Body lift or coil spacers? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 03-26-2013, 10:05 AM Thread Starter
upalms's Avatar
OK I have a 4.5 inch lift and just went to 40's, I did the trimming in the back, pinch seam etc, and moved the rear back 1" with new upper and lower control arms, in the front I went with 1.5 " spacers. The backs not bad, but I'm still getting a rub in the front. I have a set of 1" coil spacers on the bench, but I'm wondering if a 1" BL may be the way to go.
Thoughts and opinions welcome
Todd
2007 Unlimited
Cree Light Bar
7.5 Long Arm Lift
Synergy Front Suspension
Artec Front JK Armor
5:13's
Tom Woods Drive Shafts
Hi-Lift & Much More
2000 TJ
6" lift
37 TOYO MT's on Worx Rims
$hitty Built bumpers
Air Raid
Corbeau Baja RS seats
upalms is offline
post #2 of 6 Old 03-26-2013, 10:09 AM
Breaker of nice things
merlin4979's Avatar
Where are you rubbing in front?
merlin4979 is offline
post #3 of 6 Old 03-26-2013, 10:19 AM Thread Starter
upalms's Avatar
Seems right now I'm rubbing in the back of the wheel well opening, on the stock steps, I extended the stops so no hitting the frame.
I'm also going to post about cutting the area behind the wheel
Todd
2007 Unlimited
Cree Light Bar
7.5 Long Arm Lift
5:13's
Hi-Lift & Much More
2000 TJ
6" lift
Air Raid
upalms is offline
post #4 of 6 Old 04-02-2013, 12:53 PM Thread Starter
upalms's Avatar
Any more input guys??
Todd
2007 Unlimited
Cree Light Bar
7.5 Long Arm Lift
5:13's
Hi-Lift & Much More
2000 TJ
6" lift
Air Raid
upalms is offline
post #5 of 6 Old 04-02-2013, 12:59 PM
Can you post pics of what you trimmed already? It'll help. Are you rubbing while turning or all the time? Some guys I've seen have to trim the frame on the front because they rub bad. My 37's rub with 4" BS at full turn
IMO I'd go with coil spacers. Almost everyone I've talked to in person that's done a body lift wishes they hadn't. Plus coil spacers are just so much easier to deal with IMO.
I'm running aluminum coil spacers from Rokmen. I had teraflex before, but they're polyurethane and were warped to the point that they did nothing after about 2 months. Check out Rokmen.com they're cheap and you can get them in 1/2" increments from 1/2" - 2.5"
And yeah, we might be a touch rough round the edges, but Jeeple are good people.
Rooster454 is offline
post #6 of 6 Old 04-02-2013, 07:45 PM
bfj aka tambil's Avatar
Really depends on exactly where your front tires are rubbing.
I have a 1.25" body lift and 6" Tereflex LCA
I still rub on the frame at full turn. But it doesn't bother me, its only a little. (42" tires on 4.5 back spaced rims, with 1.5" spacers)
Be a little more exact about what is rubbing, and what you want to accomplish.
Proud to be an American
Shamed of our government
Native Floridian = MUD
bfj aka tambil is offline
