Got a CEL - JKowners.com : Jeep Wrangler JK Forum
post #1 of 15 Old 12-17-2011, 04:08 PM Thread Starter
Daniel_M's Avatar
Got a CEL
Anyone have anything that can tell me what it is? Can a superchips diagnose what the code is?
-Dan
2008 JK X: Sold
Daniel_M is offline
post #2 of 15 Old 12-17-2011, 04:10 PM
svtmaniac's Avatar
-Dan
Any Autozone will scan it for free and tell you what the code is. Then just post it up here and we can help you out.
You can live in your Jeep, but you can't off-road your house.
______________________________
2009 JK Rubiclone
6 Speed
svtmaniac is offline
post #3 of 15 Old 12-17-2011, 05:54 PM
axsys's Avatar
If you have a Superchips tuned to your Jeep it will tell you. However, it won't work if you use a Superchips linked to someone else's Jeep.
Or you can go to Autozone for free.
axsys is offline
post #4 of 15 Old 12-17-2011, 06:35 PM
owtdorz's Avatar
'08
My guess without a code is:
Gas cap or nvld.
Get factory if it is either one of those.
PM me if you need anything.
'09 4dr Rubi Detonator Yellow
3.5 Mid arm Rock Krawler
Finally 5.13s
owtdorz is offline
post #5 of 15 Old 12-19-2011, 04:31 PM Thread Starter
Daniel_M's Avatar
So got it checked at Auto Zone. Said EVAP small leak detected. Tried re-tightening the fuel cap, no luck.
-Dan
2008 JK X: Sold
Daniel_M is offline
post #6 of 15 Old 12-19-2011, 04:47 PM
11bravojk's Avatar
try disconecting the battery and hooking it back up.
11bravojk is offline
post #7 of 15 Old 12-19-2011, 05:57 PM
axsys's Avatar
Did you go offroading lately and maybe hit the can?
axsys is offline
post #8 of 15 Old 12-19-2011, 05:59 PM
-Dan
How long has it been since you tightened it? It's not an immediate fix, if the code was not cleared it can take several days to check and clear itself.
post #9 of 15 Old 12-19-2011, 06:45 PM
HOOLIGAN's Avatar
I think loose cap will show "gas cap" in the odo.
HOOLIGAN is offline
post #10 of 15 Old 12-19-2011, 07:03 PM Thread Starter
Daniel_M's Avatar
Went on the asfir event but CEL didn't come on until last Friday.
Just today. It runs vaccum tests randomly?
On the diagnostic reciept Auto Zone printed says: Defective/loose/missing fuel cap, evaporate canister broke/hose cracked/not connected, purge or vent solenoid defective, vacuum leak at engine
-Dan
2008 JK X: Sold
Daniel_M is offline
post #11 of 15 Old 12-19-2011, 07:10 PM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
The CEL description you're getting from the VatoZone code scanner is a generic P code that has been attached to an even more generic description on the Bear machine they're using so the counter guy can make sense of it.
The evaporative system on most OBDII vehicles has the most involved monitor cycle out of any of the systems on board. It takes several full trip cycles (key on, ignition, drive, stop, key off) to reset that monitor CEL. I would pull the negative and positive cables for approx. five minutes and take a few round trip drives before getting worried.
Also, check your evap canister for obvious damage or cracks. You did do the "sit and spin" several times two weekends ago and you may have walked onto something in the ruts without knowing it and damaged it.
JKCTAZ is offline
post #12 of 15 Old 12-19-2011, 07:50 PM
-Dan
Yes, evaporative emissions tests..when the vehicle is off at certain intervals.
post #13 of 15 Old 12-19-2011, 08:00 PM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
Oh, and by the way, if it continues or comes back I have a CanBus compliant code scanner that I can use to help narrow down the issue. I still need to get with you for the Midland CB as well, maybe a two for one trip...
JKCTAZ is offline
post #14 of 15 Old 12-20-2011, 06:28 AM Thread Starter
Daniel_M's Avatar
Coo, just let me know
-Dan
2008 JK X: Sold
Daniel_M is offline
post #15 of 15 Old 12-23-2011, 07:00 AM Thread Starter
Daniel_M's Avatar
CEL has disappeared. Could have been the gas cap thing. About 3 days after I tightened it.
-Dan
2008 JK X: Sold
Daniel_M is offline
