Am I wasting my money using Mobil 1 ? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 29 Old 11-05-2009, 01:14 PM Thread Starter
JK Wolfe's Avatar
I have a lifetime warranty so why bother using the more expensive stuff.
What do you think?
I always used M1 in my 93' Wrangler.
JK Wolfe is offline
post #2 of 29 Old 11-05-2009, 01:15 PM
Administrator
HITMONEY's Avatar
What do you think?
Use what you trust.
Mobile 1 goes in every crankcase I own.
°lllll°
Facebook Page
YouTube Channel
HITMONEY is offline
post #3 of 29 Old 11-05-2009, 02:25 PM
.:eMETAL:.'s Avatar
Use what you trust.
i'm with HITMONEY on this. but actually the Jeep is the first new vehicle i've ever owned and i just let the dealership take care of it. i have the platinum service group so i don't worry about anything and there isn't any expense on my side.
.:eMETAL:. is offline
post #4 of 29 Old 11-05-2009, 02:32 PM
Xtremjeepn's Avatar
Nobody knows yet what the 5 year manditory inspection for the lifetime warranty entails. Jeep may find a simple way to void every modified jeep from the lifetime warranty. I would take good care of it.
__________
Cole Ford
Xtremjeepn is offline
post #5 of 29 Old 11-05-2009, 02:33 PM
GreenAmphibious's Avatar
nuttin but mobile 1 since day one
2015 JKU Sport Virgin
GreenAmphibious is offline
post #6 of 29 Old 11-05-2009, 02:36 PM
JHJeep's Avatar
Mobil 1 for me... whatever the oil change place uses is fine by me. I just make sure to change it every 3,000 miles.
JHJeep is offline
post #7 of 29 Old 11-05-2009, 02:46 PM
give me vtec's Avatar
mobil 1 is in mine right now, same as the rest of my cars. I ran valvoline for the first 12,000 miles for break in.
As far as the warranty goes... Chrysler, or whoever owns jeep when your engine finally craps, may not exist or even honor your warranty 30 years down the road. I say play the safe side. A refill w/mobil1 costs about the same as a regular oil change if you do the work yourself. Why cheat your prized jeep out of the good stuff to save a couple of measly dollars???
give me vtec is offline
post #8 of 29 Old 11-05-2009, 02:49 PM
gold knight's Avatar
Yeah this. I was very surprised to have an axle seal replaced at 40k under the lifetime powertrain warranty. But I have no illusions about getting a new engine when this one wears out.....normal wear and all that jazz. So I'll take care of it best as I can and won't let the warranty be the deciding factor.
So far I have mostly run Castrol Synthetic Blend and at two years and 56k miles all is well. But I am considering Mobil1 full time.
gold knight is offline
post #9 of 29 Old 11-05-2009, 04:27 PM
bubba2u's Avatar
i run what ever is on sale at the local auto parts store. usually $12 to $15 for 5 qts and a filter and yes i buy an additional qt. i have been changing the fluids about every 2500 miles to make sure the dust, mud and water i play in hasn't contaminated the oil. on the last oil change i added a bottle of stp oil treatment. my jeep has 5000 miles now and ive been through 2 engine oil changes. 3 differential oil changes. and 2 tranny and transfer case oil changes. cheep insurance to make sure no water is in there. hey it works for me.
bubba2u is offline
post #10 of 29 Old 11-05-2009, 05:36 PM
fl-mitchells's Avatar
I run Mobile 1 in my diffs, I figure as rarely as I've had to change diff juice (once, and then only cuz I put on Riddlers) the extra cost is negligible. As far as motor oil I don't really see the benefit of synthetic vs. dino in my aplication. I change the oil regularly enough that extended life doesn't matter, and I have no performance mods beyond a CAI that would work the engine outside of it's normal specs, so the extra money seems a waste. Seems to me that when you start adding performance mods the need for better oil would be there.
"Experience is something you don't get until just after you need it." --Stephen Wright
fl-mitchells is offline
post #11 of 29 Old 11-05-2009, 06:02 PM
riverzendz's Avatar
I just switched from Castrol GTX to Mobil 1. Gonna stick with Mobil 1.
For what it's worth - the lifetime warranty only covers the block. The top end is on you after 36k.
riverzendz is offline
post #12 of 29 Old 11-05-2009, 06:04 PM
TheBeatenPath's Avatar
i use the yellow bottle i believe its Pennzoil i think its 25 bucks with the upgraded filter every time my change oil thing goes off
its too far for me to drive to starke to get my oil changed
TheBeatenPath is offline
post #13 of 29 Old 11-05-2009, 06:06 PM
Xtremjeepn's Avatar
How do you figure that?
Where is it in writing that the top of a motor is not part of the drive train?
__________
Cole Ford
post #14 of 29 Old 11-05-2009, 06:21 PM
Grant211's Avatar
I've never used synthetic oils and don't plan on it. I just stick with the same brand oil (mopar) and change it every 3K-4K miles.
I haven't owned that many cars (92 transam, 98 Ram, 04 Ram, and this heep) all were new and none of them had more than 75,000 miles on them before i traded them. To date, never had a problem. I can't even think of an issue growing up with my parents vehicles either.
Grant211 is offline
post #15 of 29 Old 11-05-2009, 06:33 PM
Xtremjeepn's Avatar
Synthetics become more important on turbo charged high performance engines where you have impellers spinning at extremely high RPM.
__________
Cole Ford
post #16 of 29 Old 11-05-2009, 06:50 PM
riverzendz's Avatar
It's right here.
http://www.jeep.com/en/lifetime_powertrain_warranty/
The cylinder block and internal parts of gasoline engines are covered for life.
post #17 of 29 Old 11-05-2009, 07:12 PM
anybody that tows a vehicle, drives more than 50 miles a day, operate in extreme temps, or does any regular off roading should seriously consider mobil1.
post #18 of 29 Old 11-05-2009, 07:33 PM
Xtremjeepn's Avatar
....and valves would be "internal parts". Nowhere in the warranty does it exclude the cyl heads as you mentioned earlier.
__________
Cole Ford
post #19 of 29 Old 11-05-2009, 07:38 PM
riverzendz's Avatar
Nowhere in the warranty does it include cylinder heads. It specifically calls out block and internal parts (crankshaft, pistons, bearings, etc.) but neglects to mention any part of the top end.
I get what your saying and tend to agree but it's not a debate that I want to have with Chrysler. Block means block. Not heads or intake manifold.
post #20 of 29 Old 11-05-2009, 07:39 PM
Mr.RonGilbert's Avatar
Keep buying the Mobil1 it helps my stock!
It's good stuff too.
Mr.RonGilbert is offline
post #21 of 29 Old 11-05-2009, 07:54 PM
riverzendz's Avatar
Misleading info on the link I posted earlier!
post #22 of 29 Old 11-05-2009, 08:06 PM
d'sjk's Avatar
Use what you trust.
Mobile 1 always in every car I have owned over the past 6 years
If you saw how bad I trashed my Jeep Grand Cher. with 238,000 only using Mobile one and never a problem and the engine was still running almost like brand new.
Now after almost 3 year of owning my JK and 68,000 miles and oil changed right away and then every 4000 miles my engine though very dirty from mud, clay, and sand or whatever was on the last trail I was on the engine still runs perfect.
I have an autozone card and for every 2 oil changes I get one free so basicly buy 12qu of oil and a filter get 6qu & filter for free. This really brings the cost down and then add that to whatever other special they have going on (last time it was buy 4qu get 2 qu free) and the cost really is not that much different.
d'sjk is offline
post #23 of 29 Old 11-06-2009, 07:51 AM Thread Starter
JK Wolfe's Avatar
Ok, I'm sticking with the Mobil 1, I had already bought but was just thinking...
all of you have re-convinced me. thanks
JK Wolfe is offline
post #24 of 29 Old 11-06-2009, 07:55 AM
lifetime warranty is ALWAYS open to dealer interpretation.... especially with Obama in office
post #25 of 29 Old 11-06-2009, 08:51 AM
offroad's Avatar
Amsoil on the engine, T/C and diffs.
offroad is offline
