Carrier Runout - JKowners.com : Jeep Wrangler JK Forum
post #1 of 21 Old 04-17-2013, 03:06 PM Thread Starter
sneck's Avatar
Carrier Runout
So I ordered a yukon grizzly and dropped my jeep off at a reputable shop in the area to get it installed. this shop didnt do the gear install, but here are some pictures the shop sent me of some issues with my diff. Basically, factory spyder gears were chipping, the shims were falling out, and my pinion had lost its preload.
whole album. http://s1278.photobucket.com/user/El...?sort=3&page=1
So the shops cleans up the mess, and goes to do a fresh install with the new locker. cant get a good pattern, goes to check the locker, and finds the case has a runout of .008. so now the shop doesnt want to install the locker because he says itll basically fuck my shit up and i'll be back in no time for the diff to get fixed again.
So I call the place I ordered from, they call yukon, yukon talks to the shop guy and comes back and says they dont think anything is wrong with the locker. is case runout a thing? is yukon fucking me, or is the shop just looking at things wrong?
sneck is offline
post #2 of 21 Old 04-17-2013, 03:21 PM
Chipewa's Avatar
Was your factory setup the one that had chipped teeth and shims falling out? If so you should be taking that crap back to the dealer for a warrenty replacement. I've never heard of a bad housing before but I suppose it's possible. If the housing is bad it would probably have come from the factory that way. What year and how many miles? I have installed gears before and it takes a diff case spreader to set the carrier pre-load. IMO carrier shims aren't loose and don't just fall out unless the install had no carrier pre-load set.
LS3 2007 JKU X - Red Rock, 2012 JKU Rubicon - Deep Cherry Red, 2001 TJ - Black
Chipewa is offline
post #3 of 21 Old 04-17-2013, 03:28 PM Thread Starter
sneck's Avatar
no, i had my jeep regeared at some other shop. so shims are on them, spiders are factory though. jeep has less then 20k on it, was regeared around 10k or so?
sneck is offline
post #4 of 21 Old 04-18-2013, 06:27 AM Thread Starter
sneck's Avatar
bump. carrier runout, is it a thing?
sneck is offline
post #5 of 21 Old 04-18-2013, 07:12 AM
Panamon Creel's Avatar
Well 0.008 runout is a bit hefty and agree that it would cause issues down the road. Would return the locker if it truly is carrier run-out which I kind of doubt.
2010 JKU Sahara
Panamon Creel is offline
post #6 of 21 Old 04-18-2013, 07:16 AM
Jeepineer
JKred07's Avatar
Yes, it's a thing. It would change our backlash as the carrier spins. The idea is your backlash is within a constant 1 or 2 thousandths around the whole ring gear.
A runout of 8 thousandths is equivalent to shifting your carrier shims 8 thousandths, only it happens every revolution. This would throw your backlash out of whack.
Did the shop measure both axial and lateral runout of the ring gear and carrier? If it was 8 thousandths, that's your problem. A housing can't exhibit runout on a carrier, since it rotates on fixed points, it's an issue with the carrier itself.
-Mike
JKred07 is offline
post #7 of 21 Old 04-18-2013, 07:18 AM
Jeepineer
JKred07's Avatar
If they measured carrier runout at 0.008" and the carrier bearing were not shifted in the housing, I don't see how it isn't the carrier, IMO
-Mike
JKred07 is offline
post #8 of 21 Old 04-18-2013, 07:27 AM
The question is how/where they measured the carrier run-out? On the Carrier itself or on the ring gear?
2010 JKU Sahara
post #9 of 21 Old 04-18-2013, 07:30 AM
Jeepineer
JKred07's Avatar
Agreed. 0.008" on both or just the carrier is concerning. 0.008" on the ring gear says they didn't seat it properly.
-Mike
JKred07 is offline
post #10 of 21 Old 04-18-2013, 07:48 AM
Chipewa's Avatar
I agree with this statement 100%. Either a bad carrier, ring gear, or ring gear is not seated on carrier surface flat.
Chipewa is offline
post #11 of 21 Old 04-18-2013, 08:28 AM Thread Starter
sneck's Avatar
shop explained that after they couldnt get a good pattern, they went to check to see if it was the ring gear or the carrier, and checked the carrier first. so its measured on the carrier, not the ring gear
sneck is offline
post #12 of 21 Old 04-18-2013, 08:41 AM
In that case return if you bought it new since IMO that's a carrier out of the reject bin if it really has that much run-out.
2010 JKU Sahara
post #13 of 21 Old 04-18-2013, 10:41 AM Thread Starter
sneck's Avatar
thats my thinking. yukon is insisting their shit dont stink, so instead of sending me a new one, i have to return this one for them to check out before they send me something. normally i would just up and buy a new one and wait for them to credit me, but if theyre already being dicks, i dont want them to claim its used or some bullshit (since it had carrier bearing put on). certainly leaving a bad taste in my mouth
sneck is offline
post #14 of 21 Old 04-18-2013, 11:42 AM
Chipewa's Avatar
This doesn't bode well for Yukon. I didn't even know they made a locker.
Chipewa is offline
post #15 of 21 Old 04-18-2013, 11:47 AM Thread Starter
sneck's Avatar
yeah the grizzly and the zip. zip is like arb, grizzly is like the detroit. i want the grizzly to work out because ive heard its smoother than the detroit is, and stronger. and the warranty is nice too, if the locker blows up, theyll cover the install costs of a new locker.
but them being captain dick heads about it, sucks. the guy at yukon i talked to said "we just dont hear of this type of thing happening, so we want to see it for ourselves" to which i replied "well obviously you dont see it happen often, if you did, you wouldnt have such an amazing warranty cuz shit would be coming back left and right!"
he didnt have a response to that
sneck is offline
post #16 of 21 Old 04-18-2013, 12:17 PM
Personally I find it odd to have such a large run-out on the carrier alone and being a bit skeptical about it. I'll stay neutral in the back on that one since I can't check the run-out myself over the net. Keep us updated on it please.
2010 JKU Sahara
post #17 of 21 Old 04-19-2013, 04:04 AM
Normaly thet measure runout on the back of the ring gear. I've seen a lack of champfer on the ring gear cause the ring gear to not seat and leave a small gap between the carrier and ring gear and misdiagnosed as a bad carrier.
oliver00 is offline
post #18 of 21 Old 04-30-2013, 12:44 PM Thread Starter
sneck's Avatar
so to bump this back up, Yukon called me back after getting the locker back (took long enough). They didn't tell me what was wrong, just asked if I wanted a new one or a refund. So great. They were 100% against sending me a new locker before, and now, they won't tell me what was wrong, theyre just sending me another. Thanks for wasting my time Yukon! hopefully the locker is worth all this bullshit
sneck is offline
post #19 of 21 Old 04-30-2013, 01:19 PM
V8 dreams
jvandy50's Avatar
did you ask them what was wrong or did they just not tell you? i'm looking at rear lockers as my rear LSD was a tad disappointing last time out. and the detroit seems like a good idea, and the grizzly more so if its 'smoother and stronger'...but not if there is issues
2010 Silver JKU
jvandy50 is offline
post #20 of 21 Old 04-30-2013, 01:54 PM Thread Starter
sneck's Avatar
and asked and the guy I was talking to said he didn't know, just that he was told to ask me if I wanted a new one or not
sneck is offline
post #21 of 21 Old 04-30-2013, 03:05 PM
Are you really talking run out in relation to the axis of revolution? It sounds like you are really talking about flatness or perpendicularity to the axis of revolution. Either way would be bad.
HEEPJEEP is offline
