JKU and JK Towing - JKowners.com : Jeep Wrangler JK Forum
post #1 of 19 Old 05-30-2012, 07:22 PM Thread Starter
BUTLER's Avatar
JKU and JK Towing
Have you guys ever pulled anything with your JK's? I am looking at buying a pop up camper and need some input because I have not seen a lot of JKU pulling anything. I just was wondering what you guys think or your thoughts were on towing with the JKU or JK
JKU Rubicon rollin on a Rock Krawler X-factor lift, Full custom 8 point cage tied into frame, Artec full armor truss kit, AEV Beadlocks with 37" KM2's, 5.38 gearing, Smuggler rear bumper, Bushwacker flat fender flairs, Rock sliders and heated Katzkin leather
BUTLER is offline
post #2 of 19 Old 05-30-2012, 08:30 PM
Apt
I Put the FU in FUN
Apt's Avatar
BigChris has a popup camper that went on it's maiden voyage a few weeks ago. IIRC, it went fine with 33's and 3.73's on an auto. I've pulled 2800 lbs on my utility trailer 300 miles on same setup before my 37's. It pulled like a champ. It did not like doing 75mph, but 60mph was quite alright.
Apt is offline
post #3 of 19 Old 05-30-2012, 08:56 PM
jeeperjkjeeper's Avatar
i've been pulling a 10ft pop-up for the past 3 years with no problems on the stock rubi set up.....i recently upgraded to a 2.5" lift and 35's and have only pulled the trailer once to get it out of storage and it seemed fine...i am sure with it fully loaded with wood, bikes etc i will feel the strain a little. I have a manual Rubi so it is tolerable.
jeeperjkjeeper is offline
post #4 of 19 Old 05-31-2012, 07:28 AM Thread Starter
BUTLER's Avatar
Sweet, I figured it would be fine but I wanted some input. I am looking at 12' pop up's with A/C and I bet they are around 2200-2500lbs
BUTLER is offline
post #5 of 19 Old 05-31-2012, 08:33 AM
quaylefarmer's Avatar
Hi Chris.
I would pay as much attention to tongue weight as I would total trailer weight.
I loaded the Jeep down with a full bed + a hitch mounted carrier box for Silver Lake this weekend.
It was squatted to the air bumps and rode smooth as butter............
Once I was on the highway it was total sketch-fest.
I have driven, hauled, towed all kinds of things in the past. This was by far my worst experience.
Taking the weight off the front axle made for white knuckles and lane drifting for 240 miles
My setup = 3" Tera springs, 37's @ 30 psi, F/R Anti-Rocks, ACE rear bumper and tire carrier
[IMG][/IMG]
Build Thread:
ACE Engineering
586-806-6641
[B]
quaylefarmer is offline
post #6 of 19 Old 05-31-2012, 12:48 PM
EMG006's Avatar
I pulled a Uhaul from CO to AL to MI, the largest enclosed trailer one, loaded up. It did great. Stopping distance was affected. I think the trailer was loaded a little over the tow rating on the way from AL to MI. Not on purpose, just didnt take into account the stuff we would buy in AL.
I drove carefully, 60-65 MPGs, 33s and 3.73s CO to AL, then 4.88s AL to MI.
EMG006 is offline
post #7 of 19 Old 05-31-2012, 01:27 PM Thread Starter
BUTLER's Avatar
Originally Posted by quaylefarmer View Post
Hi Chris.
[IMG][/IMG]
If you had the spare that you loaned me on the back it would have been fine (joke) Hmmmm
I am going to borrow a buddy's pop up this week and pull it around to see what it is like before I spend money. I can pull what ever I buy with my 2500HD but I want the option of using the Jeep every once in awhile.
EMG, I cant drive careful thats just not possible
BUTLER is offline
post #8 of 19 Old 05-31-2012, 05:59 PM
BIGCHRIS's Avatar
Arlin's got me in on this one, our camper is a14' starcraft loaded it well be around 3000lbs, mines an auto so I put a trans cooler on it and we going with a superchip next run up to near Toronto in a couple of weeks, it also dropped down to 14mpg that hurt a bit but the Jeep pulled no problem. I'll get some pictures of the set up when I get up to Collingwood.
that should buff out
BIGCHRIS is offline
post #9 of 19 Old 06-11-2012, 08:50 PM Thread Starter
BUTLER's Avatar
The Jeep pulls good, I bought this so its going to pulling this pop up to silver lake in two weeks
BUTLER is offline
post #10 of 19 Old 06-11-2012, 09:14 PM
PhrogMech46's Avatar
My pop up is 1500lbs and it pull well in general. Long steep hills kick my ass and I've had to go as slow as 40mph in order to not stay at 5k rpm. I have 5.38's, 37's, Teraflex brakes, and a brake controller.
See Garage for Mods
PhrogMech46 is offline
post #11 of 19 Old 06-11-2012, 09:21 PM Thread Starter
BUTLER's Avatar
I am installing a brake controller tomorrow just to be safe. The trailer weighs 2K. 5K RPM, wow nothing like a vison of the old castrol oil comercial
BUTLER is offline
post #12 of 19 Old 06-11-2012, 09:24 PM
Yea it kept bleeping up and I would have to immediately let off the gas so it would shift back up. I only run into this problem going east on the I8, the hills there are very steep for several miles. I would say with my set up 2k would be the max I would feel comfortable towing, not for stability issues but lack of power.
See Garage for Mods
post #13 of 19 Old 06-12-2012, 04:05 AM
I think the tongue weight gets Jeep owners in trouble more than the overall weight. I've seen a 2-door JK pull a cabin cruiser out of the water but that doesn't mean they planned to tow it on the highway. Even an Unltd is a rather short wheelbase compared to something like an extended cab pickup truck so the tongue weight can exert more leverage to take the weight off the front wheels and make the steering feel flighty. Also, unless you install an aftermarket suspension that specifically claims to increase the load rating, stock suspension or a lift kit usually rate at only a half ton which is passengers, cargo and towing tongue weight. Put a couple of bodies and some luggage in the cabin and pretty soon there's no headroom for the trailer weight at all.
As far as I can tell, the only thing significantly different on a JK with a factory towing package is the transmission cooler and given that Jeep's had a TSB on transmission overheats I would say a transmission cooler is mandatory if you're planning to tow anything.
jake_blue is offline
post #14 of 19 Old 06-12-2012, 03:53 PM
Jeeps & Guns's Avatar
[QUOTE=BUTLER;1191655]The Jeep pulls good, I bought this so its going to pulling this pop up to silver lake in two weeks
Looks good
Jeeps & Guns is offline
post #15 of 19 Old 06-21-2012, 12:05 PM Thread Starter
BUTLER's Avatar
Almost to silver lake pulling at 65 MPH getting 14.1 MPG according to the dash. Pulls good and core and jeep are packed full. Not a good as my truck for ride but still impressed
BUTLER is offline
post #16 of 19 Old 06-22-2012, 09:56 AM
JeepDad's Avatar
I don't know how you are going to get bigger tires on that thing.
JeepDad is offline
post #17 of 19 Old 06-26-2012, 10:57 AM
jctnt1's Avatar
I pulled my 16ft run-a-bout boat with my JKU for a couple years on stock springs and then on mods. Auto tranny did fine as long as I kept OD off. Note: I never drove too far with boat, lake is 5 miles from home.
I, 3 times pulled my mid frame tractor to hunting camp (1 hr) away to brush hog. That was always fun, pulling maybe 5,500lbs. It handled it, but I was pushing limits.
08 JKU Detonator Yellow on 37's, ProRocked and Rock Jocked
OIIIIIIIO
jctnt1 is offline
post #18 of 19 Old 07-31-2012, 09:13 PM
Livin Lite Quicksilver 10.0 pop-up, less than 1100#s dry pulls easy
Lund 16' with a 40H Mariner + stuff in the boat, I am guessing the whole load around 2k+ #s
liv2ryde is offline
post #19 of 19 Old 07-31-2012, 09:52 PM
Works fine for me. 35s. 3.73 1800lbs. Auto trans cooler.
4x4x4 is offline
