Best wheel size? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 08-30-2009, 12:25 PM Thread Starter
klutz1001's Avatar
Best wheel size?
Alright.. Ive been back and forth over buying used/new wheels but now leaning to new ones... I think i want 17's but im confused over 17x8 and 17x9... i dont think i have seen tires less than about 11? how does this work? also what are the thoughts on cragar vs black rocks vs others? i was gonna order the wheels from quadratec and go to discounttire for wheels to save on shippin... thanks everybody!
klutz1001 is offline
post #2 of 7 Old 08-30-2009, 12:41 PM
.:eMETAL:.'s Avatar
i run 17x9 with a 37x13.5 meat wrapped around it. i like wide tires so i opted for the 9" width wheel cuz i'll probably go a little wider in the future.
.:eMETAL:. is offline
post #3 of 7 Old 08-30-2009, 12:53 PM
muddpuppy01's Avatar
I like the 9" wheels for 13.5 tires and 12.5 are good with 8"
muddpuppy01 is offline
post #4 of 7 Old 08-30-2009, 12:56 PM
scottrock's Avatar
Unless you've got wider than stock axles, an extremely offset wheel, or additional spacers, I would not recommend running an 11" rim. 9" would be max I imagine. If you're going through Discount, ask them for a recommendation on rim width based upon your tire selection. Sufficient BS is around 4.5" and IMO for a DD anything more will cause excessive bearing wear leading to premature failure.
scottrock is offline
post #5 of 7 Old 08-30-2009, 01:22 PM Thread Starter
klutz1001's Avatar
ok awesome feedback....but how about crager vs black rock vs others??
post #6 of 7 Old 08-30-2009, 02:20 PM
scottrock's Avatar
Surely take all suggestions into consideration but whatever you choose, I would recommend staying away from 15" rims. The JK brake rotors are designed for a minimum 16" wheel. I know, I know, some fit... but many don't without grinding the calipers. I know alot of peeps say they fit with no issue while others say with minor caliper "adjusting" you'll be fine but IMO you're better served with a wheel size designed for the JK. Anyway, if you're running a 35, you'll have plenty of rubber on the sidewall without running 15's
post #7 of 7 Old 09-01-2009, 10:42 AM
l3itch's Avatar
I run 15x10 Cragars with 13.5 x 33 Nitto Mud Grapplers. Perfect combo for me
l3itch is offline
