Rubicon T Case Exploded on the 202 Pics - JKowners.com : Jeep Wrangler JK Forum
post #1 of 47 Old 10-16-2011, 08:27 PM Thread Starter
11bravojk's Avatar
So I put a post in the BS thread but I wanted to post some pics and see if anyone else has this issue. I talked to Joe Darro and he said he has seen 6 others.
Attachment 42276
Attachment 42277
Attachment 42278
Attachment 42279
11bravojk is offline
post #2 of 47 Old 10-16-2011, 08:31 PM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
Somewhere on this forum I saw a thread where someone had that happen. Any idea what caused it? That's outrageous. By the way, the pictures are HUGE! So it's hard to make out the carnage.
JKCTAZ is offline
post #3 of 47 Old 10-16-2011, 08:35 PM Thread Starter
11bravojk's Avatar
Joe is thinking that the pump broke off and was just spinning on the shaft. Sorry about the sizeof the pics i am not that good with this computer stuff.
post #4 of 47 Old 10-16-2011, 08:36 PM
Lift? Tires? Regeared? Speed?
Sent via paper airplane
post #5 of 47 Old 10-16-2011, 08:36 PM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
Are you still under warranty or is this going to be out of pocket?
JKCTAZ is offline
post #6 of 47 Old 10-16-2011, 08:37 PM
ronjenx's Avatar
Can't tell from the pics; is it the front or the rear of the t-case?
ronjenx is offline
post #7 of 47 Old 10-16-2011, 08:46 PM Thread Starter
11bravojk's Avatar
Front
post #8 of 47 Old 10-16-2011, 08:52 PM
ronjenx's Avatar
Originally Posted by 11bravojk View Post
Front
Thought so.
How much of the following is true?
Lifted
Regeared
Double cardin aftermarket front drive shaft
Front driveshaft/pinion angle greater than a few degrees
Highway speed
Some vibration most of the time, then a lot just before failure
ronjenx is offline
post #9 of 47 Old 10-16-2011, 08:58 PM
Originally Posted by ronjenx View Post
Thought so.
Lifted
Regeared
Highway speed
Seems to be the typical recipe for this.
post #10 of 47 Old 10-16-2011, 09:02 PM
ronjenx's Avatar
I forgot one item.
The distance the double cardan is from the t-case.
There are two methods that I know of. One is shorter than the other.
I'm not sure of the names of them, though. Can you help me out?
ronjenx is offline
post #11 of 47 Old 10-16-2011, 09:31 PM Thread Starter
11bravojk's Avatar
Double cardan, reel drive shaft, 513 gears, little vibration, then ticking at 75 and boom, oh yeah 2dr 4 inch lift
post #12 of 47 Old 10-16-2011, 09:37 PM
Djstorm100's Avatar
No control arms? What was the pinion angle/caster?
Maker of Black box, In-cab winch control and other electronics
Want to make wiring easy and painless?
Order your "Black Box" today!!
Djstorm100 is offline
post #13 of 47 Old 10-16-2011, 09:40 PM
racinfast002's Avatar
rockinrubi on here had the same thing happen to his.
Justin
2009 Sahara Unlimited-The Saharacon
Just hanging out in the land of the banned
racinfast002 is offline
post #14 of 47 Old 10-16-2011, 09:44 PM
ronjenx's Avatar
Sounds like the normal recipe for disaster. Especially if the angle of the front driveshaft to the pinion was more than a very few degrees.
The double cardan depends on a near zero angle on the front u-joint. Otherwise, the double cardan will vibrate more than the t-case casting can take.
Was your double cardan close to the t-case, or was it the longer distance of the two options? The longer distance will make the problem even worse.
ronjenx is offline
post #15 of 47 Old 10-16-2011, 10:49 PM
axsys's Avatar
I wonder if this is happening on just on the Rubicons? Because the few I have heard of were all Rubi cases.
axsys is offline
post #16 of 47 Old 10-16-2011, 11:36 PM
toymaster's Avatar
I resized the pics for you.
As mention this is a fairly common problem and comes from quality of driveshaft and DS angle (lift height and pinion angle). The newer lighter aluminum case cannot stand up to vibration. The fix is to have a balanced shaft and adjusted pinion angle to reduce vibrations. If you can feel vibrations you better act quick becuase the light weight case will break apart.
To answer axsys this problem is not limited to the rubi's.
JK 2dr rubi
toymaster is offline
post #17 of 47 Old 10-17-2011, 12:40 AM
-T-
-T-'s Avatar
This does not make me feel good at all.
I laugh, I smile, I bounce..............JEEP
-T- is offline
post #18 of 47 Old 10-17-2011, 04:53 AM
Sorry to hear this and it scares the heck out of me, I need a new ds but can't decide on which one and what options to get. Right now I have the stock shaft pulled. I have the money but I have been scared to death of this happening to me so I haven't ordered one.
2008 JK 4Dr Rubicon
Stone white
Mygig W/Uconnect working.
Hard top/Auto tranny
First mod, dog slobber.
Painted hard top
Spidertraxx 1.5 spacers
Teraflex 3" lift
rob4607 is offline
post #19 of 47 Old 10-17-2011, 07:06 AM
Chuck Bullitt's Avatar
Installed a new front driveshaft (Tatton 1310) a couple of weeks ago and noticed a driveline vibration instantly. Vibration got progressively worse and I noticed I could move the driveshaft up and down and the movement was in the double cardan joint. I'm replacing the joint today and re-installing the driveshaft tonight. Will double check my pinion/driveshaft angle also, but I'm pretty sure I had it under 5 degrees. 3.5" lift and 4.88's on my rig BTW.
Chuck
2009 JK Unlimited X, mostly stock with a K&N filter.
Chuck Bullitt is offline
post #20 of 47 Old 10-17-2011, 07:09 AM
Djstorm100's Avatar
Your caster or Pinion angle?
How much caster/pinion angle should there be for a 3 inch lift? Mine is 5 right now (caster) and drives fine. I know less caster = better pinion angle.
post #21 of 47 Old 10-17-2011, 07:10 AM
Dr.Dirty's Avatar
Feedback: 21 reviews
Those crappy DS adapters dont help either....
You need to dial you front end in to prevent this and get some shafts that have full replacement yokes... Most of these that have done this were running Reel DS with those shitty adapters
Dr.Dirty is offline
post #22 of 47 Old 10-17-2011, 07:20 AM
Pinion. Not sure on caster right now...but it drives ok.
I think mine is the joint itself. I wish I took a vid of it, but there was a lot of movement in that joint...maybe just a bad joint from the beginning. There was easily 1/8th inch of up and down play on the driveshaft at the joint.
Also, mine has replacement yolks.
Chuck
post #23 of 47 Old 10-17-2011, 07:21 AM
Dr.Dirty's Avatar
bad angles will kill a cardon joint quick...... they need to be maintained frequently
Dr.Dirty is offline
post #24 of 47 Old 10-17-2011, 07:27 AM
Learning quickly! Luckily, not the hard way. I'll recheck those angles once I put it back on.
Chuck
post #25 of 47 Old 10-17-2011, 07:35 AM
Djstorm100's Avatar
I've read that teraflex for the 3 inch kit said having 6-8 degrees were ok (caster) so I simply put mine at 5 (caster) (to give better angle for the P/A)
I have the stock drive shaft though. I'm nervous about going with a double jardon as I don't have no vibrations right now.
