Backspacing help - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 02-20-2014, 02:14 PM Thread Starter
Backspacing help
I'm in dire need of some cheap, black, 17", non-fake-beadlock aluminum wheels.
Tires are going to be 37" MTR/k. Reid steering knuckles without modified steering stops. Rock Krawler LCA's. Factory sway bar.
What back spacing should I be looking for to avoid rubbing? Everything I've found on the cheap side is 4.5-4.75" backspacing, and I don't think that's going to work.
Also, if you know of any wheels that fit the criteria, post'em up.
Wangmuf is offline
post #2 of 4 Old 02-20-2014, 02:33 PM
3.0-3.5" max backspacing for full steering on true 37s like the MTRs normally. You will likely need wheel spacers on top of the wheels you find. Find a cheap 17x8.5-17x9 you like as most are a 4.0-4.5 BS (check discount tire they have 17s for the JK from $102 a wheel) and buy a set of 1.5-2.0" hub centric wheel centric spacers for $120-150.
Terminator2 is offline
post #3 of 4 Old 02-20-2014, 03:02 PM Thread Starter
If this is the case, I might as well just replace my steel 15" wheels that are trashed, and save some money on tires. I'm trying to get away from spacers.
Wangmuf is offline
post #4 of 4 Old 02-20-2014, 06:26 PM
It is very hard to find 17" wheels with less than a 4" backspace so if you want 37s and full steering you almost always need wheel spacers. You can have custom wheels made with whatever backspace you want but that is costly. Toyo makes 37s for 15" wheels if you want to run 15s.
