Max tire size - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 07-11-2014, 09:31 AM Thread Starter
jw
Max tire size
I have a 2012 Call of Duty that is completely stock from the factory.
What is the max size tire that I can put on the rims that came with it?
It currently has BF Goodrich Mud Terrains LT 255 / 75 R17's installed.
I would also like a tire that does not have a ton of drone while driving down the freeway...suggestions?
jw is offline
post #2 of 8 Old 07-11-2014, 12:08 PM
You can mount any size tire that fits a 17" rim.
post #3 of 8 Old 07-11-2014, 12:45 PM
Need more info. Any lift? Any trimming? Any wheel spacers to go with those stock wheels?
Terminator2 is offline
post #4 of 8 Old 07-12-2014, 01:21 PM
Discount Tire's Avatar
The max tire size you can run without having to make modifications or adding wheel spacers (not recommended) is 285/70R-17. Tire size 295/70R-17 may work as well depending on the tire model. Tires are just like shoes. Some brands run larger while others run smaller, even in the same size.
At The Store:
To Your Door:
Useful Links:
Discount Tire is offline
post #5 of 8 Old 07-12-2014, 02:27 PM
Slow and Low
Co4Lo's Avatar
Originally Posted by Discount Tire View Post
The max tire size you can run without having to make modifications or adding wheel spacers (not recommended) is 285/70R-17. Tire size 295/70R-17 should work as well.
So which is it? 285/70/17 or 295/70/17?
And why are wheel spacers not recommended?
Co4Lo is offline
post #6 of 8 Old 07-12-2014, 03:09 PM
The factory wheels (17x7.5 +45) mounted with 285/70R-17 tires should not rub. The factory wheels with 295/70R-17 tires however is semi aggressive and may rub (stress may) towards the inside depending on the tire model. Just like shoes, not all tire brands run the same size which is something to consider when pushing maximum fitments.
As far as spacers go, we feel proper fitting wheels are the better alternative to spacers. Spacers add a "link in the chain" so to speak that could potentially fail.
At The Store:
To Your Door:
Useful Links:
post #7 of 8 Old 08-15-2014, 10:03 AM
jkx
The factory wheels (17x7.5 +45) mounted with 285/70R-17 tires should not rub...
Will it not rub off-roading/crawling?
jkx is offline
post #8 of 8 Old 08-15-2014, 02:34 PM
You may occasionally have some tire rub while articulating off-road.
At The Store:
To Your Door:
Useful Links:
