Best coating for skid plates? Paint? Powder? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 21 Old 04-09-2013, 10:03 AM Thread Starter
Keith B.'s Avatar
I just ordered some bare metal skid plates and was wondering what I should do with them as far as coating goes. I am not as concerned about the bottom, since they are going to get beat up, but more the top towards the tranny etc. I was wondering what coating would be the best to get oil and dirt off the easiest. I have a cage that I am going to have painted at a shop, so I was thinking of having the skids painted as well. I am not really too concerned about the price. Thoughts?
07 JKU, 14 bolt rear/ Teraflex 60 front, Tera Long Arm, King Coilovers, 40" MT/R-Ks, Antirock etc. 430HP LS3 engine swap. Cage and 14 bolt swap thread-
Keith B. is offline
post #2 of 21 Old 04-09-2013, 10:10 AM
dukabor's Avatar
I have found coating to be territory dependant....
I know here in the great white north powdercoating can take a beating with salty winters and rocks, I am blasting and repainting my powdercoated armor that took a beating over the last 2 years this year.... if that is a concern for you you may want to paint..... now this is only my front bumper and poison spyder steel flares, everything else seemed to hold up ok.....
hope this helps....
I don't let sleeping dogs lie
dukabor is offline
post #3 of 21 Old 04-09-2013, 10:17 AM
Rattle can.
post #4 of 21 Old 04-09-2013, 11:24 AM
Rattle can the top and bottom. Not sure if its the best but its the easiest and cheapest to replicate. Rust will be your permanent coating. No matter what you put on it it will come off.
78-79 hp 60, 5.38, spool, Reids, high steer
14 bolt, 5.38, Grizzly
37KM2s H2s "street" / 42 Iroks TR beadlocks "trail"
Redneck Ram
Ruff stuff steering
Hacked up Rubicon Express longarms
Welded on EVO corners
Hacked up JCR engine tranny skid
Trail Gear DIY sliders
BUILD THREAD
racker8wr is offline
post #5 of 21 Old 04-09-2013, 11:45 AM
lineX!
fullofdays is offline
post #6 of 21 Old 04-09-2013, 12:14 PM
+1 for line-x!
tor.ryb is offline
post #7 of 21 Old 04-09-2013, 12:23 PM
BumpInTheRoad's Avatar
How does Line-X stand up to being dragged over pointy rocks? I'm sure its strong, but I've not found anything indestructible. I vote for rattle-can or just rolled-on Rustoleum, then sand and touch-up as needed.
I'm a JKO Reject
BumpInTheRoad is offline
post #8 of 21 Old 04-09-2013, 12:30 PM
Gotlime?'s Avatar
I just rattle canned mine. IF you play in rocks, powder would get beat up (not sure about bedliner, but I think it would too) and it would be hard to touch up.
With a rattle can, you can either just hit it again or sand and repaint them whenever you need to.
I used to have a powder addiction, but I got over it. Sliders, skids, etc just get rattle canned. They're going to get beta up and need to be redone. And spray paint is cheap!!
08 Jeep Wrangler Unlimited Rubicon: lift, wheels/tires, bumpers, skids, sliders, winch, lights, cb. All the normal stuff, plus some.......
Build thread:
Gotlime? is offline
post #9 of 21 Old 04-09-2013, 12:30 PM
Ringer's Avatar
Line X tears and peels bad on the rocks. I have seen it rip off of rock rails in huge chunks.
Rust oleum bedliner so you can touch it up.
Ringer is offline
post #10 of 21 Old 04-09-2013, 12:40 PM
bgall's Avatar
I am going to assume they are steel...
Prime with self etching primer then roll on some gatorglide on the outsides. It is easy to touch up and pretty dang slick. Basically it is a silicon epoxy. It wears well but, as any finish will, it will get ripped off on rocks. Nice thing is you can just roll on some touchup. I was quite surprised to see that it was taken off my skids but the primer underneath was left undamaged. Really good stuff. Of course the cheapest and easiest is to simply prime them then rattle can them.
bgall is offline
post #11 of 21 Old 04-09-2013, 12:46 PM Thread Starter
Keith B.'s Avatar
I was more concerned about the coating on the top of the skid. The last skid plates i had used spray paint really got messed up by oil and dirt and were a pain.
Keith B. is offline
post #12 of 21 Old 04-09-2013, 12:56 PM
Rocks don't give two shits what you use--they will remove it. So, spend as little as possible and make touch-up as easy as possible. Rattle can enamel, touch up between runs.
Imped is offline
post #13 of 21 Old 04-09-2013, 01:06 PM
Gotlime?'s Avatar
Not being smart, but why does the top matter? No one can see the top and being dirty isn't going to structurally harm the skids.
Build thread:
Gotlime? is offline
post #14 of 21 Old 04-09-2013, 01:10 PM Thread Starter
Keith B.'s Avatar
I guess the answer is that I hate digging through crap when I go to clean stuff. I just want something where I can take a power washer in there and clean it out. Rattle can just doesn't last long enough for my taste, which is why I was thinking auto paint or something else.
Keith B. is offline
post #15 of 21 Old 04-09-2013, 03:29 PM
Because skids hold mud,water and dirt and can cause rust. I can absolutely see the reason to do this.
I would just splurge and powdercoat it since it wont see direct contact
MISHIMOTO IS JUNK
chknkatsu is offline
post #16 of 21 Old 04-09-2013, 03:30 PM
bgall's Avatar
I did the topsides of my skids in undercoating.
bgall is offline
post #17 of 21 Old 04-09-2013, 04:15 PM Thread Starter
Keith B.'s Avatar
That was my inital thought. Thanks.
Keith B. is offline
post #18 of 21 Old 04-09-2013, 04:32 PM
but i dont know how "flexible" powdercoat is. although it wont see direct contact, if the skid gets bent/caved in, etc. enough i wonder if the powercoating would crack. i've never had anything powdercoated before so it would be nice to know
MISHIMOTO IS JUNK
post #19 of 21 Old 04-09-2013, 04:33 PM
bgall's Avatar
They powdercoat springs. I still would not waste money on powdercoating skids.
bgall is offline
post #20 of 21 Old 04-09-2013, 04:38 PM
damon.l's Avatar
rattle can. shoot a good coat of primer then a coat of whatever color you want. dont waste money on anything else, its just going to get messed up.
damon.l is offline
post #21 of 21 Old 04-09-2013, 05:30 PM
A JKO DICK
ASSFROW's Avatar
My vote is for mud.
ASSFROW is offline
