Got my onboard air done. - JKowners.com : Jeep Wrangler JK Forum
 5Likes
  • 1 Post By lost_jeep
  • 1 Post By THREE-D
  • 2 Post By ExWrench
  • 1 Post By ExWrench
post #1 of 9 Old 05-26-2017, 03:39 PM Thread Starter
BlackOps82's Avatar
Well I was given an onboard air from Viair from a friend for doing some work on his jeep. So I spent some time and made some brackets out of aluminum and got it wired p.. works like a champ!
Float like a Cadillac Sting like a Bimmer.
BlackOps82 is offline
post #2 of 9 Old 05-27-2017, 02:18 AM
lost_jeep's Avatar
awesome!
BlackOps82 likes this.
lost_jeep is offline
post #3 of 9 Old 05-27-2017, 04:51 AM
THREE-D's Avatar
Likey, likey..I bet my daughter would soil the seat the first time that thing cycled.
THREE-D is offline
post #4 of 9 Old 05-27-2017, 11:04 PM Thread Starter
BlackOps82's Avatar
It's actually extremely quiet... I tested it today with my 18 mo daughter while she was sleeping kicked it on and let it run to 150 psi and she didn't move a muscle!!!!
post #5 of 9 Old 05-30-2017, 07:25 AM
Nice.
post #6 of 9 Old 05-30-2017, 09:09 PM
Random Dude
I dig it!
I've been considering moving my compressor from underhood, and pics are always good inspiration.
3 things you may want to consider (nothing alarming, just consider):
  • You can move the pressure relief out of the way using a tee fitting in one of the other ports
  • The compressor pump head gets warm - keep an eye on your little one's hands and that plastic window
  • Without a drain on the bottom of the tank, you may start a water collection . . .
Nothing to lose sleep over, just wanted to call those out.
Thanks again for sharing
pvanweelden and BlackOps82 like this.
ExWrench is offline
post #7 of 9 Old 05-31-2017, 10:18 PM Thread Starter
BlackOps82's Avatar
You are correct on all 3 accounts!
have considered that making a special aluminum block to hold 2 ARB locker pressure switches and will attach there or the other side.
for the compressor I'm gunna make a little water proof fan set up and thankfully my daughter it to small to currently reach it and if she is in the back my gear that I take wheeling is on the side also so hard to reach for her but thank you for thinking about it.
lastly since it did escape me and my dad also pointed in out I'm gunna get a !/4 npt bung and make a hole on the bottom and tig it on and pressure test it. also gunna run a small vacuum line out of the drain through the grommet by the taillight so it will drain out side.
I dig it!
post #8 of 9 Old 05-31-2017, 10:22 PM Thread Starter
BlackOps82's Avatar
Got this little bad boy the other day.. Viair 00041 $25 on Amazon.. it itches on and stays on!!! gauge is accurate as well... and comfortable as well!!
post #9 of 9 Old 06-01-2017, 10:10 PM
Random Dude
Originally Posted by BlackOps82 View Post
. . . also gunna run a small vacuum line out of the drain through the grommet by the taillight so it will drain out side.
If it's the grommet I'm thinking of, I found that a 90 degree fitting makes for clean routing without violating minimum bend radius.
ExWrench is offline
