4.5 inch lift with 35s - JKowners.com : Jeep Wrangler JK Forum
post #1 of 13 Old 01-08-2016, 05:17 AM Thread Starter
Anybody running that setup? Would love to see some pictures.
Shallaje is offline
post #2 of 13 Old 01-08-2016, 05:57 AM
Donut707's Avatar
08 4inch lift and 35's
here are some shot of my 08
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Donut707 is offline
post #3 of 13 Old 01-08-2016, 08:16 AM
ALASHA's Avatar
why so much lift?
ALASHA is offline
post #4 of 13 Old 01-08-2016, 08:19 AM
coilrod's Avatar
^×2.
I ran 2.5" with 37's and now 3.5".
The jeep now is almost excessively high.
coilrod is offline
post #5 of 13 Old 01-08-2016, 10:38 AM
boopiejones's Avatar
i was running 35's with a 2.5 lift and now i am on 37s with the same 2.5 lift (although my rig is fairly light so i think i'm actually over 3" of lift).
a 4.5 inch lift sounds pretty excessive to me for 35s. and properly dialing in a 4.5 lift requires significantly more time and money than a 2.5 or even 3.5 lift.
boopiejones is offline
post #6 of 13 Old 01-08-2016, 12:19 PM
Donut707's Avatar
why so much lift?
Originally Posted by coilrod View Post
^×2.
to be honest it came that way. ive really only done maintenance and new tires. it came with stock rubicon shocks on the rear when i bought it. the stealership replaced the leaking procomps and killed the ride. it had no drop/flex in the rear at all. when i replaced the rear shocks with the matching procomp shocks the ride improved (but its still pretty rough) . i rebuilt the front drive shaft cv joint and found a wear mark on the skid plate from the drive shaft contacting it. i would like to upgrade to a better lift ( tereflex or RK) down the road . my jeep weighs 4820 with no spare and me in it. 3:73 and 35's are "ok" but id like 5:13's to deal with the tires and weight. i think im right at the limit for gear vs tire size . i dont know how guys run anything taller go with out re-gearing.
Donut707 is offline
post #7 of 13 Old 01-08-2016, 01:26 PM
Donut, looking at your pictures, that does not look like a typical 4 inch lift to me. i would have guessed 2.5, but maybe the pictures are deceiving...
post #8 of 13 Old 01-08-2016, 06:43 PM Thread Starter
My aftermarket guy is guiding me towards the 4.5 with 35s but 15x10 wheels which will make it look thick and lower vs too high.
I am a bit worried that it will be too high. Although Donuts truck looks nice! Hmm one benefit is if I goto 37s it will be easy.
Decisions.
Shallaje is offline
post #9 of 13 Old 01-08-2016, 07:35 PM
ALASHA's Avatar
Decisions.
Your aftermarket guy sounds like he doesn't know what he is talking about.
ALASHA is offline
post #10 of 13 Old 01-09-2016, 05:27 AM
Donut707's Avatar
the stealership told me this was the lift that was installed by the original owner when it was bought from them in 08. its just springs and shocks . ive had some small alignment issues , the front track bar mount has broken twice . but over all it been alright ish. it doesnt really flex for shit
http://www.4wheelparts.com/Suspensio...t_pn=EXPK3089B
[IMG][/IMG]
Donut707 is offline
post #11 of 13 Old 01-09-2016, 09:47 AM
did you disconnect your front sway bar before climbing the ramp?
post #12 of 13 Old 01-09-2016, 10:19 AM
Donut707's Avatar
yup it was disconnected its sprung so stiff and i have open diffs so it raise the tires and thats as far as i went
Donut707 is offline
post #13 of 13 Old 01-09-2016, 06:48 PM
JKO Dickhead
Asmmns's Avatar
Decisions.
I run a 2.5 on 35's 15x10 with a 35x12.5 MTR
I also run a pretty big offset so it does look wide, but that is too much lift for 35's
__________________
CURE SMA !
Asmmns is offline
