Caster/Toe with 40's? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 11 Old 04-10-2013, 07:58 AM Thread Starter
Hey folks,
Looking for some input on appropriate caster and toe set up for a rig on 40's. I plan to use it for back up daily driving and wheeling.
Unlimited
PR60 Front 68.5"
4" Tera springs with 1" rubber spacer
Currie arms, JKS front track, RE rear track
40" MTR's on TR beadlocks
BigJk is offline
post #2 of 11 Old 04-10-2013, 10:07 AM
tiltz's Avatar
I am sure somebody with 40s can confirm, but I believe the same 4-6 degrees of caster and 1/16-1/8th of toe-in still applies to JKs on 40s.
tiltz is offline
post #3 of 11 Old 04-10-2013, 07:19 PM
I would assume that pro rock was built with caster correction?
post #4 of 11 Old 04-10-2013, 07:34 PM
Slow and Low
Co4Lo's Avatar
I've always tried to hang around 5* Caster. Sometimes 6*. But I run lockout hubs on junkyard one-tons. I would imagine your Prorocks have correction, so you should be happy at 5*
With 40+ tires, I run about 3/16" toe in.
35-37's I run 1/8" toe in.
Co4Lo is offline
post #5 of 11 Old 04-10-2013, 07:40 PM
SoK66's Avatar
It's either Dynatrac or Currie that has an FAQ suggesting a JK with larger tires (37+) should be cool at around 4 - 5 degrees, no more.
SoK66 is offline
post #6 of 11 Old 04-10-2013, 09:25 PM Thread Starter
Yes, caster corrected PR60.
Thanks for the input.
BigJk is offline
post #7 of 11 Old 04-11-2013, 03:41 AM
kjeeper10's Avatar
I've heard caster is less of a issue with bigger tires..... Is there truth to this ?
kjeeper10 is offline
post #8 of 11 Old 04-12-2013, 08:16 AM
dirtyoffroad's Avatar
where is the toe in dimension taken?from the wheels or the tires
dirtyoffroad is offline
post #9 of 11 Old 04-12-2013, 08:20 AM
Tires.
post #10 of 11 Old 04-12-2013, 08:57 AM
Slow and Low
Co4Lo's Avatar
It depends. One thing that people often overlook when they run bigger tires/wheels is the scrub radius.
If you have more scrub, caster symptoms may not be as noticeable because there is more road force keeping the tires tracking. With less, it may tend to wander more.
So it's just a matter of dialing in YOUR setup until it works properly.
Co4Lo is offline
post #11 of 11 Old 04-12-2013, 10:53 AM
kjeeper10's Avatar
Thank you
