What else to lift 4 inches and throw on 37's? (List of things to buy) - JKowners.com : Jeep Wrangler JK Forum
post #1 of 13 Old 03-18-2013, 12:13 PM Thread Starter
frostymarine's Avatar
I have a 2 door manual trans sport jk, i am looking to lift it 4 inches and throw on 37's. I do not want any problems with this lift and want peace of mind, is there anything else to recomend? Anything to change? Any thoughts? I am using this jeep as my daily driver as well.
RUGGED RIDGE ALUMINUM WHEELS 17" X
9" SATIN BLACK 214.99002007-2013 Jeep Wrangler JK &
Wrangler Unlimited JK
BF GOODRICH MUD TERRAIN T/A KM2 TIRE 405.990037x12.50R17*
FULL TRACTION,4" PREMIUM PLUS
SUSPENSION SYSTEM WITHOUT SHOC 1789.99002007-
http://www.jeep4x4center.com/full-tr...-ftsk7158.html
FULL TRACTION CRC LINK CONVERSION,
LEFT HAND DRIVE
PUREJEEP, FRONT AXLE KNUCKLE GUSSET
SET FOR DANA 30
TERAFLEX CV DRIVE SHAFT - FRONT
TERAFLEX CV REAR DRIVE SHAFT (2
DOOR)
TERAFLEX VSS 9550 SHOCK ABSORBER
KIT, SET OF 4, 3-4" OF LIFT
TERAFLEX HD VSS STEERING STABILIZER
frostymarine is offline
post #2 of 13 Old 03-18-2013, 12:27 PM
New gears?
RocketCityRubi is offline
post #3 of 13 Old 03-18-2013, 12:29 PM
kmd Garage's Avatar
Upgrade your ball joints
You are going to need some shocks
kmd Garage is offline
post #4 of 13 Old 03-18-2013, 12:31 PM
Breaker of nice things
merlin4979's Avatar
Two door or 4 door? You don't necessarily have to lift your JK 4 inches to clear 37's (unless you want to)
But I'd definitely agree with the gears comment above.
merlin4979 is offline
post #5 of 13 Old 03-18-2013, 12:36 PM
TCdawg's Avatar
chromo axle shafts, front and rear
I bent a stock rear flange on my first wheeling trip with 37's and twisted it as well. When I pulled the shaft out I was really surprised how much the stock shaft twisted without breaking...but that won't last long.
4" of lift is a lot on a 2dr. You could do 2.5 and flat fender flares
what is the backspace on those wheels?
TC
TCdawg is offline
post #6 of 13 Old 03-18-2013, 12:39 PM
With a 4" lift you’re going to have a big bump steer (death wobble) problem. Make sure your track bar and drag link stay parallel to each other. When I did my 4" lift, I got the JKS track bar bracket which not only moves the track bar up, it provides backbone support and relocates the steering stabilizer. I then had to get the Teraflex draglink flip kit, these two together fixed my death wobble completely. Also I got the Teraflex rear trackbar bracket. Without these brackets or welding whatever brackets you do get, you will run the risk of ripping the stock trackbar brackets off the axle. I ran 37s on a locked D30 for 2 yrs before I upgraded to a D44, no major issues. Get trail spare axle shafts.
azjeepN is offline
post #7 of 13 Old 03-18-2013, 12:41 PM
This for sure!
azjeepN is offline
post #8 of 13 Old 03-18-2013, 01:09 PM
PIG
PIG's Avatar
LEFT HAND DRIVE
SET FOR DANA 30
DOOR)
Looks like a pretty solid build... Might want to do some more research on the suspension kit though. Looks like a pretty incomplete kit for 4"
Originally Posted by RocketCityRubi View Post
New gears?
Yea, 37's are gonna really bum you out if you don't change the R&P's out. 5.13's or 5.38's would be my recommendation.
YUP but prob not right out of the gate. Might want to look at that and front inner sleeves, C-Gussets at the same time you do BJ's but do it before you trash the front end. AS far as shocks go I'd look at the Fox stuff, its good and can get as crazy as you want as far as performance/price.
Fox Performance Series
Fox Factory Series
Yup... a 3" kit/3" bumpstop extesions with aftermarket flares will clear 37's. Running that same set up right now on out 12' build.
Agreed... The front and rear shafts will have issues with 37's. RCV makes some nice stuff. The rear axle listing seems to not be listed on our site now but I have our IT department looking into it now but are $1500 for the pair. Give us a call if you want some more info.
YES... Any thing over a 3" kit should be addressing the steering issues with some sort of high steer/axle side trackbar relocation kit. Here is a link to the one we make at Synergy. Using just an adjustable trackbar aint gonna cut it.
PIG is offline
post #9 of 13 Old 03-18-2013, 03:39 PM
TeraFlex's Avatar
LEFT HAND DRIVE
SET FOR DANA 30
DOOR)
Sorry, TeraFlex stopped offering JK driveshafts last month. Take a look at JE Reel/Adams or Tom Wood's. Here's a TeraFlex 4" Kit that is more complete http://www.teraflex.biz/jk-4-suspens...rm-system.html
801-713-3314
TeraFlex is offline
post #10 of 13 Old 03-18-2013, 04:03 PM
PIG
PIG's Avatar
Originally Posted by TeraFlex View Post
Sorry, TeraFlex stopped offering JK driveshafts last month. Take a look at JE Reel ...[/url]
JE Reel has always done us right....
Here is a link to some stuff @ frostymarine
JE Reel
PIG is offline
post #11 of 13 Old 03-18-2013, 04:32 PM
RIP Brad
abendx's Avatar
Big fan of Coast for driveline needs. They are a tad on the expensive side, but as they say, you get what you pay for. As far as I know, they are on of the only major driveline shops that refuse to use any Chinese parts as many places are doing to reduce costs. Plus... I beat the fuck out of mine and never had an issue.
abendx is offline
post #12 of 13 Old 03-26-2013, 11:26 AM
Busa Dave's Avatar
I am doing everything I can think of to mine on Thurs and Fri to get it ready for the ranch in NM. The one thing I did not see mentioned yet is the new Fox Performance Series Adjustable Through Shaft (ATS) steering stabilizer. Got mine in for the install and must admit it is going to be fun to see how well this dude works! It has 24 clicks of adjustments------I guess if you wanted to-----make it real stiff for running off road and then dial it back down for the hwy..
This is my first Jeep but have run highly modified trucks my whole life and the death wobble thing concerns me so am making sure that everything is right so it will not happen.
2013 Rubicon
2014 Denali 6.2L
NRA Life Member
Busa Dave is offline
post #13 of 13 Old 03-26-2013, 12:00 PM
Norm's Avatar
Take a look at our Adams Driveshafts. Only $665 for front and rear. If you want to upgrade to a solid Spicer u-joint then they come in at $735 front and rear. Adams only use parts made in the USA by Neapco and Spicer.
http://stomperoffroad.com/jk-front-r...ive-shaft.html
We can also put great package deals together if you would be interested in a TeraFlex, Synergy, or Rock Krawler lift.
STOMPER Off-Road
Norm is offline
