Need help with tire sizing, wheels picked out - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 11-20-2014, 07:24 AM Thread Starter
I'm looking for a good set of snow tires to fit on a stock suspension 2014 jk unlimited. I'm pretty set on these 17x9 http://www.quadratec.com/products/92600_0009_07.htm
What is the largest tire I can fit on this 17x9 wheel with stock ride height? More of a daily driver than a crawler.
thanks, Mike
14jkaltitude is offline
post #2 of 5 Old 11-20-2014, 08:39 AM
A 9" wide wheel is too wide in my opinion for a stock height jeep especially if your looking for snow tires. I wouldn't want to put less than a 12.50 wide tire on a 9" wide wheel. A 12.50 wide tire is going to put you in the 33" tall range. With only 4.25" BS on a 9" wide wheel and a 33x12.50 or equivalent you will most likely/ may run into clearance issues with stock flares. Flat flares would eliminate the tire clearance issues though.
For stock height/ snow tire, I think a 285/70R17 on an 8" wide wheel with 4.5"-5" back spacing would be a better combination than a 33x12.50 on a 9" wheel with 4.25" backspacing.
-SLADE- is offline
post #3 of 5 Old 11-24-2014, 04:00 PM
Discount Tire's Avatar
thanks, Mike
Steel wheels are hit and miss in terms of fitting. They tend to hit the Jk brake calipers unless you do some grinding or install wheel spacers (neither are recommended by Discount Tire).
If you are looking for a budget winter wheel and tire package I'd recommend looking into a 16" wheel and tire package. 16" tires and wheels tend to be a little cheaper and if you purchase an alloy wheel they'll also be lighter weight and will fit without any issues.
With stock suspension and 16" wheels a 285/75R16 is a great size to consider, in 17" 285/70R17 is also a great size. Any larger than that and you'll need to install a leveling kit, mini lift or cut your fenders.
Stop by one of our local Discount Tire or America's Tire stores if you have one near you. If not, give us a ring at 1.888.459.4080. Anyone here would be happy to help you. We have some great Black Friday and Cyber Monday deals coming up as well so be sure to ask about them.
At The Store:
To Your Door:
Useful Links:
Discount Tire is offline
post #4 of 5 Old 11-24-2014, 04:04 PM
I have always used Discount Tire. They have ordered my Procomp wheels in the size and BS I needed. They have always price matched and given me great service. Nothing but good things to say about their business.
4x4x4 is offline
post #5 of 5 Old 11-24-2014, 04:08 PM
Thank you for your business and thank you for the kind words. We'll keep working hard for you.
At The Store:
To Your Door:
Useful Links:
