Does anyone know the diameter of the jk front swaybar? I can't find the information anywhere. All results are for rear swaybar, TJ sway bar ehich is 1 3/16", and aftermarket swaybars.
I don't know if there's a difference between the rubi and non ruby sway bar diameter. I have an 07 rubi.
The reason I ask is because my swaybar is hitting the round crossmember that sticks out past the front of the frame. I was gonna grind the tubes down but I've learned that those tubes are there to restrict excess lateral movement of the swaybar. I've read about people grinding the tubes down and the swaybar shifted over so much with nothing to stop it, thst it damaged the drag link and other parts.
Anyways, I want to put some clamp on shaft collars on both sides of the swaybar to prevent it from shifting side to side. I just need the correct inner diameter of the collars to.mstch the swaybar diameter.
