Were to put tranny cooler with Ripp sc. ? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 10 Old 04-09-2013, 01:27 PM Thread Starter
greenenvey's Avatar
Im installing a ripp supercharger and need to relocate my b&m tranny cooler. Anyone put one in a dandy spot that it still does its job of cooling well?
Sent from my DROID RAZR using Tapatalk 2
2010 rubicon. 3.5 rk lift. 37,s. 6.2 Ls3.
greenenvey is offline
post #2 of 10 Old 04-09-2013, 01:48 PM
Off Road Warehouse makes a kit that mounts off of the tubular crossmember behind the radiator. The kit is kinda pricey for a cooler. It would be easy to make some brackets to replicate the idea. Not sure on the cooling efficiency.
2009 Rubicon Unlimited: A mix of Teraflex and Currie with a little Poly thrown in, on 36s.
Mo' Doors, Mo' Problems
woody67 is offline
post #3 of 10 Old 04-09-2013, 01:55 PM Thread Starter
greenenvey's Avatar
Thank you, i saw the one you mentioned. I just hate to spend another 250$ for another cooler when i already have one.I'll have to make up some brackets.i just hope it cool tucked away back there.
post #4 of 10 Old 04-09-2013, 02:27 PM
Apt
I Put the FU in FUN
Apt's Avatar
Ripp has a cooler kit as well that sets it up to be able to use a PS cooler and Trans cooler so you can run the intercooler. Try talking to them.
Apt is offline
post #5 of 10 Old 04-10-2013, 12:34 PM
Send a message via AIM to RIPPMODS
Some of our customers have been mounting to the lower radiator support with great success, there are a few threads here discussing it.
RIPP
RIPPMODS is offline
post #6 of 10 Old 04-10-2013, 02:43 PM
Cod
Cod's Avatar
Send a message via MSN to Cod
I did this but rather than weld it to the crossmember i made a clamp system that bolts it on should i ever want to remove it...... and yes its still there...
Cod is offline
post #7 of 10 Old 04-10-2013, 03:10 PM
Slow and Low
Co4Lo's Avatar
Co4Lo is offline
post #8 of 10 Old 04-11-2013, 09:21 PM
ChuckMRN's Avatar
Trany cooler:
Made mine out of aluminium strap. Heated it with torch and bent it in a vice with some angle iron. Used some welding rod as a model for the bends. 2" clamps to hold it to the round cross member.
PS cooler on the bottom for now, see how it goes. There is plenty of room on the two straps behind the rad fan if this doesn't work. When I get my tune and get her running I will flex it out to check the drag link for rub issues on the PS cooler at full Pass stuff.
16 JKU Sport
RK 3.5 X Factor, UD 60's, Atlas T Case 4.3:1,
TR Bead locks with Toyo Open Country MT's,
VKS Bumpers and Sliders. EVO Skins,
PSC Hydro on Synergy Steering,
Fox Shocks and Bumps
"40's Baby!"
2011 JKU RUBI "SOLD"
ChuckMRN is offline
post #9 of 10 Old 04-12-2013, 10:57 AM
GKR
If you trim the back ridges of the grill shell, you can slide the Intercooler forward enough to keep it between it and the radiator.
Or if you use this style you can make a simple bracket and it puts in in the airflow path at the backside of the fan. I did this for a PS cooler.
GKR is offline
post #10 of 10 Old 04-12-2013, 11:17 AM
Cod
Cod's Avatar
Ive seen this done but on mine and many others there just isn't enough room at all....
Cod is offline
