SOFT TOP WINDOW FAIL - UGH - JKowners.com : Jeep Wrangler JK Forum
post #1 of 21 Old 04-16-2012, 11:26 AM Thread Starter
JerseyDevil's Avatar
Hey all! Any suggestions how to keep the side soft windows from practically flying out? I tried shimmying the whole thing down, but it keeps popping out of the slot that butts up agains the back end of the rear pass door (See pic). It only gets worse on the highway. Was thinking of gluing velcro down the strip? Did I overlook something really obvious?
Thanks in advance.
JerseyDevil is offline
post #2 of 21 Old 04-16-2012, 11:29 AM
ripnhl2005's Avatar
Thanks in advance.
If it's pressed into the indent inside door surround I cant see how it can peel itself out....
ripnhl2005 is offline
post #3 of 21 Old 04-16-2012, 11:30 AM
You need to rotate the forward end 90* and lock it into the door surround. Pretty common newb mistake.
Gluing? Velco? Installing it properly outta do just fine!
post #4 of 21 Old 04-16-2012, 11:38 AM
el_campede's Avatar
What he said.
I started with a hard top, but made the same error when I got the soft. I even went the velcro route. Does not work.
The hard plastic "L" shaped end bends into the channel on the door surround. It will zipper tight when everything is in its' place.
2007 Wrangler 2dr X
el_campede is offline
post #5 of 21 Old 04-16-2012, 11:41 AM Thread Starter
I know, right? I don't know, I got it used. Just going to wait til a meetup and see if anyone has any thoughts other than
post #6 of 21 Old 04-16-2012, 11:46 AM Thread Starter
Originally Posted by el_campede View Post
What he said.
Yeah, the L lays in the channel perfectly until I get out on the road, then it starts flapping. Rotated it 90 degrees and saw no solution. just read the manual too. Me to windows =
post #7 of 21 Old 04-16-2012, 11:49 AM
kindred359's Avatar
I don't know how far from hammonton you are but I'd be happy to meet up tonight to help out. I get off work in pomona at five. Let me know.
~ Dave G. ~
Jersey
Crew
Originally Posted by unsub View Post
I'll see you in hell with the rest of the Crew.
kindred359 is offline
post #8 of 21 Old 04-16-2012, 11:50 AM
artayay's Avatar
Here's what I typically do:
with whole window removed..
Open door..start zipper about 3-4 inches, then from top of door surround..
insert hard part of window into top of channel (can only be seen with door open)..
work hard part of window into channel all the way down.. pivot plastic flap at bottom of window down, to get under bottom of door surround..
start from fron to back, working plastic flap under metal trim where hard top would usually go..
Fully zipper window in place and work upper part of window back under the top, velcro window under top. repeat on other side..
a.k.a. Christian - 2011 Black Jeep Wrangler JKU Rubicon
37" MTRK, RK 3.5 X-Factor (3-Link Rear) and other stuff..
Owner/Manager -
and other Web Properties
artayay is offline
post #9 of 21 Old 04-16-2012, 12:00 PM
nlgrav182's Avatar
It's the same as the soft top channel tabs. Artayay sounds like he's got it right. A picture will really do the job.
OKAY FUCKMOUTH.
nlgrav182 is offline
post #10 of 21 Old 04-16-2012, 12:01 PM Thread Starter
STAND UP OFFER!!! I totally appreciate the gesture. The weather is awesome though - just taking it off. Can revisit on the 28th? Night class or else I would head to Hammonton. Only 20 mins from Marlton. Thanks!!!
post #11 of 21 Old 04-16-2012, 12:07 PM Thread Starter
Attachment 50178 here's the thing peeled back...
Probably sent while fueling up (again) at Wawa.
post #12 of 21 Old 04-16-2012, 12:08 PM Thread Starter
Attachment 50179 all zippered up re Christian's directions. Still did it, but thanks for the awesome write up!
post #13 of 21 Old 04-16-2012, 12:17 PM Thread Starter
Attachment 50180the winner was Dave with the "u" mention. I was thinking L. Thanks everyone. You guys rock!
post #14 of 21 Old 04-16-2012, 12:22 PM
kindred359's Avatar
Good stuff, glad I could help.
Now get that top down, it's 85 degrees!
~ Dave G. ~
Jersey
Crew
post #15 of 21 Old 04-16-2012, 12:24 PM
artayay's Avatar
Looks like you got it.
Sent from my DROIDX using Tapatalk 2
Owner/Manager -
artayay is offline
post #16 of 21 Old 04-16-2012, 12:27 PM Thread Starter
Will do!!! Once I re-read everything, seems so obvious. Next on me. Velcro and Crazy glue going back to Voorhees Lowe's!
post #17 of 21 Old 04-16-2012, 01:31 PM
Victim Of Pain's Avatar
Was always wondering why I occasionally see people driving with their windows flapping like that...
Victim Of Pain is offline
post #18 of 21 Old 04-16-2012, 01:56 PM
LOL - my neighbor across the street STILL has this problem. Gonna leave a link to this thread on the back of a JKO JC card tonight.
Dancin Dan is offline
post #19 of 21 Old 04-16-2012, 01:58 PM Thread Starter
Yeap, that would have been me!
post #20 of 21 Old 04-16-2012, 02:01 PM
Hope she's cute...
post #21 of 21 Old 04-14-2019, 09:37 AM
Thom Keith's Avatar
Don't suppose anybody has the pics that went with this thread. I've got the issue of the top of the window popping out on the passenger's side (Rampage Trailview). Their solution was a rubber mallet to seat the U (tried to explain that it wasn't an issue with seating properly, it pops out after seating -- their solution was to send a new roof that does the same thing). Used the rubber mallet, still pops free. Not a novice -- been running soft top Jeeps for 20 years.
Thom Keith is offline
