Is there any reason this diff won't fit in my Wrangler's rear axle? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 20 Old 04-02-2009, 10:09 AM Thread Starter
thaduke2003's Avatar
http://store.summitracing.com/partde...=DTL%2D913A590
Looking for a limited slip rear, besides OEM this is all I could find. Would rather not have a locker unless it's electronically controlled. Open to other ideas. I have stock open front and rear (read: GARBAGE), and want at LEAST a good rear diff. Thanks! Mark W.
thaduke2003 is offline
post #2 of 20 Old 04-02-2009, 10:38 AM
There seems to be some confusion out there.
I would talk to Detriot (weren't they bought by somebody?) and ask them. Most people say that the ring holes need to be drilled out and tapped for a different size bolts. I belive that is the only modification that would be needed.
I have also read that some people just installed it with no mods needed.
You of course would need the proper spline count but my understanding is there ARE people who have put a Detroit in. Some have also reported NO modifications although that is not confirmed. Contact Detroit or whoever owns them now. Post up what you find here!
I don't have the money rght now but I will be putting a Detroit in the rear. When The time comes I will share all the details I learn here at JKO
WTF_LOL is offline
post #3 of 20 Old 04-02-2009, 10:52 AM
Xtremjeepn's Avatar
Personally I would not run a Detroit in a Jeep. Did it once, HATED IT!.
Long wheelbase automatic trucks do "okay" with full time lockers.
Full time lockers are a pain on the street for a daily driver.
That is the whole reason they make selectables.
I have a Detroit in my 1 ton Crew Cab automatic truck and it is only somewhat noticeable.
I had one in my TJ and HATED IT. Talk about a clunky, squirly no fun to drive rig. I tossed in for an Eaton E-locker and life was good again.
Eaton bought Detroit.
The ring gear bolt holes are bigger on the "Next Gen" Dana 44 ring gears. There is no taping that needs to be done, just holes.
I "think" if you buy a 3.92 and down carrier it will fit the "next Gen" gear offset, but I have only heard it as a rumor. Can't varify it.
Just see if they make one for our diff specifically.
__________
Cole Ford
Xtremjeepn is offline
post #4 of 20 Old 04-02-2009, 11:01 AM Thread Starter
That's why I'm not running a locker ^ I'm looking at a limited slip diff- BIG difference- Mark W.
post #5 of 20 Old 04-02-2009, 11:07 AM
terrahawk's Avatar
If you run larger than a 35" tire you are going to regret that.
terrahawk is offline
post #6 of 20 Old 04-02-2009, 11:12 AM Thread Starter
^ Why's that? And I don't plan to go bigger than 32 or 33, but I'm just curious- Mark W.
post #7 of 20 Old 04-02-2009, 11:16 AM
terrahawk's Avatar
It will implode on itself...just not up to the task of spinning large tires like that...saw one literally explode this past weekend.
The carrier split into about four pieces!
post #8 of 20 Old 04-02-2009, 11:20 AM
Prope's Avatar
If I remember correctly, most cases need to be drilled and re-tapped for 7/16" ring gear bolts. Some companies are starting to make their cases to accept these but not many yet.
Also, like Terrahawk said... if you look at the Tru-Tracs manual(available online) I'm pretty sure they are only rated up to 32-33" tires, anything above that voids the warranty so be careful.
Although, I don't think the picture terrahawk posted is a tru-trac, correct hawk? They are gear based limited slip rather than clutch based and the carrier is much beefier.
'08 Unlimited Sahara - Hemi -
Fenders & Rockers -
Prope is offline
post #9 of 20 Old 04-02-2009, 11:41 AM
jkdrone's Avatar
It was a Posi-Trac, IIRC.
!c
jkdrone is offline
post #10 of 20 Old 04-02-2009, 12:34 PM
Steve-UK's Avatar
The bolts thread into the ring gear not the carrier, so you will only have to open up the holes in the carrier. Recently I have fitted a couple of True-Tracs into a customers TJ and had to sleeve the holes in the True-Tracs as they were for the larger bolts.
JK X Unlimited 3.5" RE Long Arm Lift, RE Drivelines, Rugged Ridge 17 x 9 Steel Wheels, 35" Mickey MTZ's, Bushwhacker Flares, 4.10 ratio, Rugged Ridge Front & Rear Bumpers.
TJ Wrangler 3.5" RE Lift, ARB's 4.56 ratio 33" Tyres
TJ Wrangler 5.5" RE Long Arm Lift, ARB's 4.56 ratio, 35" Tyres
XJ Cherokee 5.5" RE Lift, ARB's 4.88 ratio 35" Tyres
Steve-UK is offline
post #11 of 20 Old 04-02-2009, 01:20 PM Thread Starter
Hold on- sorry- I'm having a hard time picturing that, Steve- I need to open up the bolt holes on the diff itself? Or sleeve them to make them smaller? Sorry- mechanic's brain- I need to have it in my hands to get it Thanks! Mark W.
post #12 of 20 Old 04-02-2009, 01:28 PM
The ring gear is bolted to the carrier. The bolts go through a hole in the carrier and thread into the ring gear. The hole in the ring gear needs to be eith enlarged or sleeved to be the correct size for the ring gear bolt
WTF_LOL is offline
post #13 of 20 Old 04-02-2009, 01:28 PM
Xtremjeepn's Avatar
The ring gear holes on the carrier are bigger for the JK ring gear.
So on older non JK type D44 the Ring Gear bolt holes on the carrier are smaller.
__________
Cole Ford
post #14 of 20 Old 04-02-2009, 01:33 PM Thread Starter
Gotcha- I take it the ring gear is hardened, so I'd probably have no luck with a regular drill, na? Mark W.
post #15 of 20 Old 04-02-2009, 02:17 PM
Broncojohn's Avatar
I've run a Trutrac in the front of my Bronco for years. It held up to 35's; it will lock up pretty good if you ride the brake while on the gas. It doesn't have clutches that wear out which makes it nice.
Broncojohn is offline
post #16 of 20 Old 04-02-2009, 02:19 PM
Broncojohn's Avatar
That carrier looks like a Traclock. It is weak, a better version is the Powerlock but it still has clutches.
post #17 of 20 Old 04-02-2009, 02:27 PM
terrahawk's Avatar
Was...a Traclock LOL .
post #18 of 20 Old 04-02-2009, 02:28 PM
Broncojohn's Avatar
post #19 of 20 Old 04-02-2009, 02:35 PM
Steve-UK's Avatar
No you do not have to modify the ring gear, it is the carrier that you may have to alter. The bolts pass through the carrier and tighten into the ring gear. So you may have to enlarge the holes in the carrier.
Steve-UK is offline
post #20 of 20 Old 04-02-2009, 02:37 PM Thread Starter
Thanks, all. Is there a write-up anywhere about diff swaps in the Dana 44? I'm a competent wrench monkey, but having instructions/photos will make a world of difference Thanks! Mark W.
