Name that skid - JKowners.com : Jeep Wrangler JK Forum
post #1 of 17 Old 02-29-2012, 03:45 PM Thread Starter
Name that skid
This was under my Rubicon when I
I got it. Obviously it's been put to use but is it factory or aftermarket? I was hoping I could maybe replace the aluminum part for appearance purposes?Attachment 48417
Rescue green 07 2-door on 35's
viperbluelx is offline
post #2 of 17 Old 02-29-2012, 04:04 PM
Definitely looks home made to me. If it is from a company, what a POS
2008 JK X 2DR NSG370
Time to build the TONS!
Long Island Off Road Club
NOVA4x4
Suffolk JK is offline
post #3 of 17 Old 02-29-2012, 04:06 PM
I would name it Fred the Sled.
Dancin Dan is offline
post #4 of 17 Old 02-29-2012, 04:22 PM
venom's Avatar
looks like a factory skid with an additional bar across and a plate added
Originally Posted by My Wife
venom is offline
post #5 of 17 Old 02-29-2012, 05:27 PM Thread Starter
Thanks, it looks bad because it's beat up but it certainly is not homemade.
post #6 of 17 Old 02-29-2012, 05:55 PM
How can you say not homemade when you don't know where it came from in the first place? That is homemade.
post #7 of 17 Old 02-29-2012, 06:00 PM Thread Starter
The tubular bars under the flat skid are built very precise probably in a jig, but it homemade since that's obvious.
post #8 of 17 Old 02-29-2012, 06:03 PM
I would call it "Remy the soon to be recycled"
home brew skid for sure.
If you worry about what it looks like, find a new factory skid, because anything you plan on using will be ugly in no time flat if you wheel.
Fnord5 is offline
post #9 of 17 Old 02-29-2012, 06:08 PM
Slow and Low
Co4Lo's Avatar
Actually, that is not home made. You got a Border Patrol JK!!
There is a company that makes them for the US Government. Those skids are all installed on the Border Patrol JK's. The "system" includes that belly skid, front diff skid, front bumper skid, tubular evap skid.
I'm guessing your JK is white. I would also look under the carpet. There are probably a whole bunch of holes from all the equipment that was mounted under there.
They also rivot a steel plate over the jack mounting cubby for some reason. Not sure why, but it's pretty weird.
Co4Lo is offline
post #10 of 17 Old 02-29-2012, 06:19 PM
Slow and Low
Co4Lo's Avatar
Go check your evap. I bet it has that tubular skid on it. And on a lot of the BP Rubicons, they also remove the electric swaybar.
They install hour meters in the dash too, so you probably have mostly new dash pieces since they most likely removed all that shit at the stealership you bough it from.
Co4Lo is offline
post #11 of 17 Old 02-29-2012, 06:20 PM
That would make sense. Being a government vehicle the lowest bidder most likely made those skids, and it shows, lol.
Semper Fi
highoctane is offline
post #12 of 17 Old 02-29-2012, 06:27 PM
Slow and Low
Co4Lo's Avatar
I recently built 3 of those BP JK's that we bought at auction. The floors were so tore up that we ended up Line-X'ing all of the tubs.
After some nice lifts, tires, and a bunch of TLC, they turned out pretty decent. But they were beat to shit! Much worse than my Farabee's Rental Rocket was.
Co4Lo is offline
post #13 of 17 Old 02-29-2012, 06:39 PM Thread Starter
Yes it was border patrol, I knew that when I bought it. This one is actually in good shape, there were a few light bar holes in the roof but I had those fixed when I had the top painted body color. I'll check for holes in the pans but I've had it on a lift a good bit and never saw holes. Mine does have plates riveted to the inside of the tailgate which makes no sense.
post #14 of 17 Old 02-29-2012, 06:40 PM Thread Starter
No hour meter in mine, what did the hour meter take the place of on the cluster?
post #15 of 17 Old 02-29-2012, 06:43 PM Thread Starter
Attachment 48424
post #16 of 17 Old 03-01-2012, 06:07 AM
Ok now I have to ask. How do you get hold of a BP JKU?
post #17 of 17 Old 03-01-2012, 06:54 AM
Slow and Low
Co4Lo's Avatar
They get auctioned off after retirement from the BP, same as Farabee's (and all other) rental Jeeps, and end up in the circuit. Dealers buy them at auction because they usually are amazed at the price to value(on paper) ratio that they can buy them for. They think they got a steal...
Till they get them in their shop and realize that they pretty much need to rebuild them to make them marketable. Then they go
Co4Lo is offline
