Gouges in front axle shafts - JKowners.com : Jeep Wrangler JK Forum
post #1 of 11 Old 04-19-2013, 10:46 AM Thread Starter
M&M's's Avatar
So I took out the front axle shafts to get ready for a truss installation and discovered that both sides have pretty heavy gouges in them. The drivers side is gouged at 4 7/16" in from the end of the spline and the passenger side is gouged 3 1/16" in from the end of the spline.
I haven't removed the carrier to see what might be going on and was hoping maybe someone has seen this before and knows whats causing it before I tear into if any further.
Last time I personally had these out was to install the Nitro sleeves. The gouges weren't there at that time. Since the sleeve install, I had new gears installed around 6-months ago. I wasn't there when they did the gears so I can't say the gouges were or weren't there at that time. I assume (yeah, yeah, I know) if they were that the tech would have pointed it out. Could this have something to do with the new gear installation? It really has me worried now cause I don't want to put anything back together that might cause more damage down the road.
Originally Posted by van7559
I can bury my pinky in the rear, and just barley feel it, the front is a little easier, but still seems low to me!
I fist fuck life with a nuclear powered pneumatic fuck hammer for 60, 70 hrs a week...
M&M's is offline
post #2 of 11 Old 04-19-2013, 10:48 AM Thread Starter
M&M's's Avatar
Here's pic.
M&M's is offline
post #3 of 11 Old 04-19-2013, 11:42 AM
bgall's Avatar
That looks like right about where the seals would be around the shafts. How deep is the "gouge"? I wonder if you have debris that is/was wedge in the seal or between the seal and shaft. When was the last time you changed your diff fluid? If you recall, was it littered with shavings?
bgall is offline
post #4 of 11 Old 04-19-2013, 11:50 AM
bgall's Avatar
Did you do the install of the shafts? Almost looks like someone put "retainers" on them.
bgall is offline
post #5 of 11 Old 04-19-2013, 01:34 PM Thread Starter
M&M's's Avatar
Gouges are only a few thousands. No retainers. I installed shafts originally with original seals. Installed Nitro sleeves last year with no issues that I knew of. Gear install 6 months ago and as I said, I wasn't there so I don't know if the gouges were too.
Last diff oil change was only a few weeks ago and there wasn't any abnormal issue with the fluid.
I'm wondering now if its possible that the tech installed the races and carrier retainers ass backwards. Think that could be the cause. I won't be into the diff until next week to find out.
Sent from my SGH-T989 using Tapatalk 2
M&M's is offline
post #6 of 11 Old 04-19-2013, 07:07 PM
X2 on the seal.
Jeepmods is offline
post #7 of 11 Old 04-19-2013, 07:10 PM
Going with where the seal rides.
post #8 of 11 Old 04-19-2013, 07:26 PM
NascarRubicon's Avatar
Yup. Have those too. Not nearly as bad. But its from my inner seals
"Eat Liquid Gold"
NascarRubicon is offline
post #9 of 11 Old 04-19-2013, 08:12 PM
Seals. Just the way it is. Any sign of oil leaking.
JeepUpKeep37s is offline
post #10 of 11 Old 04-19-2013, 08:58 PM Thread Starter
M&M's's Avatar
Ok, for now I'll assume it's the seals. I'll pull the carrier out once I'm done putting the truss on and see which it actually is. I'm surprised a rubber seal could cut into the metal that bad.
So far the seals seem ok. There really wasn't evidence of a leak. There was a little oil on the shaft but no more than normal and again, no abnormal metal shavings or anything like that during last oil change a couple weeks ago.
Guess what my real concern is, is that when I put RCV's in I don't want them to have a reason to void a warranty in the event there's a problem so we'll see what I find next week when we open the diff up.
Thanks guys for the support. I'll report back next week.
M&M's is offline
post #11 of 11 Old 04-26-2013, 09:33 AM
Catfish's Avatar
Murray...I was cleaning the garage, throwing out my old shaft from the rug rd debacle and saw this! Not deep enough to measure but definately worn like yours! FWIW for those who don't know, stock rig open, d30 shafts that had been out for seals, thats it. 60k before the joint busted. Hope it goes well this weekend!
Catfish is offline
