37" help - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 03-14-2014, 11:00 AM Thread Starter
37" help
I searched for this and didn't find the specific question I have so...
I'm looking to eventually run 37"x12.5"x17" tires on my 2011 JKUR.
I'm looking at either XD Addict or ProComp 7005 wheels.
Can I run that tire size with a 4.5" or 4.75" backspace ok, or will I need to go with a 3.5" BS like the 13"+ tires need? (4.5"+1" spacer, etc.)
If it helps, I will be running a Rock Krawler 3.5" Flex system and flat fenders.
Thank you for your assistance.
Grimscale is offline
post #2 of 9 Old 03-14-2014, 04:25 PM
You don't want to run 1" spacers you need to go to a 1.5" adapter if you are going to run off road with a 4.5"+bs wheel.Look to net out to around 3". Your lift and fenders really don't have anything to do with it unless you are bump stopped so you don't have any up travel.
post #3 of 9 Old 03-17-2014, 02:14 PM
If those 37x12.50s run true to size (37x12.50 17 BFG KM2s are 35.5" tires) and you want to keep your full steering range you will need a net BS of about 3-3.25" to prevent frame rubbing at full turn and full stuff. 1.5" wheel spacers plus 4.5" BS wheels would work well.
Terminator2 is offline
post #4 of 9 Old 03-18-2014, 10:43 AM
White13JKUR's Avatar
I'm running 37" MTRs on stock 2013 rubi wheels with teraflex adapters so that's 6.25" on the factory wheel less the 1.25" of the teraflex adapters or 5" of back spacing. I am actually thinking about widening the track a bit more and going to either a 1.5" wheel spacer (probably the rugged ridge) or to procomp 7069s @ 4.5"
Running aev 4.5" lift and no rubbing durring daily driving or moderate playing at the local 4x4 park. No hard wheeling yet but similar setup was fine on hard core trails (3.5" lift with 35" tires).
Stock rock sliders hit at the extreme with 35s and are now off.
Have not had to adjust the steering stops at all since it left the factory.
Already have a January 13 build so have the trimmed punch seam from the factory.
White13JKUR is offline
post #5 of 9 Old 03-20-2014, 07:52 AM
With a 5" net BS and as much tire bubble as a 12.50 width tire has on a 7.5" wide wheel this seems crazy to me. I see people with 37s and a 4" BS rub paint off the frames when wheeling
post #6 of 9 Old 03-20-2014, 10:09 AM
jkx0778's Avatar
Last I checked the stock wheels had 5.5" backspacing. I'm going off 2007-2010 stock wheels. Haven't seen / measured 2013 wheels. So with 5.5" backspacing - 1.25" spacers = 4.25" backspacing.
Running 37x12.50r17 BFG KM1's (yes old school KM1's) on 17x8 steel wheels with 4" backspacing, I only barely rubbed the front of the anti-sway bar at full stuff and full turn. I run the teraflex QD that relocate the end links to the front body mount when stored/disconnected. I have not adjusted the stock steering stops.
________________
jkx0778 is offline
post #7 of 9 Old 03-21-2014, 05:34 PM
51%
I am running that tire on Pintlers. No spacer, no rubbing and I have not changed steering stops either. Suggest you look up the specs on that wheel.
And no, it's not a mall crawler either.
14 JKU 4-1/2 AEV Dualsport RS, 37" KM2 on Pintlers, PR44, 4.88, ARBs .... under construction
51% is offline
post #8 of 9 Old 03-21-2014, 08:11 PM
V8 dreams
jvandy50's Avatar
that size MTR/k and 3.5 BS wheels and i still hit the frame some. it is what it is
2010 Silver JKU
jvandy50 is offline
post #9 of 9 Old 03-21-2014, 09:47 PM
tehiv's Avatar
Grimscale, I'm on RK 3.5", Procomp 7005s, MTR/K 37x12.5x17 and Xenon flat flares... pretty much exactly what you're looking at.
I rubbed all the paint off the frame on the driver's side. Added 1.5" Spidertrax and it doesn't hit any more.
tehiv
'14 Copperhead JKUR
'14 White WK2 Overland
formerly: 98 TJ | 97 XJ | 05 TJ | 01 WJ | 07 JKU
tehiv is offline
