Show Your 2-Door on 40s+ - JKowners.com : Jeep Wrangler JK Forum
 1Likes
  • 1 Post By jerseyjeep95
post #1 of 12 Old 07-30-2016, 12:17 PM Thread Starter
Bumpstick's Avatar
2-Doors don't get shown as much as the JKU. There is the Stretched 2-Door thread and the Post your 37s thread, so I thought 'lets see what 40s+ on little 2-doors look like and what guys have been doing to get them to fit.' Plus their thoughts on that big of a tire and lift on the short wheel base they are running. Right now I'm doing the LCG on 37s on my 2-door, but its going to be tweeked because I want more up-travel 3" is not enough.
- 37 Irok's - 4.88 - Detroit/OX -
Bumpstick is offline
post #2 of 12 Old 07-30-2016, 09:34 PM
jerseyjeep95's Avatar
40s on a stock wheelbase is a little short IMO. A 3" stretch would be ideal.
Here's mine on 3.5 RK springs and stock wheelbase.
Sent from my SM-N920V using Tapatalk
POISON SPYDER • ROCK KRAWLER • POLY • RCV • YUKON • AEV • TATTON • MBRP • TERAFLEX • BILSTEIN • JKS • RAMSEY • ROCK HARD • WURX • NEMESIS • SPOD • RIGID
jerseyjeep95 is offline
post #3 of 12 Old 07-31-2016, 03:44 AM Thread Starter
Bumpstick's Avatar
I had my 4" TF springs in at first with my 37s then swapped back to 17/58s w/ 1.75 spacers I was running with my 33s before the flat fenders. I haven't gotten a chance to really wheel it yet but first impressions were stock is a little short once you start going big.
What fenders are those?
post #4 of 12 Old 08-10-2016, 12:31 PM
Tweak's Avatar
Running pretty much stock wheelbase with 40" sticky treps, it really needs a stretch.
Billet 2013 2 door
Dana 60 front, 14 Bolt rear, ARB's, 5.38's, 40" sticky Trepadors, 3 link front and rear, 14" Sway-a-Way coilovers, Tom Woods 1310 front, Adams 1350 rear, PSC Hydro assist
Tweak is offline
post #5 of 12 Old 08-10-2016, 01:52 PM
BigBlackJK's Avatar
Here is mine. 3 inch lift stock length and toyo 40s
Sent from a big rock
BigBlackJK is offline
post #6 of 12 Old 08-10-2016, 06:17 PM
105 WB, 40 Nitto's, 3in. of lift
Jampop1 is offline
post #7 of 12 Old 08-10-2016, 08:03 PM
A little preview of what's to come.
RiverCityOffroad likes this.
post #8 of 12 Old 09-04-2016, 06:35 AM
Napalm Nate's Avatar
I think 40s on a two door is badass it's just stock axles are too weak to handle those big meats tons and a 3 inch stretch would be perfect
Napalm Nate is offline
post #9 of 12 Old 09-04-2016, 01:04 PM
The Wheelin Man's Friend
RiverCityOffroad's Avatar
Feedback: 60 reviews
You've all seen it, but sure why not.
RiverCityOffroad is offline
post #10 of 12 Old 09-13-2016, 09:38 AM
terrahawk's Avatar
terrahawk is offline
post #11 of 12 Old 09-13-2016, 08:47 PM
qqq
qqq's Avatar
Size:  153.1 KB first pic is 40 stock .the second one is whit the 12 inchs strech,like it better whit some strech,,40 and 14.50 is big
qqq is offline
post #12 of 12 Old 12-06-2016, 07:57 PM
RUNNINGMAN42's Avatar
2009 on 40" stickys. Its for sale too.
JK 2-door, 78,000 miles. V-6 with a 6 speed manual transmission.
Atlas 4.3 twin stick transfer case with 1350 yokes at both ends.
Custom weld in roll cage that ties to the frame and allows the use of factory and after market tops.
Front axle:
Dynatrac Pro rock 44HD. It's loaded with Reid Racing knuckles, RCV shafts and a 4-pin Eton Elocker and 5.13 gears.
Hydro assist Steering:
PSC high volume/high pressure pump, reservoir, 14" heat sink cooler, PSC ram and PSC steering box(not a taped factory JK box).All steering linkage is 1.5" DOM.
Driveline:
Custom front and rear 1350 drive shafts.
Rear axle:
Dana 60 with 35 spline chromoly shafts, Detroit locker and 5.13 gears. Custom 3-link truss.
Suspension:
Custom 3-link front and rear with a 4" wheel base stretch for an overall 100". Progressive rate 3.5" lift coil springs, Bilstein remote reservoir shocks.
Wheels and tires:
For the street and trail four 40/13.5/17 Nitto trail grapplers on AE beadlocks.
For the trail ONLY four 40/13.5/17 Maxxis competition Sticky Treps on ATX Slab bead locks.
Misc Items:
Corbeau Racing adjustable and reclining harness seats with Corbeau harnesses.
Rocker armor and Comp Cut Crawler Conceptz corner armor.
Genright fuel cell(not yet installed)
Tube trail doors(new and still in the box.
Victory 4x4 frame chop front and rear bumpers.
9500LB winch with synthetic rope
This rig is street legal and will pass emissions. I have both driven it to the trail to wheel and also trailered it.
RUNNINGMAN42 is offline
