HELP!! cant finish lift - JKowners.com : Jeep Wrangler JK Forum
post #1 of 26 Old 06-10-2010, 12:46 PM Thread Starter
we have started putting on the lift on my jk. its the rock krawler 3.5 with skyjacker shocks.
the front (minus the sway bars and track bar) is on.
the rear we cant do.
we took the shocks and sway bar links off. the axle wont lower enough to let the springs out. does anyone have any suggestions on how to get them out? (spring compressors)?
ms5490renegade is offline
post #2 of 26 Old 06-10-2010, 12:56 PM
Did you undo the rear trac bar? Undo the e-brake cable from the bottom of the body?
08 Silver Rubicon
3" springs, shoxs, fuca's, adj f tracbar, SS brake lines, drag link flip and brace, steering stabilizer, 9.5Ti, frt bumper
COHighlife is offline
post #3 of 26 Old 06-10-2010, 12:58 PM
Also watch the brake lines for stretch, and the abs lines.
08 Silver Rubicon
post #4 of 26 Old 06-10-2010, 01:08 PM
alt_phil's Avatar
Unbolt the rear trac bar, any cables... see if that will drop it enough. If not, then go hit up an auto parts store for some cheapo spring compressors.
Personally? I use a pry bar and muscle 'em in and out.
alt_phil is offline
post #5 of 26 Old 06-10-2010, 01:35 PM
paramaniac's Avatar
I echo what the others have said, take off the track bar, watch the abs lines and if you really need that last couple inches just have a helper stand on the end of the axle.
It's so easy even a caveman can do it
paramaniac is offline
post #6 of 26 Old 06-10-2010, 01:37 PM
IndianaJeep's Avatar
agree with others: remove track bar, unbolt the emergency brake cable from tub (above the Evap canister), then loosen (but do NOT remove bolts) to upper and lower control arms to help also.
you should not need spring compressor if this is all done
IndianaJeep is offline
post #7 of 26 Old 06-10-2010, 01:46 PM
paramaniac's Avatar
Good looking out Indiana... Forgot about that e-brake cable!
post #8 of 26 Old 06-10-2010, 01:54 PM Thread Starter
thanks. the track bar has to come off anyway.
i really appreciate the advice.
post #9 of 26 Old 06-10-2010, 01:59 PM
i think others before me mentioned brake cables to watch out too
NOTES: I ended up just leaving the E-brake cables un-mounted back to tub because at full droop they were stretched to the max and leaving them unbolted back up to the tub doesn't seem to be any issues and gives that extra length needed. TF kit came with rear brake brake line extensions so no problems there.
I also picked up some 7/16" ( i think is the size) PVC tubing and a matching sized plastic Splicer (total $3) to lengthen the Axle Breather Tube (since that pops off at full droop too if it's not lengthened)
post #10 of 26 Old 06-10-2010, 07:33 PM Thread Starter
we got the springs in and rear track bar bracket in.
now we just need the front track bar and the rear shocks and the swaybar links.
quick question, whats the easiest way to get the top shock bolts out?
and how do i get the swaybars off?
post #11 of 26 Old 06-10-2010, 09:06 PM Thread Starter
we still need to do the rear shocks
post #12 of 26 Old 06-10-2010, 09:13 PM
TheBeatenPath's Avatar
when i was installing my bb i slipped a crescent wrench on top of the bolt in between the frame and tub.
then on the other side i just held the ratchet in place because i didnt have room to turn it there. then use teh crescent wrench to loosen them. it takes a couple minutes unless you have one of the fancy gear wrenches things but thats how i did it
it will look good you may need a new driveshafts soon tho just a forewarning
TheBeatenPath is offline
post #13 of 26 Old 06-10-2010, 10:23 PM Thread Starter
lol thanks.
i'll give it a shot. i cant wait to get this finished and get back to enjoying my jeep
post #14 of 26 Old 06-11-2010, 05:00 AM
to remove the rear top shock mounts, i used a 6" extension to my 1/2 drive sockets (connected to impact wrench for me). the clearance for getting up there is tight but doable. good luck
post #15 of 26 Old 06-11-2010, 04:38 PM Thread Starter
how do i get the weird bracket for the top shock mounts to go through the bushing?
post #16 of 26 Old 06-11-2010, 06:02 PM
alt_phil's Avatar
Usually you can force 'em through. Some find it easier to put the bushing on the bracket first, then push the whole thing through the shock.
Rubber bushings are much easier to get in when hot. So if you're still having trouble, put 'em in really hot water for awhile. Also, of course, grease helps.
alt_phil is offline
post #17 of 26 Old 06-11-2010, 06:12 PM Thread Starter
thanks. i forced them through. only took about 2 hours....
all thats left is the front track bar and im done!!!!!!!!!!!
post #18 of 26 Old 06-11-2010, 09:37 PM
And get some new rubber for that thing now please...those tires looking real anorexic with that new lift on now.
08 2dr X, Rock Krawler Arms and front truss, C Gussets, FT 3" Springs, JKS Trackbars & Discos, AEV Snorkel, Warn Front Bumper, Rancho Rear Bumper, 35" BFG KM2, Recon 10500 Winch, Synthetic Line, Coast Rear Shaft 1350, KC Slimlites, Cobra 75 CB
SEPA JK08 is offline
post #19 of 26 Old 06-13-2010, 03:12 PM Thread Starter
my drive shaft has already crapped out
post #20 of 26 Old 06-13-2010, 03:22 PM
paramaniac's Avatar
wow... sorry to hear that man.
post #21 of 26 Old 06-13-2010, 04:49 PM
How exactly?
jake_blue is offline
post #22 of 26 Old 06-13-2010, 04:51 PM Thread Starter
Originally Posted by jake_blue View Post
How exactly?
torn boot. cv grease everywhere. i smelled it burning on the exhaust. its all over the bottom of the jeep.
im going to get it off tomorrow
post #23 of 26 Old 06-13-2010, 06:20 PM
Jeep~Rebel~Chick's Avatar
do you off road yours? i have had my RC lift on 4 2 months now and mine is ok, but i havent been offroad yet
too may jeeps and other vehicles. but my dd is an 09 wrangler sahara 4 dr, 4" rc susp, 35" attitides, 17" rebel racing wheels, hi rock bumpers, winch, kc's, rock rails, daystar accessories.....
Jeep~Rebel~Chick is offline
post #24 of 26 Old 06-13-2010, 06:29 PM Thread Starter
nope. all road driving
post #25 of 26 Old 06-15-2010, 04:47 PM Thread Starter
i got in contact with [email protected] and he some pictures and asked for more and i sent them. that was yesterday. havent heard anything today
