Reptar got RIPPd - JKowners.com : Jeep Wrangler JK Forum
post #1 of 35 Old 11-22-2013, 03:07 PM Thread Starter
Reptar got RIPPd
Well I have been away for a while finishing my XJ build, I decided to show the JK some love for almost hitting 20k miles. I got a RIPP supercharger installed on my 3.6, this thing is all kinds of fun now. The waste gate sounds awesome when you get on it. Diablo set up a great tune on it with their new Version 2 tune for the 2012-13 wranglers. I really like the new Diablosport Trinity programmer, you can attach it to your windshield and 0-60, 0-100, 1/4 mile, and 1/8 mile times. Lots of neat features on it over the old hand held programmer I had on my charger. Only drove it about 20 miles today, but it has been a blast and actually keeps up with traffic.
Idle Video
Throttle Video
Reptar is offline
post #2 of 35 Old 11-22-2013, 09:40 PM
BANZAIKEV's Avatar
NIIIIIICE!!!!!
MAY THE LORD BLESS YOU.... YOUR JEEP.... AND THE TRAILS YOU RIDE ON....
BANZAIKEV is offline
post #3 of 35 Old 11-22-2013, 10:03 PM
BigMike's Avatar
Sweet. Who did the install?
, Granite,
BigMike is offline
post #4 of 35 Old 11-22-2013, 10:07 PM Thread Starter
Allsouth Autosports in Buford
I am not far from you, I bought a lot of vehicles from Palmer Dodge in Roswell and am over that way quite a bit
Reptar is offline
post #5 of 35 Old 11-23-2013, 09:54 AM
Tat2dfreak's Avatar
Not a fan of how close the air filter is to the radiator, seem like it would be sucking in a lot of hot air.
Tat2dfreak is offline
post #6 of 35 Old 11-23-2013, 10:20 AM
Pascoreli's Avatar
WOW is thats a sexy sound.
Project Saskuatch is underway!! 2013 Wrangler Unlimited Rubicon
3.5" MC Game Changer, Genright Armour, Warn Winch, Fuel Wheels, 37" Nitto's, AEV hood, JW Speaker w/ Rigid Lights.....
Pascoreli is offline
post #7 of 35 Old 11-23-2013, 01:52 PM
Monty's Avatar
nice! and chive on my brother.
Mike M
2013 2dr rubi
MC 2.5", Fox RR TF tuned shocks, TF carrier, Viair, TL's and so on...... still on stock tires
Monty is offline
post #8 of 35 Old 11-23-2013, 09:06 PM
TCdawg's Avatar
The air it sucks in gets run through an intercooler.
TC
TCdawg is offline
post #9 of 35 Old 11-24-2013, 10:47 AM Thread Starter
It sure does, I love hearing the waste gate while I drive.
KCCO
Ding ding!!
Reptar is offline
post #10 of 35 Old 11-24-2013, 11:04 AM
Which is trying to cool hot air running through the blower. air-to-air coolers are inefficient as it is, preheating it before the blower isn't helping much at all. Combine that with a high mass flow rate and small surface area, and it's not going to bring amazing results. I'd shoot for a water-to-gas intercooler, ~3x higher heat transfer coefficient than gas-to-gas.
post #11 of 35 Old 11-24-2013, 11:17 AM Thread Starter
^^^ This guy got something negative to write on every post I make.
Reptar is offline
post #12 of 35 Old 11-24-2013, 11:35 AM
And yet you don't complain about this one?
Wah.
post #13 of 35 Old 11-24-2013, 06:30 PM
ADDICTION II build begins....
TXROCK's Avatar
awesome!!
Been running the RIPP with RIPP long tube headers on mine for a couple months now and very happy with it as well!
U.S. Army
TXROCK is offline
post #14 of 35 Old 11-24-2013, 10:38 PM
Do you have an aftermarket cam or is it just my crappy speakers? Sounds like the idle is a little more aggressive. Sweet rig btw.
beenzz69 is offline
post #15 of 35 Old 12-17-2013, 05:33 AM
A bad design is a bad design. Don't shoot the messenger for making a suggestion that will get you a bigger return on your sizable investment.
Wangmuf is offline
post #16 of 35 Old 12-17-2013, 05:47 AM
BigMike's Avatar
Notice any difference in fuel efficiency?
, Granite,
BigMike is offline
post #17 of 35 Old 12-17-2013, 08:42 AM
TCdawg's Avatar
is it a bad design? Or are you just repeating stuff you read on the internet, because all of it is true. Bonjour!
Sure it is pulling in hot air from around the motor. So is your stock air filter or any other aftermarket "cold air intake" they are all in relatively the same location unless you are running a snorkel. And in none of these cases is that air getting cooled off prior to going through the intake.
The air the SC pulls through is cooled through the intercooler and it does a pretty good job. Sure, the are even more efficient ways to cool the air but many are beyond the scope of a simple and efficient forced air system.
TC
TCdawg is offline
post #18 of 35 Old 12-17-2013, 08:55 AM
BigMike's Avatar
^^^^ This
Also, RIPP tested their system a while ago with a snorkel and got lower HP/TQ numbers due to the length of the intake.
Bottom line, are you getting MORE POWER? Okay, that settles it.
, Granite,
BigMike is offline
post #19 of 35 Old 12-19-2013, 11:42 AM
2010jk's Avatar
I think goody's just mad he doesn't have one. I love the jeep and the sound.
2010jk is offline
post #20 of 35 Old 01-18-2014, 08:15 AM
Actually air to air is better in the long run because after a while the water heats up to the same temp as the IATs and no longer has any cooling effects whereas the air hitting the IC stays around the same temp. Further adding to this the water tank is underhood normally further heating up the water. A properly sized air to air IC (this one is honestly way too small) with an intake that draws air from outside the engine bay is a far better setup. My Turbo Cobalt was running 26 psi (temps at the hot side IC were around 190* at 26 psi and normal florida air temps) and making nearly 400 ft lbs and 350 hp at the wheels out of a 2.0L motor and with my large air to air front mount IC I could do repeated 0-120 MPH pulls (took around 13-13.5 seconds each) and the IATs never rose more than 5* above ambient on my data logs. Do repeated long pulls like that with a water to air IC and unless you have a way of cooling the water in the tank ( I have seen people run the AC through them via a HE) and the tank is outside the engine bay I can guarantee your IATs will be much higher. Having tuned a few dozen supercharged Cobalts which have a water to air IC (and a good sized one for a 2.0L engine) their IATs are much hotter, up to 100* hotter to be exact, on repeated pulls vs the air to air IC.
Terminator2 is offline
post #21 of 35 Old 01-20-2014, 08:47 AM
ALASHA's Avatar
You are WAY off here.
For starters, the heat exchanger in a water to air setup sits in the same place as an air to air intercooler so either set up will recieve the same fresh air hitting the front of the JK.
Water is more dense than air so it will have better heat absorption properties aka transfer heat from the intake air out to the heat exchanger (think radiator) better. This is why a water to air heat exchanger is smaller than an air to air intercooler. This is also why engines are water cooled (VW bug excluded).
Lastly, you cant compare the IATs of a turbo to a supercharger (I am guessing a roots style is what you had experience with) and blame it on the intercooler set up used.
ALASHA is offline
post #22 of 35 Old 01-21-2014, 12:32 PM
I will say you are both right and slightly wrong but hear me out. I had a 09 Silverado with a Maggie 2300 on it and yes the heat exchanger is like a radiator and mounted in the same place as the air to air intercooler however the actual intercooler is part of the supercharger manifold and is subject to heat soak. Back to back hard runs will show the water temp will not drop as far each time and your IATs will suffer. This is true for a roots style SC not a Centri like the Ripp design so your right its not apples to apples. I traded that truck for my 12 Camaro and I have a Vortech V3Si on it with a large air to air intercooler and back to back runs my IATs never get above 5-7 degrees higher than outside air. My filter was the largest K&N I could fit directly on the supercharger inlet and is only a few inches from my heads on a 6.2L LS3 which cranks out a lot of heat. Air to Air works just fine as long as air is moving over it. I do think those IATs will rise while crawling due to lack of airflow but it wont be near as bad as a roots SC IATs. Just my opinion and I know I'm a newb here but I've had turbo diesels, turbo 4 bangers, roots style SCs, and my current Centri so I do ok at forced induction.
edit: sorry Reptar for clogging up your thread. Your Jeep is awesome brother!
SFC_A is offline
post #23 of 35 Old 01-21-2014, 12:43 PM
ALASHA's Avatar
Yes since the intercooler sits directly on top of the motor, there is added heat soak but you did the same thing again but comparing a roots to a centrifugal...
ALASHA is offline
post #24 of 35 Old 01-21-2014, 12:53 PM
[QUOTE=ALASHA;2183897]
Nope just explained why your comment above is incorrect. I have never seen air to air IC IATs be beat by a air to water IC IATs on back to back runs or extended use. I'm not comparing SCs I'm comparing the intercooler setup types to what I have seen.
SFC_A is offline
post #25 of 35 Old 01-21-2014, 01:01 PM
ALASHA's Avatar
[QUOTE=SFC_A;2188409]
Have you seen the same exact supercharger on back to back passes with an air to air vs. an air to water?
The intercooler on top of the block isnt the main contributor to increased heat from back to back passes. Its the nature of a roots style blower.
ALASHA is offline
