Poison Spyder 50" LED Bar Mount Vibration - JKowners.com : Jeep Wrangler JK Forum
post #1 of 10 Old 04-09-2013, 11:08 AM Thread Starter
aha
aha's Avatar
Hey guys, I have the 50" LED Bar mount with a Rigid 50" E series bar on my Jeep. Since its been installed there is a vibration occurring over 60mph on the freeway. This vibration is coming from the passenger side of the vehicle.
Has anyone seen this issue before?
aha is offline
post #2 of 10 Old 04-09-2013, 01:00 PM
KrawlOff-Road.com's Avatar
Feedback: 37 reviews
We have seen something like this before. What the issue was with ours is that the rubber gasket was to long. The air was going between the frame and the mount, hitting the rubber gasket causing it to flop around. On the inside, sounded like a major vibration! Very big pain. When we installed it on our new 4dr, we cut the rubber gaskets way down and it seemed to fix this issue.
Now, we are getting a TON of noise from our stock soft top with the 50". We didnt have that issue on the older 2dr...
-Jason
Phone: 864-437-8029
KrawlOff-Road.com is offline
post #3 of 10 Old 04-09-2013, 01:55 PM Thread Starter
aha
aha's Avatar
Thanks Jason, I will try to cut the gasket down... the vibration is really loud and quite annoying
aha is offline
post #4 of 10 Old 04-09-2013, 02:43 PM
Yeah, I know! We found "ours" on the 10hr road trip to Jeep Beach last year at 2am! That will keep you up on the interstate!
-Jason
Phone: 864-437-8029
post #5 of 10 Old 04-09-2013, 03:43 PM
bgall's Avatar
-Jason
Hey, at least it kept you awake. When I reinstall mine I plan on using adhesive to attach the liner to the mounts but I am going to cut it so just the major pieces are in contact. The leftover space will be used to run the wiring under the mount.
Now onto a relevant question, single or double row? My single row has noticeable road noise at highway/interstate speed. Happened with both the factory soft top and trek top. Wiring is on the driver side on mine.
bgall is offline
post #6 of 10 Old 04-09-2013, 08:39 PM
If it's a whining noise you can take about 2 inches of silicone in each of the heat sink gaps on both sides and it will go away. You will still have some noise but no whine.
ccjimmyb is offline
post #7 of 10 Old 04-09-2013, 09:04 PM
Blackr6's Avatar
I've had to add some foam strips to my soft top on my four door. If you look there's a tab that rest on the soft top frame. It vibrates and rattles around 55+. Some weatherstripping made it go away.
Blackr6 is offline
post #8 of 10 Old 04-10-2013, 11:33 AM Thread Starter
aha
aha's Avatar
-Jason
Yeah that will for sure keep you awake!
Mine is a E series so its a double row. I get that whine if I angle my LED into a certain position. If I point it slightly down from that position where it whine's the whine will go away. I too have the power cable on the drivers side.
aha is offline
post #9 of 10 Old 04-10-2013, 10:35 PM
ibjammin's Avatar
I had a hell of a noise coming off my light bar with the PSC mounts kinda like a whisle that would change pich at different speeds and found the fix was a cpl of strips of electrical tape wraped from the top fin to the bottom fin eliminated the noise!
ibjammin is offline
post #10 of 10 Old 04-25-2013, 06:25 AM
D5Fire's Avatar
Send a message via Yahoo to D5Fire
Just to update you guys, Rigid came up with a piece to fix the noise with the lightbar, just give them a call and they will mail you the new pieces, the only question asked is what is your address. Found out about it on one of the other places by accident, now Im just waiting on mine to show up.
Fortis cadere, cedere non potest
Poison Spyder BFH w/ trail stinger, custom rear BFH, crusher flares, rocker knockers, evap skid, hood louver. Rock Krawler 2.5 Max Travel, Teraflex rear tire carrier, River Raider cowl snorkel,Warn VR 10,000 lbs winch, sPod, Rigid 50"SR.
D5Fire is offline
