Little weekend carnage - JKowners.com : Jeep Wrangler JK Forum
post #1 of 15 Old 02-23-2015, 07:49 AM Thread Starter
Thisguyhasadd42's Avatar
Had my first experience with snow wheeling yesterday, which turned into the worst break I've had on the trail. Broke my sector shaft I was trying to climb an ice covered hill and grabbed a dry spot got traction which pulled me into the berm/tree root and pop. Wheel speed was definitely the culprit in this case, but there was no chance i was crawling up this thing.
It looks like theres a little rust on the bottom right side, so I'm thankful it happened here and not on the road.
Rigged up the sling to the knuckles and this badass little liberty pulled my ass out
Made a phone call to a buddy and he was nice enough to pick me up. He just got this set up and let me tell you this 450 pulls like an absolute beast. Could hardly tell the jeep was behind us.
All in all it was a good day, the guy in the liberty got me to the parking lot and then we wheeled in his jeep the rest of the day. And my buddies little YJ he bought for a grand was a little animal out there. He welded up the front and rear and that bitch went damn near everywhere.
At this point i figure Ill just pony up for the PSC hydro assist kit. I need to get a new pitman arm as well, as we unable to get the busted shaft out and the splines are all chewed up anyways. I have a stock drag link, you guys think i should just upgrade now as well?
2010 Mango 2dr 6spd Rubicon
Thisguyhasadd42 is offline
post #2 of 15 Old 02-23-2015, 09:19 AM
KrawlOff-Road.com's Avatar
Feedback: 37 reviews
Glad you were able to make it out! Looks fun... minus the breakage!
-Jason
Phone: 864-437-8029
KrawlOff-Road.com is offline
post #3 of 15 Old 02-23-2015, 11:28 AM Thread Starter
-Jason
It was a lot of fun, only part i was mad about was how early it happened. The learning experience of the whole thing was great. Now having the knowledge of how to make a recovery in that situation will be something ill never forget and will be able to pass on to fellow wheelers if something like that happens again.
post #4 of 15 Old 02-23-2015, 11:40 AM
TCdawg's Avatar
The old sector shaft break is one that absolutely ends your day. At least you were in a spot where the recovery wasn't so bad.
I would swap out that stock DL for a better one while you are doing all the work. I have had a RK drag link on for a years and have never had an issue with it at all. Many other good brands too.
TC
TCdawg is offline
post #5 of 15 Old 02-23-2015, 12:02 PM Thread Starter
It sure does. It actually wasn't to terrible getting it out of the woods, just slow moving. The snow and ice definitely helped i thought.
Im gonna go with the synergy DL, i like that it comes with the tre's and its adjustable while on the jeep.
Do you think it is worth getting the sector shaft brace with the hydro assist?
post #6 of 15 Old 02-23-2015, 01:05 PM
TCdawg's Avatar
I think all drag links use the adjuster sleeve which allows you to adjust while on the vehicle. Not totally sure on that though
I elected not to do a sector shaft brace since doing the hydro assist. supposedly the ram takes some pressure off the steering box. So far so good for me. But I don't see how it would hurt. If you are doing a Synergy DL, they make a nice sector shaft brace to go along with it.
TC
TCdawg is offline
post #7 of 15 Old 02-23-2015, 01:09 PM
kjeeper10's Avatar
It's my understanding you do not need a SSB with Hydro assist. The load is removed from the drag link/sector shaft.
kjeeper10 is offline
post #8 of 15 Old 02-23-2015, 01:27 PM Thread Starter
I have read that as well, I think the brace might help against a shock of something similar to what happened to me. Not sure if the brace would have helped in this case tho.
Edit: after a quick look at the brace i think in fact would have helped in this situation
post #9 of 15 Old 02-23-2015, 01:30 PM
Random Dude
You've already passed on some knowledge - I filed away the trick of setting up the tow strap as a yoke to the knuckles.
  1. Thanks for sharing that trick!
  2. Glad you got out without any more drama.
  3. Did your Jeep trail along behind the Liberty without needing corrections?
  4. With those big-assed meats and non-mall wheeling, consider adding ram assist rather than a sector shaft brace.
ExWrench is offline
post #10 of 15 Old 02-23-2015, 01:40 PM Thread Starter
Glad to share! Surprisingly it did, as long as you keep the shackle from sliding on the strap attached to the knuckles it should follow. the shorter sling from the "apex" to the liberty helped. It acted pretty much as a tow bar. Ram assist will be added, going with the PSC kit. I know its pricey but i figure ill do it right the first time. I just wondering if the brace would be added insurance.
Forgot to mention, the was in gear "4low and first" to help assist the tow. No gas from me unless absolutely needed. Also if the jeep started to climb out of the ruts id push the clutch in and lock up the brakes and it would slide back in the ruts. Again i think the snow helped tremendously with this.
post #11 of 15 Old 02-23-2015, 02:15 PM
Random Dude
Thank you! I can't quite see - what did y'all use to cinch the strap together near the shackle? (damn, I'm a needy bitch today)
All good stuff, except for their bolt-on axle side ram mount - I got a PM question from a dude who's bent 2 of them.
Also, I strongly suggest putting a cooler in the return line to the reservoir unless you like cooking and replacing pumps.
It's added insurance, but IMHO kinda' like adding training wheels to a tricycle.
No harm in going overkill - feel free to ignore me when I suggest not adding strength to your Jeep.
ExWrench is offline
post #12 of 15 Old 02-23-2015, 02:42 PM Thread Starter
My buddy who is a rigger by trade worked his magic. He made loop with the loop at the end of the sling "cats paw" around the tre on the pass side. Was harder on the driver side, he tied a clove hitch then secured it with some flat line. Also need to make sure the shackle up front doesn't slide.
They will be making a custom bracket for me sense I have the Teraflex 44 housing up front. I'll be sure to keep and eye on it. Worst case I can weld something stronger. Cooler was ordered as well!
Gotcha, will most likely pass on it at this time.
post #13 of 15 Old 02-28-2015, 02:47 PM Thread Starter
Brown santa came today!!! Pretty sure i got pump, I wanted the light feel but got the firm feel. Think ill be able to just send the pump back? Got the synergy DL as well.
post #14 of 15 Old 02-28-2015, 09:33 PM
TCdawg's Avatar
They sent you the wrong pump? Hell yes, send it back.
TC
TCdawg is offline
post #15 of 15 Old 03-12-2015, 05:50 AM Thread Starter
After a quick email to Marcus we got it figured out. He talked to Kelvin at PSC and he said to run the firm feel if the jeep will be drivin at all on the road. It's not my dd but I defintely drive it. So all is good, looking forward to getting this system on the jeep.
