Is this considered powertrain?!? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 17 Old 05-10-2012, 10:03 AM Thread Starter
opustm's Avatar
(SORRY PICTURES ARE SO BIG) Hey guys while crawling under my rig to remove to twigs/small branches from my last run i saw this. I know it is the front drive shaft bushing (i am pretty sure at least) where it goes into the transmission. But i was wondering if that is part of the powertrain (and under my lifetime warranty). Anyone know and if not how hard is it to fix?
'08 4dr Red Rock Pearl3" lift, 35's, locked, sleeved+ gussetted, Iron bull front bumper, reverse solar charger, bumpin tunes
opustm is offline
post #2 of 17 Old 05-10-2012, 10:39 AM
Kissed the warranty on a driveshaft goodbye a long time ago when you put that 3" lift on it. Need a new driveshaft.
post #3 of 17 Old 05-10-2012, 11:47 AM Thread Starter
opustm's Avatar
do i need a whole shaft or can that part (is it the yoke or CV joint) be replaced...if i hadnt done a lift would it be covered? Or is it an external part so not covered regardless?
opustm is offline
post #4 of 17 Old 05-10-2012, 11:54 AM
It'd probably be covered without a lift, but its very likely it never would have failed without the lift as well. Someone may sell a service joint, but through MOPAR it's all one unit.
post #5 of 17 Old 05-10-2012, 11:59 AM
ronjenx's Avatar
I'm pretty sure you have to replace the whole drive shaft. There is no parts support for it.
It is part of the drive train, and would be covered under normal circumstances.
Yours probably won't be covered. It won't hurt to ask. Just let them look at the drive shaft, and don't mention the lift.
If you install another drive shaft just like it, the same thing will happen again.
Looks like it's time for an aftermarket drive shaft. There are lots of threads on the subject.
ronjenx is online now
post #6 of 17 Old 05-10-2012, 01:30 PM
axsys's Avatar
I'm sure someone around town will have a spare for you. I just gave mine to Ben a couple weeks ago.
axsys is offline
post #7 of 17 Old 05-10-2012, 01:59 PM Thread Starter
opustm's Avatar
I'm going to swing by camp and see what he has...i am hoping he has the shafts from the Kraken laying around. How hard are they to put in?
opustm is offline
post #8 of 17 Old 05-10-2012, 02:02 PM
There's a dude selling a stock drive shaft from JKO out in Cali. Might work out for you.
https://www.jkowners.com/forum/showthread.php?t=72295
Dancin Dan is offline
post #9 of 17 Old 05-10-2012, 02:10 PM
PhrogMech46's Avatar
Your stock driveshaft will last for quite a while with that torn boot.
Driveshafts are super easy to install
See Garage for Mods
PhrogMech46 is offline
post #10 of 17 Old 05-11-2012, 02:58 PM
10jk's Avatar
Carry a wrench that fits the front drive shaft bolts that bolt to the front axle. Disconnect front drive shaft, tie it up, bolt it up and use it only when you go wheeling, will last for years using it like that. Really,,,, do you need that drive shaft while your buzzing up and down the highway? I didn't think so.
2010 JKUR, 4" Pro C., 3/4" f Daystar spacer, 5.38's, EVO sleeve/gusset/custom trussed, Rear Ten Factory axle shafts, 1.5" wheel spacers, Pro C. 17 x 9 wheels, 38 x 14.50 x 17 MTR's, SuperChip FP, no fenders, B&M Tranny cooler, Magnaflow, Fr./ Rr. frame hacked off, HD Balls
29,000 miles as of 12/13/14
10jk is offline
post #11 of 17 Old 05-11-2012, 03:12 PM
KevinJBurt's Avatar
Send a message via Yahoo to KevinJBurt
Mine was covered and I have a 3 inch lift!! Hope this helps ya!
Just looked at my receipt I have a 2.5 lift on the rear and it was my rear drive shafts that broke!! Sorry didn't mean to get your hopes up... But if I were you I'd give it a try!! All they could say is NO...
Always forward never straight sometimes upside-down!
KevinJBurt is offline
post #12 of 17 Old 05-11-2012, 03:27 PM
As affordable as some of the aftermarket shafts are, I'd just upgrade it to a good aftermarket. I got my Adams driveshaft from Stomper Offroad for $325 shipped. Pretty reasonable in the long run.
JeffTN is offline
post #13 of 17 Old 05-12-2012, 09:08 PM
dougnpj's Avatar
I will be in surprise in 2 weeks and I have a spare front if you need it.
Nothing to say at this time.
dougnpj is offline
post #14 of 17 Old 05-14-2012, 12:30 PM Thread Starter
opustm's Avatar
Thank you for the offer!!!...i just left the dealership and it is considered powertrain and they are going to replace it under warranty later this week.
opustm is offline
post #15 of 17 Old 05-14-2012, 12:57 PM
HeloJeff's Avatar
Thats cool that they are covering it, what dealership?
HeloJeff is offline
post #16 of 17 Old 05-14-2012, 02:31 PM Thread Starter
opustm's Avatar
yes....It's the deaership i bought if from....they did the 2 motor swaps and the multiple clutches....i took it showed them the picture, they talked to the head of the shop and he said it was considered powertrain and under the lifetime warranty.
opustm is offline
post #17 of 17 Old 05-14-2012, 04:13 PM
HeloJeff's Avatar
Was just curious about what dealership it was?
HeloJeff is offline
