HD Tie rod/Drag link - JKowners.com : Jeep Wrangler JK Forum
post #1 of 34 Old 04-11-2013, 08:12 PM Thread Starter
woomdawg's Avatar
So I bent my tie rod climbing a snowbank a couple of weeks ago and now i am going to make my own Drag link and tie rod from ruffstuff. this is what I will be using.
http://www.ruffstuffspecialties.com/...g/TREOFFK.html
http://www.ruffstuffspecialties.com/...8X34SET15.html
http://www.ruffstuffspecialties.com/.../15X25DOM.html
http://www.ruffstuffspecialties.com/...4TO58SAFE.html
Now as far as the misalignment spacers go I only need two safety high misalignment spacers, both for the draglink right? One on the Pittman arm and one at the knuckle. Let me know what you think maybe I am missing something.
2007 unlimited X
rough country 4" lift
18" KMC Rockstars
superchips flashpaq
1 ton Offset TRE's with 1.5" X .25" wall DOM tubing Tie Rod
1.5" X .25" wall DOM tubing Draglink with 7/8" hiem's
Adam's Front Driveshaft
woomdawg is offline
post #2 of 34 Old 04-11-2013, 08:32 PM
I just did their tie rod and it is pretty nice and a no brainer for the money.
I will be curious to see the drag link, and how much droop it will handle.
post #3 of 34 Old 04-11-2013, 08:57 PM Thread Starter
woomdawg's Avatar
Do you think I should use these instead?
http://www.ruffstuffspecialties.com/...g/TREDRAG.html
2007 unlimited X
18" KMC Rockstars
superchips flashpaq
woomdawg is offline
post #4 of 34 Old 04-12-2013, 05:32 AM
I would think the heims would have more articulation in them but may be noisy. How much droop are you planning on having?
post #5 of 34 Old 04-12-2013, 06:32 AM
bnb2010's Avatar
I made the ruffs tuff DL for my jeep with heim ends and its very quite. Wish I had done my tie rod as well but I went with the RK tie rod which is stout but a PITA to adjust.
bnb2010 is offline
post #6 of 34 Old 04-12-2013, 06:43 AM
So when you do all this, are going to go with hydro-assist also??
Kind of my plan for my next mod. This stuff looks like it would be up to the task.
JEEPDON is offline
post #7 of 34 Old 04-12-2013, 07:33 AM
What kind of articulation are you getting from it? I might be able to fit 16" travel shocks up front and not sure if the tre on my synergy has enough travel to handle it.
post #8 of 34 Old 04-12-2013, 07:44 AM Thread Starter
woomdawg's Avatar
No hydro planned for this axle. I am not sure how much articulation it has, it is sporting 4" rc lift. So I do not need the high misalignment spacers then? Just the normal ones?
Sent from my DNA.
2007 unlimited X
18" KMC Rockstars
superchips flashpaq
woomdawg is offline
post #9 of 34 Old 04-12-2013, 07:50 AM
bnb2010's Avatar
I haven't had it in any off camber situations since I've done it but from what a friend tells me that has also done it there is no binding of the DL now. I do need to get it in that situation because I think my shocks are going to be what will limit the articulation now
bnb2010 is offline
post #10 of 34 Old 04-12-2013, 08:50 AM
Sent from my DNA.
That would depend on the amount of down travel you have. I would say if you are running up to 10-12" of down travel you would be fine with a tre.
post #11 of 34 Old 04-12-2013, 01:13 PM
Do you have any pictures of the DL? I'm thinking of going this route since the pre-made ones are way overpriced for what you get.
onsafari is offline
post #12 of 34 Old 04-12-2013, 01:17 PM
bnb2010's Avatar
I'll make some tonight
bnb2010 is offline
post #13 of 34 Old 04-12-2013, 01:21 PM
Jeepineer
JKred07's Avatar
I used 3/4" heims and standard misalignment spacers and 3/4" grade 8 bolts when I made my drag link. I have about 5" up travel and 6" down with 2.5" bump stop extension over factory... My heims would bind with another 1/2" of down travel.
A safety washer is essential on any single shear setup that uses heims. If I could do it again I would have gone with 7/8" heims and high misalignment spacers, will need to if I ever get more down travel
-Mike
JKred07 is offline
post #14 of 34 Old 04-12-2013, 03:46 PM Thread Starter
woomdawg's Avatar
Done, just ordered it now plus %15 off with a sale they are having . I cant wait.....now I need to find someone with a welder
2007 unlimited X
18" KMC Rockstars
superchips flashpaq
woomdawg is offline
post #15 of 34 Old 04-12-2013, 07:54 PM
bnb2010's Avatar
Here's a few pics
bnb2010 is offline
post #16 of 34 Old 04-12-2013, 08:06 PM Thread Starter
woomdawg's Avatar
They look like they are holing up great.
Sent from my DNA.
2007 unlimited X
18" KMC Rockstars
superchips flashpaq
woomdawg is offline
post #17 of 34 Old 04-12-2013, 09:37 PM
VKS Fab
JK Vick's Avatar
Here's a few pics
Just a heads up. Since you're running both ends single shear you should grab a couple safety washers. Ruffstuff has a high misalign/safety washer combo unit that will work perfectly.
Handmade One At A Time
GIVE US A CALL 559-392-3145
JK Vick is offline
post #18 of 34 Old 04-12-2013, 09:38 PM
bnb2010's Avatar
Will do
bnb2010 is offline
post #19 of 34 Old 04-12-2013, 09:39 PM
bnb2010's Avatar
Sent from my DNA.
So far so good
bnb2010 is offline
post #20 of 34 Old 04-12-2013, 09:53 PM
DeucesALLin's Avatar
I promise I'm not retarded... BUUUUT-
I am REALLY interested in stuff like this- but I am not really sure how to go about it. Do you guys just order specific componts, or are you blessed with vices and saws and all that good shit?
I ask because I just sumped up to 37's and a sleeved/gusseted/Spartan'd D30. I have been working towards ram-assist, but budget wise I am thinking I would rather run the factory PS setup untill I can adresss TB bracing, CA boxing, TREs, and all the other stuff a noob like me is gonna be surprised can fail.
Is this a recipe/assymbly thing, or are you guys trimming to fit a generic (though beefy) DIY kit?
Soon to be a vendor!!!
Looking for a good Rat Rod JK donor vehicle.
DeucesALLin is offline
post #21 of 34 Old 04-12-2013, 11:03 PM
Blackr6's Avatar
All I used was 1.5" .25" wall DOM. Some thread adapters and 1ton tre's. weld in adapters thread tres in and your done. I like the bein joints also. May consider down the road.
Blackr6 is offline
post #22 of 34 Old 04-13-2013, 07:30 AM Thread Starter
woomdawg's Avatar
For me this is the first time building something like this. I am a automotive dealer technician so I have access to all sorts of tools, but unfortunately I don't have anything to cut the dom properly or a welder. So I am probably going to get my measurements and bring the dom to a fabricator and have them cut and the tube adapters welded. I have a friend that has a friend that does powder coating so he will powder coat the parts for me. I wish I had a house with a garage..... Priority #1 after the wedding in June, I hate living in an apartment. Ramble ramble ramble
Sent from my DNA.
2007 unlimited X
18" KMC Rockstars
superchips flashpaq
woomdawg is offline
post #23 of 34 Old 04-13-2013, 07:51 AM
I would just rattle can paint the tie rod, it will get scratched up pretty quick off road. You will want to touch it up after each off road trip.
post #24 of 34 Old 04-13-2013, 08:50 AM Thread Starter
woomdawg's Avatar
That would save a ton of time.
2007 unlimited X
18" KMC Rockstars
superchips flashpaq
woomdawg is offline
post #25 of 34 Old 04-22-2013, 12:30 PM
Have you got your new steering in yet?
onsafari is offline
