old 12-11-2014, 09:24 AM
Have them set it to 0* equal both sides they you get out your tape and adjust it for whatever toe you want.
CT Performance, Inc is offline
post #3 of 8 Old 12-11-2014, 09:46 AM
0.19* is what I have mine set at with 35/12.5-17 and it drives perfect.
Jadmt is offline
post #4 of 8 Old 12-11-2014, 09:58 AM
The factory toe in should be 0.09* to 0.12*... so Jadmt is in the right direction... larger tire=more drag so you have to have more static toe-in to get to a dynamic toe-in of 0* going down the road.
jedgington is offline
post #5 of 8 Old 12-11-2014, 01:10 PM Thread Starter
ok so tell them to adjust to .019 degrees toe in correct?
jlagross is offline
post #6 of 8 Old 12-11-2014, 02:25 PM
for total toe in yes
Jadmt is offline
post #7 of 8 Old 12-11-2014, 07:50 PM
funfred's Avatar
Just an FYI, if I've done the rough math correctly, .19 of toe is .1125" on 17" wheels...about .006" short on each side for a full 1/8".
How exact does it have to be?
funfred is offline
post #8 of 8 Old 12-12-2014, 11:40 AM Thread Starter
well they will wear... thanks for the help though! i appreciate it guys
jlagross is offline
