Ten Factory rear axle shaft bearings - JKowners.com : Jeep Wrangler JK Forum
post #1 of 22 Old 03-30-2013, 01:07 PM Thread Starter
TCdawg's Avatar
My passenger rear axle shaft bearing crapped out on me. Anyone have a part number for a replacement? I'm hoping this is something that can be sourced local. Heading out on a wheeling trip Friday.
Pulled the diver side and it was fine but I'm going to replace it too since its out.
TC
TCdawg is offline
post #2 of 22 Old 03-30-2013, 01:33 PM
highwayman's Avatar
I don't see why a OEM wouldn't work. Also don't see why a call to Dave at Northridge first thing Mon, won't get u a bearing by tues.
highwayman is offline
post #3 of 22 Old 03-30-2013, 02:18 PM
rdlynch2's Avatar
HOw did you identify the sound you were hearing as a rear axle bearing? For my own curiosity....
2008 Black 2Dr 6spd D30/44
rdlynch2 is offline
post #4 of 22 Old 03-30-2013, 03:28 PM Thread Starter
TCdawg's Avatar
It was a rotational clunk that only came when I was on the gas and started when I took a sharp left turn. When it started on Thursday It sounded like it was coming from the rear DS or axle. I got under the jeep and inspected everything, looking for anything loose or showing contact with something else. The Rear DS is fairly new and all its joints looked normal.
This morning I laid the back seat down and laid down in the back with my ear to the floor in different areas while a friend drove around. By the location of the sound I was guessing an axle bearing. Pulled it and...bingo!
TC
TCdawg is offline
post #5 of 22 Old 03-30-2013, 04:07 PM
Should be stock replacement..
post #6 of 22 Old 03-30-2013, 10:00 PM Thread Starter
TCdawg's Avatar
No reason to ship something overnight, cross country if I can get it local. If its an OEM bearing, I've got jeep dealers right here.
TC
TCdawg is offline
post #7 of 22 Old 03-31-2013, 08:05 AM Thread Starter
TCdawg's Avatar
Measured the OD of the stock axle shaft at the bearing collar, 1.563"
Measured the OD of the Ten Factory shaft, same thing, 1.563
The OD of the bearing has obviously got to fit in the stock axle tube.
I guess the answer to the question, as some have mentioned, is OEM bearings or like sized aftermarket will fit.
I just wasn't sure if the OD of the Ten Factory shafts were the same as the stock shafts at the bearing. They are...so I'll rock on with OEM sized bearings. Looks like NAPA has some as well.
TC
TCdawg is offline
post #8 of 22 Old 03-31-2013, 08:42 AM
FireTrail741's Avatar
I just bought mine at the local dealership when I replaced everything in my axles. It didn't hurt much!
FireTrail741 is offline
post #9 of 22 Old 03-31-2013, 08:44 AM Thread Starter
TCdawg's Avatar
Did they have a kit that included the seals, bearings and bearing retainer or was everything individual?
how much...looks like Napa has them for $49.99 but that is just the bearing and retainer, no seal
TC
TCdawg is offline
post #10 of 22 Old 03-31-2013, 08:57 AM
SoK66's Avatar
I lost both rear seals after a ham fisted tech pulled the shafts during a re-gear . Northridge David fixed me up w/everything. You'll have to drill and break the collars, then use a bearin separator to pull from the retainers inward. Careful who u farm it out to if that's necessary, hacks abound.
SoK66 is offline
post #11 of 22 Old 03-31-2013, 09:03 AM
I bought the seals separate. The retainer came with the bearings. And yes, you have drill and cut the old retainers off.
post #12 of 22 Old 03-31-2013, 09:05 AM
Agree 100%!
post #13 of 22 Old 03-31-2013, 09:20 AM
it probably broke from the weight of that new cage and corner armor. I would part it out.
Lawton is offline
post #14 of 22 Old 03-31-2013, 09:23 AM Thread Starter
TCdawg's Avatar
I'm sure that is just exactly what happened...I'll let you know when the part out starts...
TC
TCdawg is offline
post #15 of 22 Old 04-01-2013, 05:42 AM Thread Starter
TCdawg's Avatar
Local jeep dealer; bearings $57 and Seals $23
Moparonlineparts.com; bearings $39.99, Seals $16
Local Napa; bearings $23(OEM) or $49(napa gold), Seals $23
I have a time constraint so I am not going to try and rush ship via moparonline. I am going to hit up Napa. They also have a machine shop and will press the bearings on.
TC
TCdawg is offline
post #16 of 22 Old 04-01-2013, 06:38 AM
Good information right there.
post #17 of 22 Old 08-27-2013, 01:33 PM
XJhammer's Avatar
Sorry for the dumb question... but do bad bearings look like this?
When i pull out my old shafts both bearings looked like this.
Also i have a noise comming from my rear axle, and the bearing was seperated like this.
Thanks,
08' Rubi 4-door. Baby Hauler, even in 2ft of snow...
3.5" Rock Krawler, and 35's.
94' XJ 4.5" RE OX front and Rear, 33's
XJhammer is offline
post #18 of 22 Old 08-27-2013, 02:42 PM Thread Starter
TCdawg's Avatar
Thanks,
That picture doesn't really show much. If your bearing pulls away from the axle shaft at all as you are spinning it or is wobbly and not a clean tight press fit on the shaft then they are bad.
TC
TCdawg is offline
post #19 of 22 Old 08-27-2013, 09:15 PM
Quacktacular's Avatar
Just a heads up for those of you that live in areas that don't have great parts stores or the prices are insanely high, Amazon carries timken bearing sets that can be had for a good price.
I had to replace a couple of rear wheel seals in 2011 on my '04 rubicon. Of course to replace the seal you need a minimum of a new retainer, probably a bearing too. So I shopped locally (Moab) and found the bearing and seal for about $85.
Amazon carried the same Timken SET10 bearing and retainer set for $30.33 and the Timken seal (9912S) for $16.32.
I believe the same set and seals are used on the D44 in the JK as well. Current pricing looks to be $29.93 and $15.22!
http://www.amazon.com/gp/product/B00..._ya_os_product
Jason - KB0WLI
2008 Black JKU Rubicon
RIPP Stage 2, RockHard Bumpers, RockKrawler 3.5" X-Factor & Fox 2.0's, Nitro Sleeved, Artec Trussed & Gusseted, Synergy DL Flip, Energy green Spyder Louvers, 37x12.50-17 Falken Wild Peaks wrapped around 17x9 XD Addics
Quacktacular is offline
post #20 of 22 Old 08-28-2013, 11:03 AM
Abadjeeper's Avatar
I had the same clunk with a set of G2's which I think are the same shafts. G2 warrantied them since the shafts were only 3 months old. I had a brand new set of Superiors so I just put them in and the G2's will be my spares now.
Abadjeeper is offline
post #21 of 22 Old 08-28-2013, 11:08 AM Thread Starter
TCdawg's Avatar
G2 warrantied a shaft due to a bearing issue? That is a little weird but pretty cool for you.
TC
TCdawg is offline
post #22 of 22 Old 08-28-2013, 11:36 AM
Northridge4x4's Avatar
Standard Set 10 Bearing and seal. Should be able to pick it up at any auto parts store.
David
Free shipping on all orders over $70
Northridge4x4 is offline
