fuel d551 wheels - JKowners.com : Jeep Wrangler JK Forum
post #1 of 2 Old 03-06-2014, 06:13 PM Thread Starter
fuel d551 wheels
i am looking at Fuel's d551 wheel for my 2014 Amp'd 2dr Rubicon X. I will be doing a 2.5" lift with 35" Cooper STT tires. I really like the look of the d551 but i either want the 17x8.5 with 4.5 backspacing or the 18x10 with 4.5 backspacing. The cost diff between the 17" and 18" Cooper tires is really nothing so that does not come into play. Anyone running these wheels? Any thoughts? I like how the size of the 18" looks but i am not sure about running the 10" wide wheels. Seems like most aftermarket wheels are the 17x8.5" range. Would the smaller wheel be better for off roading bc the smaller width to air down tires or would the 18x10 wheel work same for the 35x12.50? Since i would not be going super low on air psi bc they are not beadlocks would the 10" width still hold the bead? Fuel said the weights of the wheels were ard 27 lbs for the 17" and 32 lbs for the 18" wheels. There is a 2lb diff between the two cooper stt tires. So total weight diff between the two combos would be around 7lbs per wheel with the 18". Which would lead to a small diff in performance on the highway.
QUIKSILVERZ is offline
post #2 of 2 Old 03-07-2014, 06:00 PM
having been working for discount tires for almost two years, i can say the best off road wheels youll find will come from fuel and KMC. i just sold a set of the Trophys youre talking about and its been all smiles on the customers end. he loves the look and you dont see it too often. i run 8 PSI on my stock 17's all day in the dunes and havent had a problem so far, so you should be ok on that end. go with the 17 and save your money, my customer put 285's on his trophys and saved a bunch over the 18
MI JeepSkate is offline
