Super Chips Issue need help - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 04-05-2013, 11:13 AM Thread Starter
Mreddie's Avatar
Angry Super Chips Issue need help
I have the 2010 JKU and bought the Super Chips Vivid PAQ. Unfortunately super chips only has help the hours we all work 9-5 so it is impossible to get help. I have contacted super chips a couple times with no solution yet. The programmer required an update as the directions said it might so OK. During the first update and every update since shortly after connecting it to the computer for the update it does its check and says do not disconnect then I get a "Baud Rate Error", I click ok and it never says it is ok to disconnect. Super chips said not to worry and disconnect it. The additional problem is when I try to program it continually says the programmer must be update. I have updated it numerous times as well as the program on the paq.
Any help would be appricated, is it a bad unit or is this a common problem.
Ed-W
Mreddie is offline
post #2 of 8 Old 04-05-2013, 11:50 AM
JohnnyWalker's Avatar
I talked to Sonny at superchips back when the flashpaq first came out. I got it on a Friday and updated it immediately. I can't remember the specific error I got, but we were able to determine it was a website error.
JohnnyWalker is offline
post #3 of 8 Old 04-05-2013, 12:37 PM
They have a forum on their website. Log in and post your question/problem. Haven't been there in two years or so, but they used to be pretty good about replying.
GreenJK is offline
post #4 of 8 Old 04-05-2013, 12:55 PM
BumpInTheRoad's Avatar
Eddie! Long time no see.
First thing to check is that you don't have any 3rd-party firewalls on your computer that might be blocking the SC Updater. Also try disabling your anti-virus program when you update.
I had trouble updating my SC Flashpaq because the USB cable I was using wouldn't make a good, reliable connection. Switching to a different USB cable that fit the SC's jack tighter solved that problem.
If none of that works then try the SC forum.
Ed-W
I'm a JKO Reject
BumpInTheRoad is offline
post #5 of 8 Old 04-05-2013, 01:52 PM Thread Starter
Mreddie's Avatar
Thanks for the quick replies; I will try the new cable and disabling the firewall. I tried on two different computers but did not think of these possible issues. Thanks. I will let you know how it works.
Been busy with the kids at LAX and Comp Cheer and work has been insane. Looking forward to spring when I should get some me time.
Thanks.
Mreddie is offline
post #6 of 8 Old 04-07-2013, 03:18 PM Thread Starter
Mreddie's Avatar
no luck guys. Got the fire wall and virus turned off and used my phone cord that i know works. Still have same error and am still being told to update the programmer.
Also sent connected to superchips through the website on Thursday. no responce yet,
Mreddie is offline
post #7 of 8 Old 04-09-2013, 09:32 AM Thread Starter
Mreddie's Avatar
Unable to call as I work the M-F 8-4:30 hours they are available (actually 8-6 or later) and the e-mails they send back and forth just say the same things over again as if they don't read what I type. Very frustrating. I guess if you get one that works the customer service doesn't matter.
Mreddie is offline
post #8 of 8 Old 04-09-2013, 10:09 PM
jtphoto JK's Avatar
Try the Superchips Forum. You can ask you question and get an answer back as soon as someone can.
Jeff _(OllllllO)_
jtphoto JK is offline
