Superchip for manual trans - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 03-28-2013, 09:12 PM Thread Starter
Hercmech's Avatar
What will a superchip do for 2009 JK unlimited manual trans with 4.56 gear and 285/75R 17 Toyo A/T II tires? When going up on inclines in 6th gear at 65 mph with foot to floor doesn't seem right. I'm starting to think I have power trans / engine problems?
Rob Hunter
Hercmech is offline
post #2 of 9 Old 03-28-2013, 09:31 PM
rdlynch2's Avatar
Downshifting will help.
6th is an overdrive gear. Having to downshift every once in a while when going up steep hills at speed is perfectly normal. People seem to believe JKs should be able to accelerate uphill in 6th gear going 10mph. You dont have engine/tranny problems. A superchips would help somewhat with power gains.
2008 Black 2Dr 6spd D30/44
rdlynch2 is offline
post #3 of 9 Old 03-28-2013, 09:39 PM Thread Starter
Hercmech's Avatar
Yea, I do to maintain. 5th doesn't have much power as well.
Rob Hunter
Hercmech is offline
post #4 of 9 Old 03-28-2013, 09:42 PM
Fklein6768's Avatar
I have an 08 w a six speed and i dont have power in any gear....
Is this thing on?
www.4x4s-pod.com
Fklein6768 is online now
post #5 of 9 Old 03-28-2013, 09:49 PM
Blackr6's Avatar
I have a 10 jku six speed and adding the superchips was a noticeable difference. Not going to say a power difference but definitely drive ability. Hard to explain but with your tire change and gearing change you should definitely pick one up.
Blackr6 is offline
post #6 of 9 Old 03-28-2013, 09:50 PM
kkuntz01's Avatar
Rob Hunter
We had an '09 2dr 6spd Rubi that I used a Flashpaq on. It was bone stock but using the Flashpaq on Tow Tune and running it on 91 octane improved seat of the pants feel. The Jeep was my wife's before it was mine, she hadn't driven it in forever and took it out sometime after I flashed it. When she came back she asked what I did to the Jeep because if felt like it drove better, like it didn't struggle road.
In a nut shell, whether the Flashpaq or other tuner, it's worth the money.
Side note, are your tires Load Range C, D or E? Do you know how much they weigh? For what ever reason I'm thinking because they're Toyo's that they are a heavy tire and that is certainly working against you even with a re-gear.
kkuntz01 is offline
post #7 of 9 Old 03-28-2013, 09:56 PM Thread Starter
Hercmech's Avatar
Even worth it with a manual trans?
Rob Hunter
Hercmech is offline
post #8 of 9 Old 03-28-2013, 10:03 PM
kkuntz01's Avatar
Rob Hunter
IMO, yes.
You can play around to see what works best for you, but I ran the tow tune the entire time I used it. To me it was noticeable rowing through the gears, it did seem to struggle as much, especially in first and second gears. Up top, no matter what you'll need to down shift on any grade. Heck I get that now in our '12 Rubi with a 6sp.
kkuntz01 is offline
post #9 of 9 Old 03-29-2013, 04:52 AM
6th gear is an overdrive gear, it's not intended for accelerating, rather maintaining a speed...Any other V6 vehicle would downshift. Regearing is torque multiplication, it doesn't add a lick of horsepower. So when you're regearing you trade rpm for speed [mph], it will generally drive better..but you really aren't going to accelerate much faster.
Consider regearing when it comes to 1/4 mile racing, when changing nothing else, is usually dead equal elapsed times. Where the re-gearing picks up the low end/hole shot, the lack of shifting and long end mph of the non-regeared run will be faster. You aren't making any more power. Regearing gives the feeling of speed because the low end torque and the engine making more noise, but the mph isn't there any more for the same given rpm...however that's what makes it better for crawling and "normal" driving.
