Purchase coming, need opinions - JKowners.com : Jeep Wrangler JK Forum
post #1 of 19 Old 04-14-2013, 05:05 PM Thread Starter
angercrown's Avatar
So it's time for the front lower adjustable control arms.
What's the best to go with, Or what's the best for not a ridiculous price?
Any other input is appreciated before I make a purchase.
I totally take back all those times I didn't want to sleep when I was younger
angercrown is offline
post #2 of 19 Old 04-14-2013, 05:13 PM
Abacabb's Avatar
RK, MC, TF, PP.
2012 Jeep Wrangler - Gecko
3.5" Rock Krawler X Factor
Abacabb is offline
post #3 of 19 Old 04-14-2013, 06:30 PM
just_in's Avatar
Metal Cloak, Rock Krawler
just_in is offline
post #4 of 19 Old 04-14-2013, 08:30 PM
JKO Dickhead
Asmmns's Avatar
RK...or .... RK
Can only provide real world input on RK, but there area few nice options out there !
__________________
CURE SMA !
Asmmns is offline
post #5 of 19 Old 04-14-2013, 08:41 PM
jkoiiiiojk's Avatar
I just installed some metal cloaks on a friends rig and those things were very high quality. Beefy as hell and not a lot of weight. The joints are supposedly some of the best. We will see. Op you probably know the jeep. He's from orchard park.
jkoiiiiojk is offline
post #6 of 19 Old 04-14-2013, 08:42 PM
tiltz's Avatar
I went to home depot and got some threaded pipe and some t fittings and made my own. It was really crazy because I asked the guy in the plumbing department if he had ever heard of anybody making control arms out of plumbing fittings and it turned out that it was very common. He said hardcore rock crawlers came in all the time. He was kind of an expert. He even showed me how to make rubber bushings from dried up gorilla glue. They work amazing!
tiltz is offline
post #7 of 19 Old 04-15-2013, 05:44 AM
M&M's's Avatar
Really??? I have a hard enough time getting building materials from home depot let alone any advice on how to build or fix something and now they are giving advice on how to mod your jeep? Good luck with that...lol
Originally Posted by van7559
I can bury my pinky in the rear, and just barley feel it, the front is a little easier, but still seems low to me!
I fist fuck life with a nuclear powered pneumatic fuck hammer for 60, 70 hrs a week...
M&M's is offline
post #8 of 19 Old 04-15-2013, 08:02 AM
jkoiiiiojk's Avatar
Pics or it didn't happen....
post #9 of 19 Old 04-15-2013, 08:58 AM
oscar the grouch's Avatar
thats how ive been doing it for years. 3/8s pipe will make great sway bar links too
oscar the grouch is offline
post #10 of 19 Old 04-19-2013, 07:20 PM Thread Starter
angercrown's Avatar
Any experience with currie?
post #11 of 19 Old 04-19-2013, 07:32 PM
This is your best bet if you are on a budget. Make sure sure you get the galvanized pipe since you live in Buffalo where they may salt the roads. Tractor supply has heim joints most of the time. They appear to be heavy duty.
I have Teraflex myself. Best of luck to you.
da20captain is offline
post #12 of 19 Old 04-19-2013, 07:53 PM
Aprilfools is a little late! Rofl
JeepUpKeep37s is offline
post #13 of 19 Old 04-20-2013, 08:18 PM
M&M's's Avatar
I have Currie all around. Love em. JJ's are the shit. Would rather have them than any other joint in my opinion. Super easy to rebuild and they last forever and they don't squeak at all.
M&M's is offline
post #14 of 19 Old 04-20-2013, 08:57 PM
tiltz's Avatar
Sorry, I was feeling goofy when I made that last post... I have Synergy adjustable long arms. They are very nice and beefy. Their short arms will be just as nice.
tiltz is offline
post #15 of 19 Old 04-21-2013, 08:19 AM
Cut the bushing off the axle end of the factory arm, weld in a threaded bung, buy a Johnny Joint and a jam nut to complete the adjustable control arm mod.
You should be able to do it for $60 per arm if you can weld.
post #16 of 19 Old 04-21-2013, 09:33 AM
PIG
PIG's Avatar
Thanks for the pimp guy. Here is a link to the Synergy ADJ Front Lowers. Let me know if you have any questions.
Have you actually done this? To get the factory clevite style bushings out of the factory arms is pretty tough to do without totally fucking them up. Gonna have to do that if you want to weld the old end links to some new tube. Also, if you want to make the arms correctly then you should throw a bend in them for tire clearance and ground clearance. We do sell/make all the stuff a guy needs to build a set of arms but you'd have about $250 in materials/fright (W/O double adjuster assembly) to make a pair. Spend an extra $50-$75 bucks and have a set of done ones (W/ Double Adjuster Assemblies) shipped to your door ready to be bolted on. Just sayin...
PIG is offline
post #17 of 19 Old 04-21-2013, 10:18 AM
I don't think you were grasping what I was describing. I was talking about just replacing the axle end with a bung and new joint. Not re using the factory ends on a new tube.
post #18 of 19 Old 04-21-2013, 01:22 PM
M&M's's Avatar
He may have missed it. For someone on a super tight budget that's a great idea. Probably not the strongest arms out there but still a great idea!
Sent from my SGH-T989 using Tapatalk 2
M&M's is offline
post #19 of 19 Old 04-23-2013, 08:26 AM
PIG
PIG's Avatar
OK, so your saying wack the end off a factory arm and graft a bung on the end with a JJ? Sounds like a little less work than what I thought you were saying. You'd prob be into a pair of arms for about $150 once all the parts made it to your front door. Add that to a days worth of work and you might have something that will get you by for a little bit. Been seeing alot of guys noodling up their front and rear lower arms so I'd say its still a ticking time bomb depending on how hard you are wheeling. I think your idea is something to think about regardless though.
PIG is offline
