Rubicon Gears Where to buy - JKowners.com : Jeep Wrangler JK Forum
post #1 of 16 Old 03-12-2013, 07:44 AM Thread Starter
So I have a 2007 unlimited rubicon and just upgrated to recentered H1 rims and 37 in tires. I now need to get some gears. I am wondering who has best prices, and best quality? I know that best price doesn't always mean best quality, and will be looking for somewhere in the middle.
I have an auto, but it is my daily driver, with occational wheeling, so I have been trying to decide between 4.88 and 5.13 and 5.38.
All suggestions are welcome.
neil.cross is offline
post #2 of 16 Old 03-12-2013, 07:47 AM
ALASHA's Avatar
I would go with 5.13s and Yukon gears.
ALASHA is offline
post #3 of 16 Old 03-12-2013, 07:52 AM
JKO Dickhead
Asmmns's Avatar
I have a 07 JkU X - w 35'd. Just went with Yukon 5:13'd from stock 4:10's.
Day and night, and will be even better when I go with the 37's
__________________
CURE SMA !
Asmmns is offline
post #4 of 16 Old 03-12-2013, 08:21 AM
The Wheelin Man's Friend
RiverCityOffroad's Avatar
Feedback: 60 reviews
I'd go 5.13s too.
I can offer you front and rear G2 or Yukon at $550 delivered with master install kits. Either way you go the install kits include Timken Bearings which most prefer.
Happy to help if I can.
Marcus
RiverCityOffroad is offline
post #5 of 16 Old 03-12-2013, 11:01 AM
Here are some charts, don't where they originally originated from, but, make sure you match your engine & tranny to the proper chart..
https://www.jkowners.com/forum/showth...=1#post1463363
UP N OVER is offline
post #6 of 16 Old 03-12-2013, 11:14 AM
damon.l's Avatar
i purchased a 5.13 kit from northridge. they send pretty much whatever is in stock because the stuff they have in stock is all made by the same supplier then just rebranded to whatever company makes the box.
i got yukon gears and motive install kits. my installer said for future reference try and get yukon install kits as his experience says that the yukon kits are more complete (has more parts) than the motive. i honestly dont know what more it has, but thats just what my guy told me.
damon.l is offline
post #7 of 16 Old 03-12-2013, 11:25 AM
hammerstien's Avatar
Yukons and Marcus at river city. Done deal
hammerstien is offline
post #8 of 16 Old 03-12-2013, 11:35 AM
PhrogMech46's Avatar
I went with 5.38 Yukon gears ordered and installed by rwk haus supply. I had 5.13's in my first jk and like the 5.38's better.
See Garage for Mods
PhrogMech46 is offline
post #9 of 16 Old 03-12-2013, 11:38 AM Thread Starter
That seems like a good deal for the gears and install kit, is this something I can do at home? I have decent mechanical skills, just have never done a set of gears.
do I really need a housing spreader?
I have no problem getting the other necessary tools and don't mind tackling a project like this, but don't want to ruin a good set of gears
post #10 of 16 Old 03-12-2013, 11:45 AM
JKO Dickhead
Asmmns's Avatar
After doing my first der of gears recently. This is something that someone can do to save a ton of cash. However make sure you have someone there helping you that knows what they are doing and have done gears before.
It's not hard. It's time consuming, and fairly tedious ... And can be very nerve wracking to hope that they are set up right.
Not something I would have even attempting without the presence of a master tech mechanic and another guy who had done a ton of gear sets directing me.
But it can be done
__________________
CURE SMA !
Asmmns is offline
post #11 of 16 Old 03-12-2013, 11:51 AM
But it can be done
I agree!
post #12 of 16 Old 03-12-2013, 02:11 PM
UnlimiDozer's Avatar
^^^ This! Tried this last summer with a pair of D44s in my truck. After fiddling with it for about three days I finally loaded up the housings and took them to a local guy I had established a decent working relationship with. He said I had the fronts close, but not ideal. But the rears were not even close, which I didn't think they were, but I had come to the point that every change seemed to make things worse. Someone with experience giving advice probably could've guided me through the rough spots, but trying it with nothing but pictures and descriptions could make you pull your hair out. YMMV.
My Build Thread:
I'm the NRA
JOIN HERE:
UnlimiDozer is offline
post #13 of 16 Old 03-13-2013, 11:05 AM Thread Starter
Well I guess I should have a backup plan before starting. I have seen a few gear install guides, and it doesn't look impossible, but having someone who has done it and can guide you is always a plus.
post #14 of 16 Old 03-13-2013, 11:16 AM
JKO Dickhead
Asmmns's Avatar
from what I have been told..the jk axles are much easier than the older dana stuff, as the shims are on the outside.
started with what was there from the factory, some quick math and both front and rear were almost perfect firtst time.
pinion install is a delicate tedious process to ensure you arent wrecking the crush sleeve.
maybe i got lucky ??
__________________
CURE SMA !
Asmmns is offline
post #15 of 16 Old 03-14-2013, 11:32 AM
cloaked willys's Avatar
We have 5.38 gears in the shop JK and they are great. Remember that the hummer setup is heavy and you need more gear to help get it rolling.
BTW, I have G2 gears in both my tow rig and my crawler. Never had an issue with them.
MetalCloak, It's Your Jeep, Only Better
Will (916)631-8071
Originally Posted by -SLADE- View Post
Metalcloak claims to have the highest clearance flat fenders and their Duroflex joints appear to bridge the gap between stock clevite bushings and re-buildable joints making them a great option for daily drivers. Metalcloak's dual rate coils actually backup the available travel in their suspension instead of just making claims of "flex" and "max travel" only to provide short coils with little travel like some have done.
cloaked willys is offline
post #16 of 16 Old 03-14-2013, 04:53 PM
X2 on the 5.38's. I run 37" on my 08 2 door with an auto. At 70mph I'm turning aprox 2100 rpm. Tranny almost never downshifts on small hills now
