Tire bead damage question - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 03-01-2014, 11:00 AM Thread Starter
gnarlyswine's Avatar
Picked up some used tires, closer inspection shows 2 have damage on the inside of the bead, not all the way through to the front of the bead. Each chunk is about 1.5 inch long
Does this type of damage make them pretty unsafe?
Is repair possible fir that kind of damage?
Would that be a big problem airing down?
The guy has offered a refund.
Unspoilt by progress.
gnarlyswine is offline
post #2 of 9 Old 03-01-2014, 11:18 AM
Tight_wad's Avatar
I have seen worse. Its not repairable any way that I have ever seen or heard. Not sure I would fully trust them to not slowly loose pressure. But they might. I'd probably take the refund. Or maybe a steep discount and run them on the back.
Autoguide, Seriously!
Tight_wad is offline
post #3 of 9 Old 03-01-2014, 11:30 AM
ronjenx's Avatar
Speaking from decades of dealing with tires as part of my job, I would condemn a tire for that damage.
ronjenx is offline
post #4 of 9 Old 03-01-2014, 02:29 PM
BumpInTheRoad's Avatar
Unless you're using them only for off-roading, take the refund.
I'm a JKO Reject
BumpInTheRoad is offline
post #5 of 9 Old 03-01-2014, 03:55 PM Thread Starter
Ok, thats pretty unanimous. Theyre going back. Thanks
post #6 of 9 Old 03-01-2014, 04:07 PM
tiltz's Avatar
My last set of Procomps did that. I only noticed when I lost a bead 2 years after I first bought them. Once I reset the bead, the tires continued to hold air fine.
I assume the damage occurred when the shop mounted them.
Sent from AutoGuide.com App
tiltz is offline
post #7 of 9 Old 03-02-2014, 12:24 PM Thread Starter
Couldnt say when it happened, I havent tried to mount them, im guessing when they came off the previous wheel.
post #8 of 9 Old 03-02-2014, 01:44 PM
My spare Toyo has a spot like that. Holds air fine. How much was the tire?
da20captain is offline
post #9 of 9 Old 03-07-2014, 06:05 PM
i wouldnt personally mount those. however ive had a lot worse come in. a lot of people dont know how to mount a 18 inch runflat tire correctly or even at all and a guy came in with on that was ripped a foot long section off of the bead and he never had a problem. he didnt even notice it until we put new tires on it.
MI JeepSkate is offline
