MC joints in Synergy arms? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 51 Old 04-26-2013, 02:15 PM Thread Starter
bgall's Avatar
I am currently looking into a long arm upgrade. While researching the synergy kit I noticed they use JJ. I also stumbled across the fact that Metal Cloak (MC) make JJ upgrades. Has anyone used the MC JJ up grades? Any clue if they work with the synergy JJ setup? I tried calling synergy but had no luck reaching a human. I currently have the MC mid arms and love the joints for durability, performance, ride, and ease of maintenance. The fact that the synergy arms are adjustable ON the vehicle would be fantastic. Combine the two and it looks like this setup is rapidly moving to the top of my list.
bgall is offline
post #2 of 51 Old 04-26-2013, 02:19 PM
LILWB's Avatar
I can comment on the upgrade but between Jeep Beach and them moving their warehouse, I'd say the people at Poly are all busy doing work.
2008 JKUR- 3 Inch Synergy Stage III Lift, PR44, 1310 Shafts, RROR Skids, 37" MTR's, Warn 9.5Ti, Bumpers, Sliders, OBA, Lights... bla bla bla
LILWB is offline
post #3 of 51 Old 04-26-2013, 02:20 PM Thread Starter
bgall's Avatar
Hmm, maybe I should have gone to Daytona this weekend after all.
bgall is offline
post #4 of 51 Old 04-26-2013, 02:47 PM
They have a rebuild kit for the Currie Johnny joint, that is what synergy uses on their arms, I would double check with synergy but I am sure they are using the 2 5/8" joint. I doubt if you would notice much difference on the ride quality since you already have a clevite joint on the frame end of the synergy arm.
post #5 of 51 Old 04-26-2013, 03:43 PM Thread Starter
bgall's Avatar
I would think the MC joint would take some of the shock and help prolong the life of the clevite. I tore my factory clevite joints up pretty fast wheeling so anything to prolong their live (or avoid them) is a good thing.
bgall is offline
post #6 of 51 Old 04-26-2013, 03:48 PM
cloaked willys's Avatar
I can tell you that they are using the 2.5" JJ in their arms on the adjustable side. The fixed side uses a Clevite bushing. Our 2.5" JJ kit will work in the joint that they use. The downfall is that you will only have an articulating joint on one end of the arm.
http://www.metalcloak.com/2-5-8-D-x2...ade-p/7350.htm
MetalCloak, It's Your Jeep, Only Better
Will (916)631-8071
Originally Posted by -SLADE- View Post
Metalcloak claims to have the highest clearance flat fenders and their Duroflex joints appear to bridge the gap between stock clevite bushings and re-buildable joints making them a great option for daily drivers. Metalcloak's dual rate coils actually backup the available travel in their suspension instead of just making claims of "flex" and "max travel" only to provide short coils with little travel like some have done.
cloaked willys is offline
post #7 of 51 Old 04-26-2013, 04:00 PM Thread Starter
bgall's Avatar
Excellent! Thanks. Getting a quote on the synergy kit from a shop now. Hmm, need to get them to become a MC dealer now.
bgall is offline
post #8 of 51 Old 04-26-2013, 04:15 PM
damon.l's Avatar
downfall?
damon.l is offline
post #9 of 51 Old 04-26-2013, 04:18 PM
Originally Posted by damon.l View Post
downfall?
Yeah, It puts added pressure on the axle brackets. Why wouldn't you want them on both ends?
Will (916)631-8071
post #10 of 51 Old 04-26-2013, 04:34 PM
damon.l's Avatar
not saying your setup isnt nice, it def is, but the jj and "factory" clevite setup is tried and true and used in nearly all aftermarket arm setups and i havnt seen anyone having issues with not enough articulation due to restriction at the joints.
damon.l is offline
post #11 of 51 Old 04-26-2013, 10:46 PM
JohnnyWalker's Avatar
Interesting. You gonna go coilover?
JohnnyWalker is offline
post #12 of 51 Old 04-27-2013, 06:00 AM Thread Starter
bgall's Avatar
Most likely. I have poly 4.5 springs now and the front is noticably lower than the rear. While I do have spacers to put on the adjustability/tunability of coilovers in the front is very appealing. Looking at rebel's front coilover kit with AGM sliders. That should allow me to retain the teraflex speed bumps in the front even though I will have to work out how to handle holding the front bump in place. Probably gonna add a set screw to the jounce tube.
bgall is offline
post #13 of 51 Old 04-27-2013, 06:19 AM
hammerstien's Avatar
Try this...
[email protected]
He's a sales manager
hammerstien is offline
post #14 of 51 Old 04-27-2013, 06:46 AM
unsub's Avatar
Were running There 5.5" on our 2dr Rubi for the last four years no with no problems. Easy install once you get the stock mounts off.
Crew
unsub is offline
post #15 of 51 Old 04-27-2013, 04:53 PM Thread Starter
bgall's Avatar
Since synergy is at jeep beach and I have been hitting teh bourbon... Anyone ever talked to synergy about custom work? I was thinking that the MC spuds and JJ rebuilds would be a pretty sweet setup. It would give misalignment at both ends and help take some stress off the control arm brackets. So is it the bourbon stirring my brain cells or does this seem logical? On a side note, Four Roses bourbon is pretty good.
bgall is offline
post #16 of 51 Old 04-27-2013, 09:38 PM
tiltz's Avatar
I asked about custom length arms when I order my stretch kit and they said no.
tiltz is offline
post #17 of 51 Old 04-28-2013, 07:04 AM
Four roses, Yum. Did you want to add a MC joint at the clevite joint end? I don't think that would be a problem, but would require cutting and welding. That clevite end can be cut off, a threaded plug could be adapted and the joint inserted. Are the lower front/rear poly arms straight? http://www.teraflex.biz/builders-rod...using-nub.html
GatorJeeper is offline
post #18 of 51 Old 04-28-2013, 07:07 AM
If you are going to do that much work just make your own arms. Kinda silly buying new arms and cutting them up.
post #19 of 51 Old 04-28-2013, 07:29 AM
Yup, I was thinking he had the arms allready. Bgall, you could get DOM tubing cut to length, and then use a left hand and right hand threaded end, and you could still adjust with it on the vehicle without the synergy insert gizmo.
post #20 of 51 Old 04-28-2013, 10:27 AM Thread Starter
bgall's Avatar
What I was hoping is that synergy could put the MC ends on in lieu of the clevite end. I know it would have to be during a production run if they even are willing. While the idea of making my own long arms sounds like a fun project, the reality is that I don't have the time or facilities to do it. Not until I get my old vette and firebird sold at least.
bgall is offline
post #21 of 51 Old 04-28-2013, 11:28 AM
RIP Brad
abendx's Avatar
Is the threaded end of the joint the same size (JJ and MC)? If so... you are done, swap in whatever you want.
I also x2 the making your own arms. It is really a trivial thing to accomplish and will allow you to get the right sized arms. I'd guess, if you don't own a welder, it would cost you about one hour of labor... bring him the DOM for extra savings (no double markup).
abendx is offline
post #22 of 51 Old 04-28-2013, 05:34 PM
I believe the synergy uses a left hand thread in their double adjuster and metal cloak ends are all right hand threads. You would have to use the jj rebuild kit from metal cloak to get it in the axle end.
post #23 of 51 Old 04-28-2013, 08:02 PM Thread Starter
bgall's Avatar
Yep, axle end is not a problem. Just have to replace the guts of the JJ. It is the frame end where I was thinking it would be nice to have the MC joints.
bgall is offline
post #24 of 51 Old 04-29-2013, 08:58 AM
cjcraig7's Avatar
I run Synergy adjusters and left handed MC Joints on the rear. Lefts are available....I think short special order wait.
On the front, Synergy doesn't parallel their joints, which allows them to run their adjusters on the front. This design and the value of their adjusters has been discussed in the MC Build Thread.
Cutting a Clevite off and welding a MC barrel on is relatively simple and will definitely help with binding joints, or when replacing worn joints. Though I am with others, hacking up new arms, I would question.
And most importantly, never listen to Damon in Mod Tech, he is the resident special child on anything not having to do with billet fuel doors and interior trim kits.
In some mall crawling JK world, Clevites (OEM) never fail. So Damon (today's official thread crapper), read the title of the thread - if you do not have tech to add to Mod Tech, or you lack the experience to provide an educated opinion, DOC told me to tell you to STFU.
So Forrest Gump: STFU.
cjcraig7 is offline
post #25 of 51 Old 04-29-2013, 09:31 AM
Tried and true? More like tried and fail. Clevite bushings aren't what you want when you leave the pavement. The downfalls of standard Clevite bushings have been well-documented.
The Synergy arms use standard 2.5" Currie barrels so yes, of course the MC Duroflex insert made for that application will work. But you've still got the Clevite bushing on one end. Sell the arms and either build or buy new ones so that you can take advantage of having Duroflex bushings on all ends.
Imped is offline
