609 Hybrid Front axle - JKowners.com : Jeep Wrangler JK Forum
post #1 of 1 Old 06-22-2017, 09:50 AM Thread Starter
Selling my drivers side drop 609 front axle project. It started out as a new stamped steel ford 9" housing that I cut down and sleeved the tubes with 3.5"x.25 dom tube. The shafts, C's and knuckles are factory super duty Dana 60 parts. So it's the same width as a 99-03 f250. This will be the same as swapping a SuperDuty dana 60 into a JK.
The third member is a refurbished unit from Quick Performance with a 35 spline spool and 5.43 gears.
Housing comes with:
Third member complete with gears and spool.
Inner and outer axle shafts with brand new spicer u joints.
Brand new ball joints.
Brand new wheel bearing assemblies (8x170 bolt pattern).
Factory knuckles.
2 pieces of 1.5"x.25" dom tubing for steering.
You will need to purchase:
Locking hubs or flanges.
Axle seals. - https://m.summitracing.com/parts/aaf-all72100
TRE or heims for steering.
Mounts for your application.
Brakes.
I was planning to put a full truss on the housing, and I recommend you do the same. Housing has minor surface rust from sitting in the garage.
Asking $1500 for everything. Also looking to trade for stock or built JK axles with 4.10s or 4.56s. Located in Fenton 48430. Sold as-is.
RDK_YJ88 is offline
