December ROTM Class 2 Vote - JKowners.com : Jeep Wrangler JK Forum
View Poll Results: December ROTM Class 2 Vote!
sneck 3 4.35%
4LO PRO 2 2.90%
Asmmns 7 10.14%
Rottenbelly 21 30.43%
illyb 11 15.94%
Thisguyhasadd42 15 21.74%
LAXPHATTY 10 14.49%
Voters: 69. You may not vote on this poll
post #1 of 18 Old 12-16-2012, 06:16 AM Thread Starter
Apt
I Put the FU in FUN
Apt's Avatar
December Class 2
ROTM Contest (35" to 38" Tire size)
So here are the guidelines/rules:
1. Class 2 is anything and everything allowed on a rig with 35" to <39" tires.
2. Voting will begin on December 16th and will end on December 22nd at 11:59pm EST. The rig that wins the voting for Class 2 will be announced on December 23rd.
3. Vendor prizes are:
a. Matsonian - $100 gift certificate
b. Daves Offroad Supply - $75 off Reid Knuckles or $50 Store Credit for second place
Good luck to everyone!
Apt is offline
post #2 of 18 Old 12-16-2012, 06:23 AM Thread Starter
Apt
I Put the FU in FUN
Apt's Avatar
sneck
2011 Sport Unlimited Wrangler
Rear Limited slip diff, soft top. Sweet chrome grill. factory tcase and gas skid
4" frankenlift, teraflex LCAs, RK UCAs, OME HD+ 4" coils. bilstein 4" lift shocks. Rallylights h4 conversion headlights, with rigid dually supplemental lights. Evo Quarter Pounder front bumper with stinger and rugged ridge 8k, with synthetic line. Ace rock rails with rubi sliders. Ace rear tire carrier/bumper combo. Rockhard oilpan/transmission skid. OF-fab replacement crossmember. poison spider evap skid. prorock44 unlimited, with arb air lockers and 4.88 gearing. RK tie rod, with flipped drag link, poly trackbar and draglink. rcvs axle shafts. adams 1310 driveshafts front and rear. evo rockstars and poly upper shock relocation. RK rear trackbar and bracket. stock wheels, goodyear mt/r k's 37x12.5.17s, with wheel spacers. custom exhaust, with a cherry bomb behind the cats. OBA setup with 2 gallon tanks. poly weld on trackbar bracket, RK 3link,
Apt is offline
post #3 of 18 Old 12-16-2012, 06:24 AM Thread Starter
Apt
I Put the FU in FUN
Apt's Avatar
4LO PRO
EVO Bolt On Front/rear Coil Over kits, Teraflex Control Arms, Bilstein Stabilizer, Rock Krawler HD Tie Rod, Teraflex Draglink Flip Kit, JKS Quick Disconnects, RSP sector shaft brace and RSP Trackbar
PSC BFH front Stinger and PSC BFH rear
Evo MFG RockSliders, Evo control arm skids, Evo upper and lower C gussets, Evo Rockstar Skids
JE Reel 1310 Front Driveshaft, Yukon 5.13 Gears, Timken Bearings, Nitro Axle sleeves, JKS axle truss
Warn 9.5 CTI, Viking 3/8" synthetic line, Viking Thimble, PSC Fairlead, PSC Fairlead Light Mount
TrekTop NX, Poison Spyder Tramp Stamp, Poison Spyder license Delete, Removed Rollbar Pads, Poison Spyder Evap Skid, Carpet Removed, Trimmed Fenders, AntennaX, WD Custom Rear Grab Handles
35x12.5 KM2s
15x8 Pro Comp Steel Wheels
Apt is offline
post #4 of 18 Old 12-16-2012, 06:27 AM Thread Starter
Apt
I Put the FU in FUN
Apt's Avatar
Asmmns
2007 JKU X
2.5 RK Max Travel, Bilstein 5100's, GY MTRk's 35x12.50x15, PSC BFH Rear, PSC Brawler Lite Front, PSC Rocker Knockers, Aussie Locker, SUuerwinch LP8500, Delta Quadbars, RK Alum Pro Tie Rod, RK F/R HD Track Bars, FOX SS, SOLID Diff Covers, POLY C gussets and LCA skids, PSC Evap Skid, Masterpull synthetic line, ANZO led fogs, Crown SS lines, Rear shock relo, muffler relo, tramp stamp, ARB OBA, a few dents...some trimming, cutting and welding.
Apt is offline
post #5 of 18 Old 12-16-2012, 06:30 AM Thread Starter
Apt
I Put the FU in FUN
Apt's Avatar
Rottenbelly
2007 JK
4.5 synergy springs, Fox resi front shocks, Fox 2.0 rears. Metalcloak control arms.
PR 44 Unlimited front with 35 spline RCV's ,ARB locker, poly ball joints, custom control arm skids.
44 rear with 35 spline Superiors, ARB locker, custom Riddler dif cover. 5:38's, custom rear lower shock relocators. JKS front trackbar, Teraflex monster rear.
Under hood ARB compressor, optima red top
Power slot rotors and ceramic pads.
Tatton front driveshaft.
Custom made front bumper with Recon 10.5 winch
Custom gas tank skid. Poison Spider evap skid and rocker armor.
Fox steering stabilizer.
Rigid duallys, all kinds of in cab switches. 5 panel mirror.
Hr3 fire exstingiusher. Gen right hood vents, Ace hi lift mounts on hood with 48 hilift.
Level 8 strike wheels with 37 mud grapplers.
Apt is offline
post #6 of 18 Old 12-16-2012, 06:31 AM Thread Starter
Apt
I Put the FU in FUN
Apt's Avatar
illyb
2008 2DR Sahara 6spd (or what's left of one)
Rock Krawler 5.5" X-Factor coil over stretch lift (with extras)
- Rear stretch: 8"
- Front stretch: 2"
- 3-linked front and rear
- 12" RRD 2.625" front coilovers
- 12" RRD 2" rear coilovers
- RK adjustable weld-in bump stops
- Weld-in Ass Vault limit straps on all four corners (logos removed)
Rough Country Dual Steering Stabilizer with Performance 2.2 Series stabilizer cylinders
Quigly 1350 front and rear driveshafts
Yukon 5.13 Gears
Front and rear ARB differential covers
Drilled and slotted rotors with hi-performance brake pads
17x8.5 Argent AEV Pintler Beadlock wheels (the ones with 4.7" BS, not the new models)
35x12.50r17 Nitto Trail Grapplers
kNOw Where 2 Jeep 2" wheel spacers
Flowmaster HP-2 exhaust; resonator mounted next to evaporation canister
River Raider gas tank, transmission, oil pan, transfer case, and evap canister black powder coat 3/16" steel skids
River Raider fastback-style roll cage with harness mount bar
River Raider Hi-Lift jack mount
Epoxy coated interior
All factory in-tub wiring relocated under tub
Corbeau Baja XP seats
Pro Armor four point harnesses
D-Cell flashlight mounts on seat bases
Rugged Ridge A-pillar switch pod
Hidden (behind dash) FM/AM radio antenna
Uniden GMR 5089-2CKHS Submersible GMR/FRS Two-Way Radios
Cobra 29 WX NW BT CB radio
FireStik 4' Black FireFly tunable CB antenna
- FireStik SS-3H heavy duty antenna spring
- FireStik K-1A quick disconnect
Custom subwoofer setup
- 8" Pioneer TS-SW841D low-profile subwoofer
- Mounted in tub cubby (former cubby made into subwoofer enclosure)
- Powered by a Rockford Fosgate PBF300.1 amp mounted behind glove box
H3R Performance MAXOUT 2.5lb dry chemical fire extinguishers
Drake Off Road fire extinguisher clamp kits
ARB high output on-board air compressor
Synergy Suspension master cylinder air compressor bracket
ARB tire inflation kit
ARB tire inflator with gauge
Optima Blue Top battery
Black Lange Originals Quick Mirror IIs
TMD hood
Epoxy coated River Raider Rock Crawler front bumper w/ Smittybilt black D-Rings
Smittybilt XRC8 winch with synthetic rope
Speaker 8700 Evolution LED headlights
Speaker 6045 LED fog lights with protective covers
Custom wire mesh in grill slats
Custom wire mesh in hood louvers
Blacked-out Jeep logo on front grill
Night Shades treated front turned signals
Epoxy coated River Raider Pro Crawler Rear Bumper w/ license plate mount and Smittybilt black D-Rings
Lite-N-Boltz LED illumination for rear license plate
CJ-style fold-down tailgate with remote solenoid popper mounted behind glove box
Comp cut
River Raider weld-on stretched rear 3/16" steel Crusher Corners; integrated weld-on full-width tube fenders; integrated custom weld-on CB antenna mount on left corner
ORO LiteDOTs taillights
Gas tank fill tube relocation to within the rear left wheel well
River Raider weld-on front 3/16" steel Crusher Corners; integrated weld-on full-width tube fenders
River Raider custom 3/16" steel Rock Sliders w/o tube steps
Bestop bikini top, windjammer, and duster
OEM hard top; interior coated in black PlastiDip
Apt is offline
post #7 of 18 Old 12-16-2012, 06:34 AM Thread Starter
Apt
I Put the FU in FUN
Apt's Avatar
Thisguyhasadd42
2010 Mango Tango 2dr 6spd Rubicon
PSC BFH front and rear
Warn 9.5cti with viking synth line
Rigid duallys
RROR full skid
PSC evap skid
PSC diff covers
PSC trampstamp
Currie Antirock
RK 2.5 max travel pro
RK RRD shocks
37" Nitto Trail Grapplers
4.88s
purejeep backbone
evo gussets
Dynomax Rock clawer exhaust
Trek Armor seat covers
Cobra 29 LX cb
Linexed tub
Sictrunks trunk cover
Apt is offline
post #8 of 18 Old 12-16-2012, 06:37 AM Thread Starter
Apt
I Put the FU in FUN
Apt's Avatar
LAXPHATTY
Introducing my 2008 JKU Rubicon “Ms Davis” (go watch “Varsity Blues”). White with black armor and red accents (shock boots, antenna, grab handles, skids and such). She's a daily driver and I'm a Soldier, so building SLOOOWLY...
~35" Fierce Attitude tires
~Stock rattle can black rims
~Spydertrax 1.5” wheel spacers
~JKS ACOS front coil spacer
~Skyjacker 2" coil rear spacer
~Homemade front discos (rear link and HD cotter pin) (painted red)
~Chopped fenders
~Tuffy rear security enclosure (sealed with a water noodle and a TON of black silicone caulk)
~Tuffy stereo cover
~Pioneer AppRadio
~Rock camera in front passenger fender well with display on stereo
~US Border Patrol surplus differential guards front and rear (painted red)
~Lube Locker differential gaskets
~Stock transfer case skid painted red
~6 red Rugged Ridge grab handles (used a lot)
~Rugged Ridge engine and transmission skid (painted red)
~Rugged Ridge A Pillar switch pod
~Homemade power distribution center (based on Littelfuse HWB60)
~Windshield mounted Walmart (don’t hate) driving lights
~Walmart micro driving lights in wheel wells for night crawling
~Die Hard platinum AGM battery with custom bracket
~Cobra 75 CB
~Red Firestik 4’ antenna w/quick disconnect
~ALWAYS no doors
~Hinge mount mirrors
~Bestop bikini top
~Wet Okole seat covers
~GenRight aluminum tire carrier with PRP bag
~GenRight aluminum front bumper with grille hoop and boulder series stinger
~GenRight hood louvers
~Smittybilt d-ring shackles in front and reciever hitch shackle in back
~Smittybilt snatch block, recovery strap, tree saver…
~Daystar d-ring, winch, Hi-Lift isolators
~Trail Gear TG8000 waterproof winch with Anderson quick disconnect
~Tuff Stuff flip up fairlead license plate bracket
~Interior winch controls (coming after Christmas)
~48’ Hi-Lift jack with neoprene boot and off road base
~Dominion Off Road Hi-Lift jack mount
~Dominion Off Road Hi-Lift accessory brackets with Craftsman axe and shovel
~Dominion Off Road hood struts
~Homemade fire extinguisher bracket
~Homemade limb risers
~Drake hood latches
~K&N cold air intake with dry pre-filter
~Airaid throttle body spacer
~Flow Master exhaust
~All Amsoil liquids
~Cheapo air horn (fun)
Apt is offline
post #9 of 18 Old 12-16-2012, 06:47 AM
rdlynch2's Avatar
Thisguyhasadd for the win!!!!!
2008 Black 2Dr 6spd D30/44
rdlynch2 is offline
post #10 of 18 Old 12-17-2012, 08:50 AM
sneck's Avatar
need more love for the chrome
sneck is offline
post #11 of 18 Old 12-17-2012, 09:55 AM
illyb's Avatar
Apt, could you post the fifth pic I uploaded to the original submission thread to my entry for the contest? Thanks!
illyb is offline
post #12 of 18 Old 12-17-2012, 10:17 AM Thread Starter
Apt
I Put the FU in FUN
Apt's Avatar
Yep. Done. Not sure why I overlooked that one. Sorry about that.
Apt is offline
post #13 of 18 Old 12-17-2012, 10:33 AM
illyb's Avatar
No worries!
illyb is offline
post #14 of 18 Old 12-19-2012, 02:06 AM
Best wheeling pics and my vote - Rottenbelly
post #15 of 18 Old 12-19-2012, 02:43 AM
ADDICTION II build begins....
TXROCK's Avatar
voted for LAXPHATTY.....I have seen him personally use his Jeep and push it to the limits here on Oahu! And a great Jeeper to boot!
U.S. Army
TXROCK is offline
post #16 of 18 Old 12-19-2012, 02:08 PM Thread Starter
Apt
I Put the FU in FUN
Apt's Avatar
Giving this one a mid week bump as well.
Apt is offline
post #17 of 18 Old 12-22-2012, 03:22 AM Thread Starter
Apt
I Put the FU in FUN
Apt's Avatar
Last day bump.
Apt is offline
post #18 of 18 Old 12-23-2012, 09:40 AM Thread Starter
Apt
I Put the FU in FUN
Apt's Avatar
Winner!
Winner of the class 2 vote = Rottenbelly
What a terrific amount of participation by everyone, thanks!
I'll let the vendors know the outcome via PM.
Apt is offline
You may not post new threads
