Rubicon case problem - JKowners.com : Jeep Wrangler JK Forum
post #1 of 18 Old 03-08-2013, 08:56 PM Thread Starter
Mhare's Avatar
I just swapped a rubi case into my x. It will not come out of four wheel drive. My linkage is fine. I'm not sure if there is something sticking. The guy I bought it from said it had been sitting for over a year. I changed the fluid and it looked clean. Does anyone have any experience with this. I'm going to pull it out and tear it down my next day off. Just want some ideas on what the problem may be. I shifted in and out of 4hi while moving forward and reverse. Pulled the front shaft and drove it for about 60 miles hoping it would free it up. Put the front shaft back in and it is definitely in 4hi. It does shift in and and of 4 lo fine.
Any ideas guys?
Mhare is offline
post #2 of 18 Old 03-08-2013, 10:09 PM Thread Starter
Mhare's Avatar
I even removed the linkage and front drive shaft. Then pulled the shifter on the case as far forward as I could. And the front yoke would not free spin like it should. I am convinced it's an internal issue. But I won't know until I tear it down. But what throws me is the dash lights correspond with the linkage position.
Mhare is offline
post #3 of 18 Old 03-09-2013, 05:46 AM
Un hook the shifter cable and manually push the linkage on the xfer case all the back which should be in 2hi.
post #4 of 18 Old 03-09-2013, 11:34 AM Thread Starter
Mhare's Avatar
This is not that way. If I push the linkage on the transfer case to the back it goes in 4lo.
Mhare is offline
post #5 of 18 Old 03-09-2013, 12:29 PM Thread Starter
Mhare's Avatar
This is what Is what I'm saying
This is a screen shot from an advanced adapters you tube video
Mhare is offline
post #6 of 18 Old 03-09-2013, 02:04 PM
Maybe I am thinking this upside down.
Does it make sense that when you shift from 2Hi into 4Lo that you are pulling the cable which would pull the linkage forward?
post #7 of 18 Old 03-09-2013, 02:54 PM Thread Starter
Mhare's Avatar
That makes total sense to me. And before I looked at this. I would have assumed. That was the way it worked.
Mhare is offline
post #8 of 18 Old 03-09-2013, 04:19 PM Thread Starter
Mhare's Avatar
This will clear up the confusion
Mhare is offline
post #9 of 18 Old 03-09-2013, 07:10 PM
swap your hairpin clip for a e-clip or turn the hairpin around so it does not hit the back of the housing and keep you from going into 2-hi.
jklarry09 is offline
post #10 of 18 Old 03-10-2013, 07:20 AM Thread Starter
Mhare's Avatar
That is not my linkage. Just an example I found. I have an issue inside my transfer case.
I have done some research and believe the issue is going to be with the mode selector arm or gear.
I am taking it back out and tearing it down tomorrow. I will update what I find
Mhare is offline
post #11 of 18 Old 03-12-2013, 08:11 PM Thread Starter
Mhare's Avatar
Well I got it figured out.
Apparently the previous owner of this case had changed the input gear bearing(#40). Upon reassembly he decided to leave out the input gear thrust washer(37), the carrier lock ring(78), and the lock ring(39). And installed the input bearing retainer(44) in that space and then installed the snap ring(41).
This caused the main shaft(19) to sit 4mm to the front o the case. Which prevented the synchronizer stop ring(29) from disengaging by the said 4mm.
I have parts on order to reassemble. Thanks for the input guys.
Hope that makes sense. I tried to describe it the best I could.
Mhare is offline
post #12 of 18 Old 03-12-2013, 08:16 PM
dmhines's Avatar
Seller gonna make things right? I just put a rubi case in my X and would have been pissed if there was an issue since seller said it was perfect.
2009 JK - 2DR - 6SPD - 1/2 Doors
4.88 G2 Gears / Warn XD9000i / Custom bumpers & Swing Gate
XRC Rock Rails / 35" Kumho's on Black Rock Vipers
2.5" Mutt Lift / Rubicon T-Case / E-DISCO / VIAIR OBA
Rear CV Driveshaft / Rear Detroit Locker / Front Aussie
Teraflex Sleeves / Gussets / Nitro Chromoly Axles
dmhines is offline
post #13 of 18 Old 03-12-2013, 08:30 PM Thread Starter
Mhare's Avatar
He answered the first time I called. He said he would talk to his buddy "mechanic at Chrysler" and get back with me the next day. He has not answered the phone again.
Mhare is offline
post #14 of 18 Old 03-12-2013, 08:46 PM
Well that was fucking brilliant of him.
post #15 of 18 Old 03-13-2013, 12:37 AM Thread Starter
Mhare's Avatar
Oh and I Said the fluid I drained out originally was clean. But this time it was full of rust. The inside of this case looks as if it set for awhile without fluid. He must have filled it up just so it looked good when I checked it.
After the 60 or so miles I put on the case. The fluid came out almost orange.
I will clean it all up and have to do a few extra fluid changes. But I think I will be ok.
Pretty shitty for a "ready to go case"
Mhare is offline
post #16 of 18 Old 03-13-2013, 06:26 AM
What a fuckhead. If he doesn't make this better in some way you need to call him out.
post #17 of 18 Old 03-14-2013, 03:04 PM
Topgun863's Avatar
That sucks man...I'd be concerned if they were into that case before and didn't get it back together right...makes you wonder if/how long they ran it in 4wd because they couldn't get it into 2wd. I'd be pretty pissed if I were you and wasn't told that the case was apart/something was changed prior to purchase. Hope you get it all sorted out. Might wanna look over the other bearings and the gears while you have it apart an look for wear and/or signs of them getting hot.
07 X 2dr- 6spd
Topgun863 is offline
post #18 of 18 Old 03-21-2013, 08:29 PM Thread Starter
Mhare's Avatar
I got it all back together and it's working fine now.
Mhare is offline
