coolers behind radiator - JKowners.com : Jeep Wrangler JK Forum
post #1 of 15 Old 03-25-2013, 06:38 PM Thread Starter
Ok, last year I put the PSC Hydro assist on. So I have to run a cooler with their pump. No biggie. I already had the B&M trans cooler on. Last year engine temps would top out at 224 and then go back down. I don't want to do that again this year.
So my thinking is to put the PS cooler behind the radiator with a fan. Going to be a derale with their built in temp sensor so that it will kick in at 180 degrees. And then just leave the trans cooler where it was originally mounted. I will be running brackets off the engine for the top support and a bracket to the round crash bar on the bottom for support.
Any concerns complaints, moans, bitches? I know where Doc put his at but I have the stock airbox right there and Derale doesn't make a small enough cooler with fan to fit there.
post #2 of 15 Old 03-25-2013, 07:11 PM
bthomas's Avatar
here's where mine is located. welded 2 flat tabs to the round crossmember.
bthomas is offline
post #3 of 15 Old 03-25-2013, 07:30 PM Thread Starter
Nice but I don't want heat sinks I want at least one of these bad boys. I tend to over engineer shit all the time.
post #4 of 15 Old 03-25-2013, 10:41 PM
ibjammin's Avatar
It's not a good idea to mount anything to the motor and chassis unless you have solid motor mounts?
ibjammin is offline
post #5 of 15 Old 03-26-2013, 05:07 AM
gold knight's Avatar
Look at bodyguy's setup in the write-up library, it might be right up your alley. Check the index under cooling.
gold knight is offline
post #6 of 15 Old 03-26-2013, 05:16 AM
FireTrail741's Avatar
I would say not the best idea to mount it behind the radiator. To much hot air given off from the radiator. Not the best cooling air even with a fan. IMO
FireTrail741 is offline
post #7 of 15 Old 03-26-2013, 06:40 AM Thread Starter
But I would rather have it behind the radiator fan with its own fan running than sitting in front of the radiator with no fan.
post #8 of 15 Old 03-26-2013, 06:57 AM
Fan or not, the heat exchanger is only as effective as the air it's pulling through. If you're behind the radiator pulling in 150*+ air, it can't exchange much heat and will be substantially less effective.
That would be an over-engineered part choice in an under-engineered location. Seems like you are pretty hell bent for glory with that location..have at it.
post #9 of 15 Old 03-26-2013, 07:12 AM Thread Starter
Not hell bent on that location. Just can't find another spot for a cooler with fan.
post #10 of 15 Old 03-26-2013, 07:36 AM
Got any extra skids you can put it above?
post #11 of 15 Old 03-26-2013, 07:41 AM Thread Starter
Interesting.
post #12 of 15 Old 03-26-2013, 08:06 AM
https://www.jkowners.com/forum/showthread.php?t=20702
post #13 of 15 Old 03-26-2013, 08:44 AM Thread Starter
I saw that yesterday before I posted this thread.
post #14 of 15 Old 03-26-2013, 11:14 AM
Rottenbelly's Avatar
Probably not the answer your looking for but hood vents helped a ton with my underhood temps.
Plus I'm running a 6.5 spal fan to pull air out.
You smell that?
Rottenbelly is offline
post #15 of 15 Old 03-26-2013, 11:49 AM Thread Starter
Did the poison spyder louvers a couple of months ago.
