Notching/Grooving the Housing For ARB/RCV install - JKowners.com : Jeep Wrangler JK Forum
post #1 of 17 Old 03-13-2013, 12:12 PM Thread Starter
Jeepineer
JKred07's Avatar
I tried searching this but didnt come up with much of anything. I've been seeing some posts floating around about grooving the housing on a Rubicon front 44 when adding RCV's and an ARB locker to keep pressure down and prevent blowing out seals.
Example:
Also, another tip is to notch the bearing channel inside of the axle housing to allow oil drainage. If not, pressure will build and gear oil will seep though inner axle seals -> this is mainly for the long tube side
Can someone elaborate on this? Specifically how to go about adding grooves and where to add them, and maybe what the purpose is? (I know it has something to do with oil pressure ).
Thanks in advanced.
-Mike
JKred07 is offline
post #2 of 17 Old 03-13-2013, 12:37 PM
Where did you see those posts at?
post #3 of 17 Old 03-13-2013, 12:54 PM Thread Starter
Jeepineer
JKred07's Avatar
https://www.jkowners.com/forum/showpo...2&postcount=12
I found a few other post in random threads, that one seemed the most on topic tho....
-Mike
JKred07 is offline
post #4 of 17 Old 03-13-2013, 01:08 PM
I don't have the ARB locker but I have been running RCV's for over a year and I have no leak issues.
post #5 of 17 Old 03-13-2013, 01:11 PM
rdlynch2's Avatar
Does ARB recommend it?
I would contact them. ARB is quite possibly the best company I have ever dealt with customer service wise. Incredibly helpful. They will tell you everything you need to know.
[email protected]
2008 Black 2Dr 6spd D30/44
rdlynch2 is offline
post #6 of 17 Old 03-13-2013, 01:20 PM Thread Starter
Jeepineer
JKred07's Avatar
I've been trying to find the install instructions for days now while I wait for everything to come it. That's how I've stumbled across these "notching" comments....
-Mike
JKred07 is offline
post #7 of 17 Old 03-13-2013, 01:42 PM
yes im pretty sure that was stated in ARB's instructions. i know it was specified in mine.
MISHIMOTO IS JUNK
chknkatsu is offline
post #8 of 17 Old 03-13-2013, 02:07 PM
Chipewa's Avatar
The notching is outlined in the arb locker installation instructions. Instead of notching I drilled oil drain back holes in mine. It is necessary to have some way for the gear oil to return to the housing from the axle tubes or you can run low in the diff and put too much oil into the axle tubes.
LS3 2007 JKU X - Red Rock, 2012 JKU Rubicon - Deep Cherry Red, 2001 TJ - Black
Chipewa is offline
post #9 of 17 Old 03-13-2013, 06:20 PM
bthomas's Avatar
there is a pic in the arb instructions that shows if your housing doesnt have drain holes in the right spot, they should be added. the right spot being behind the carrier bearings where the tube meets up to the housing.
bthomas is offline
post #10 of 17 Old 03-14-2013, 06:18 AM
rdlynch2's Avatar
Did you add it when you installed your arb?
rdlynch2 is offline
post #11 of 17 Old 03-14-2013, 06:39 AM
rdlynch2's Avatar
I just checked my install instructions, it states...
Some salisbury axles were manufactured with poor oil drainage between the axle tubes and the differential housing. This can often result in one of the axle tubes filling up with differential oil while running. In most cases this will result in a blocked air vent which will cause the differential housing to pressurize and expel oil from the axle seals at the wheels or force oil into the air system of the Air Locker, eventually expelling oil at the solenoid valve.This is a design flaw which was corrected by most automakers in the later releases of their axle assemblies.
Does this mean our Dana's have this corrected design flaw? I did not look at where the tubes meet the diff housing close enough to determine if the oil drain locations were appropriate or not.....but I assumed they were being that ARB is referring to older axle assemblies. Plus, the install directions ARB supplies currently, are pretty dated...
rdlynch2 is offline
post #12 of 17 Old 03-14-2013, 06:50 AM
tcodjk's Avatar
On my 07 I had to open up the rear housing to drain out of the tubes.
07 unlimited LS 6.2 6l80 auto 3" black diamond 37" TOYO MT Trailready beadlocks arb's frt & rear
tcodjk is offline
post #13 of 17 Old 03-14-2013, 06:53 AM
rdlynch2's Avatar
On a side note, did any of you actually have to use a diff housing spreader during removal/reinstallation, to set carrier bearing preload?
I have never heard of anyone actually using one before as the instructions indicate.
Complete derail, I know, sorry
rdlynch2 is offline
post #14 of 17 Old 03-14-2013, 07:09 AM Thread Starter
Jeepineer
JKred07's Avatar
Ah, ok... Sounds like this pertains to the rear axle where fluid flows between the differential and tubes.
I will be installing this in the front (and I had stumbled across my initial quote on a thread discussing FRONT applications). This notching appears to balance pressure between the tubes and the housing but in the front I don't want fluid in the housing getting into the tunes, so I would assume this doesn't apply in a front application, given my breather is in the housing anyway as well?
-Mike
JKred07 is offline
post #15 of 17 Old 03-14-2013, 07:10 AM Thread Starter
Jeepineer
JKred07's Avatar
I'm going to do everything I can to not use one, but I have heard of people using one for ARB's to get their high preload recommendation.
-Mike
JKred07 is offline
post #16 of 17 Old 03-14-2013, 07:21 AM
rdlynch2's Avatar
Yeah, its a 500 dollar tool. I would imagine that if it was a real problem not using it, that just about everyone with an ARB would have worn carrier bearings!
rdlynch2 is offline
post #17 of 17 Old 03-14-2013, 01:19 PM
Chipewa's Avatar
Yep, I used the diff spreader to install ARBs front and rear. IMO it's the only way to get the carrier bearing preload correct without destroying the shims.
$240 with free shipping.
http://extremecustomparts.com/i-2878...-lower-48.html
Chipewa is offline
