Passenger Rear "Clunk"... Plz help - JKowners.com : Jeep Wrangler JK Forum
post #1 of 21 Old 04-15-2013, 12:54 PM Thread Starter
autenb's Avatar
Well... I've gone throught everything I can think of, and I can't find it. So, I'm going to ask for words of wisdom here.
I have a clunk when I hit bumps in the road. Big and small... even small ones make the noise. It seems to do it on the downtravel.
I see no signs of anything touching or rubbing anywhere in the range of travel with the Jeep on the ground, bouncing on the bumper, or on the lift, raising and lowering the rear-end with a transmission jack. I can't make it duplicate the noise unless I'm driving down the road.
It almost sounds like the wheel is wobbling on the hub, but I KNOW that's not the case or it'd do it all the time, not just when I hit a rough spot in the road. I also went back and removed the little locks off of the rotors and reinstalled my wheels after the shop failed to removed them when they put my aftermarket wheels on.
Things I've checked:
Shocks- The stock ones were all tight and didn't have issues. I replaced them with OME this weekend... clunk still present.
Track bar- Both bolts were tight. Installed Terraflex bracket this weekend... clunk still present.
Sway bar- Links weren't touching anywhere, replaced with 2" longer ones this weekend to compensate for lift... clunk still present.
Bumper- Checked bolts for tightness... clunk still present.
Subwoofer/box- removed and rode around without it in the Jeep... clunk still present.
Brake rotor/caliper clearance- All appears to have plenty of room, and I'm not hearing the noise on the passenger side.
Spring- Its sitting in the factory rubber perch up top, and isn't contacting the body anywhere. I've even rotated it and re-positioned it on the axle to see if it changed anything... clunk still present.
Exhaust- I've gone up under there and pulled/pushed on it and don't feel it rubbing/hitting anything...? The noise doesn't sound like a heat-shield at all. It's more of a clunk, not a tap.
So the problem is in the rear wheel-well area somewhere, but for the life of me, I can't find it.
Thoughts???
autenb is offline
post #2 of 21 Old 04-15-2013, 01:34 PM
Breaker of nice things
merlin4979's Avatar
Could it be your bumpstops?
Do you have a lift/what kind/size/etc.? More detail might be able to help.
merlin4979 is offline
post #3 of 21 Old 04-15-2013, 02:04 PM
ALASHA's Avatar
Drive shaft against the gas tank skid?
ALASHA is offline
post #4 of 21 Old 04-15-2013, 03:10 PM
Check the stock jack that sits in the back...im serious, that thing gets the full effect of each bump and could rattle and clunk. Mine clunks and rattles.
If not, check your control arms
MISHIMOTO IS JUNK
chknkatsu is offline
post #5 of 21 Old 04-15-2013, 03:20 PM
PhrogMech46's Avatar
Check to make sure your rear frame side track bar bolt is not hitting the bumpstop pad
See Garage for Mods
PhrogMech46 is offline
post #6 of 21 Old 04-15-2013, 03:21 PM
greenenvey's Avatar
If you have a lift your driver side rear spring may be hitting your trackbar when you hit a bump if your springs are bowed in the rear
Sent from my DROID RAZR using Tapatalk 2
2010 rubicon. 3.5 rk lift. 37,s. 6.2 Ls3.
greenenvey is offline
post #7 of 21 Old 04-15-2013, 06:08 PM Thread Starter
autenb's Avatar
Well... I'm 90% sure its a bad wheel bearing. when I jacked it up and pulled on the tire in and out it had some movement and something tells me it should not have any. the lug nuts were tight so I took the wheel off as well as the caliper and rotor and the axle actually moved in and out of the housing just a little.
autenb is offline
post #8 of 21 Old 04-15-2013, 06:10 PM
Did you check torque on the axle retaining nuts?
See Garage for Mods
post #9 of 21 Old 04-15-2013, 06:13 PM Thread Starter
autenb's Avatar
The whaaa? Are those the 4 that hold the brake assy to the tube? Yea.. Those are all tight.
autenb is offline
post #10 of 21 Old 04-15-2013, 07:36 PM
They are the 4 nuts that should be torqued down to 45ftlbs that hold you axle shaft to your axle housing. There are another 2 bolts that hold your brake caliper on.
See Garage for Mods
post #11 of 21 Old 04-15-2013, 07:39 PM Thread Starter
autenb's Avatar
Yes. All 6 were very tight. And i retightened the caliper bolts when i was finished
autenb is offline
post #12 of 21 Old 04-15-2013, 07:42 PM
Have you checked your upper and lower shock mount bolts?
See Garage for Mods
post #13 of 21 Old 04-15-2013, 07:43 PM Thread Starter
autenb's Avatar
Checked those first.
I think its the bearings or something.
autenb is offline
post #14 of 21 Old 04-15-2013, 07:45 PM
Yea that's a start and they are easy enough to change with a press.
See Garage for Mods
post #15 of 21 Old 04-15-2013, 07:47 PM Thread Starter
autenb's Avatar
Its under warranty and service contract. I got it close. The dealership can fix the actual problem.
autenb is offline
post #16 of 21 Old 04-15-2013, 07:47 PM
flyingbrian's Avatar
Electrical tape on the door striker? Does it go away when doorless?
A lot of good info so far.
Sent from my i5 using just one thumb and tapatalk
flyingbrian is offline
post #17 of 21 Old 04-15-2013, 07:48 PM Thread Starter
autenb's Avatar
It is not the doors. Any of them. It is very clearly coming from the passenger wheelwell
autenb is offline
post #18 of 21 Old 04-27-2013, 06:30 AM
I'm having the exact same issue. I can not find a cause. I don't think the bearings would make that sharp clunk. Plus you hear that bearing grumbling long before it clunks.
I had about 500 lbs of lawn care crap in the back the other day. Guess what - no clunk. It's definitely in the suspension somewhere. But I'll be damned if I can find it.
Curious to see what you find.
nofender is offline
post #19 of 21 Old 04-27-2013, 10:12 AM
rdlynch2's Avatar
Rear coils unseating and contacting rear track bar maybe?
2008 Black 2Dr 6spd D30/44
rdlynch2 is offline
post #20 of 21 Old 05-10-2013, 09:13 AM Thread Starter
autenb's Avatar
Well guys, after several weeks of having it in and out of the dealership, checking body mount bolts, bushings, and every piece of hardware back there, removing the fender liners... they can't find it.
And as far as the coils coming unseated... I'm going to use a conduit clamp at the top and see if I can't lock it into position.
Or... maybe replace the top rubber piece. -RC doesn't make another rubber isolator. Even their spacer lifts reuse the factory isolator.
autenb is offline
post #21 of 21 Old 05-10-2013, 09:32 AM
spookylynx's Avatar
This drove me crazy for two days before I figured out what it was
spookylynx is offline
