Front Rubi Locker fried - is it repairable if the dealer won't warrantee? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 04-04-2009, 12:13 PM Thread Starter
I seem to have fried my front Rubi E-locker. I also broke my rear drivers side Superior CM axle shaft. That is covered under a lifetime warrantee and Superior already has the replacement in UPS. Superior says this is the first JK CM axle to break.
I'll probably pull my CM front shafts and put the stockers in and see if the Jeep dealer will warrantee the locker. If not is there any alternative to buying a new one? Is it repairable - I've heard various things? If so who can do it. I have heard that ARB is coming out with an air locker that will fit the Rubi axles but that it is 90 days out. I really don't want to buy a new factory locker. If I have to buy anew locker I'd rather buy the ARB in 90 days.
08 JKU Rubi, GM 6.2 LS, 6L80 6 sp automatic, Atlas 4 sp TC, Dynatrac ProRock 80 rear and in front PR60 w RCV shafts, DynaLock w Stub hubs, 4.88 gears and ARB Lockers, 4.0" lift, Synergy Long Arm, King coilovers, 40" Nitto's, Hutchison Rock Monster wheels, GenRight alum bumper and fenders, GenRight 20 gal aux gas tank, PSC steering, Warn Zeon 12K.
2nd Jeep is a 2014 Grand Cherokee Overland with a 5.7 Hemi, Quadra-Lift Suspension and Quadra-Drive II. My wife says I can't do anything to it!
post #2 of 7 Old 04-06-2009, 06:43 PM
There is no reason why the shouldnt fix it. You didnt mod the locker and evens installed if you have had bigger gears installed that would not fry a locker. You should be good
MALL CRAWLER is offline
post #3 of 7 Old 04-06-2009, 07:36 PM
seer's Avatar
Actually, things turned out better than you could ask. We thought it was his locker when it happened, but he went in and found it was his left axle that popped right at the splines. Since he was running Alloy USA's in the front and Superiors in the rear, they were both covered with a non-Chrysler type warranty. You know, replaced no questions asked.
seer is offline
post #4 of 7 Old 04-06-2009, 07:42 PM
So he broke a superior rear d44 axle at the splines? Kinda surprised to hear it. What was the conditions that caused it?
WTF_LOL is offline
post #5 of 7 Old 04-06-2009, 08:18 PM
kerryp's Avatar
Did I read that right, he broke front and rear alloy shafts, bith at the same time?? Y'all musta been gettin it with the skinny petal to snap two at once??
ジープ
@CigarsNJeeps
kerryp is offline
post #6 of 7 Old 04-06-2009, 09:57 PM
on 35's in a rubi.........??????? with alloys????
what kinda stupid was taking place when they broke???
were there 's involved???
redneckhouston is offline
post #7 of 7 Old 04-07-2009, 12:25 AM Thread Starter
They didn't break at exactly the same time. And no beer was involved - and no getting into the skinny pedal too hard.
I was going up High Dive in Moab and got off line a bit; the line was the only way that I could see that a JK on 35's could use to get up it. Some bump steer put me a bit to the left of where I wanted to be and my left rear tire dropped in a crevice. Apparently the crevice was just the perfect size to really sieze the rear wheel and tire. I was feeding in some throttle, was not spinning or moving and she went. I was probably at around 2500 rpm. I guess the combination of the automatics torque multiplication, 4:1 TC and 5.13 gears put a lot of torque to that axle. After it went we got on the winch and I was easing into the throttle to help the winch and the front axle went.
When I thought the front e-locker was gone I was wishing that it had been an axle since it would be covered under warrantee and I wouldn't have to fight Chrysler over it. The new ARB locker for the Rubi axles is 90 days away. If it was available now I wouldn't have minded replacing the factroy locker since I could get the beefier ARB unit. I just hated the idea of buying a new factory locker if the old was not rebuildable.
In retrospect by trying this climb I was pushing the envelop for a heavy 4 dr JK on 35's. I don't regret trying it, excpet for my wife is still pissed at me as she had bad feelings about it and is usually game to try most anything. Had I/we realized the rear wheel tire was as tightly jammed into the crivice as it must have been we could have used a HiLift and wheel lifts strap to lift it up and free it.
I had had some concerns about the strength of the pinion in the 5.13 gears but they seem to have held up well. I didn't look at the pinion on the rear but the ring looks good. In order to get the axle stub out of the front carrier I had to pull the carrier (and drill and tap the stub and fab up a puller) and hence could check out the pinion and it looks perfect (as is the ring gear). I was also happy with the fact that the e-lockers held up. I did not think that the axles would be the weak link. In the end all it cost me was an upgrade to my AAA memberhip (which I was going to do anyway) to get 100 mile tows which got me home and the time needed to swap axle shafts. New axle shafts are on the way. With the stock axles in she drives fine and both lockers lock and unlock normally.
